返回列表 发新帖
【题目】【讨论】說說這個東西的電極與刀路 --加分題
发表于 2003-5-16 09:31:34 | 只看该作者
就是用Lathe, 不是在Mill/Turn...
发表于 2003-5-18 03:24:50 | 只看该作者
Lathe如何与mill/turn建立联系?
发表于 2003-5-18 10:38:47 | 只看该作者
顧名思義, 車銑複合, 本來就是 車床上帶有銑的功能。。。標準就是用車的, 用Mill/Turn的銑的功能, 系統會自動輸出一些宣告命令... 你隨便做一個, 用APT輸出就可以看到...
发表于 2003-5-19 03:40:49 | 只看该作者
Mill/Turn 仿真结果:
发表于 2003-5-19 04:02:38 | 只看该作者
$$ SURFCAM INC to APT Translator $Revision: 146 $
PARTNO/0
UNITS/MM
$$ Unrecognized INC record #221, Size 190
OPERTN/6,-1,0
OPERTN/23,-1,0
PPRINT/'CView 1, Top View'
PPRINT/'ONXY=0.0000000000, FROMXY=89.9999999952'
DEFCV/ONXY,0.0000000000,FROMXY,89.9999999952
MCS/$
1.0000000000,0.0000000000,0.0000000000,$
0.0000000000,1.0000000000,0.0000000000,$
0.0000000000,0.0000000000,1.0000000000,$
0.000000,0.000000,0.000000
MULTAX/ON
PPRINT/SURFCAM TOOL LIBRARY NUMBER 2041
PPRINT/SURFCAM TOOL TYPE NUMBER 0
PPRINT/DESCRIPTION: 12MM  -  4 FLUTE - HSS BALLMILL
PPRINT/TAPER ANGLE: 0.000000
PPRINT/NUM FLUTES: 4
PPRINT/MATERIAL: 0
CUTTER/12.000000,6.000000
TURRET/41,41,0.000000,0.000000,REAR
SELCTL/0
SPINDL/RPM,796,CLW
COOLNT/FLOOD
SELECT/0
RAPD1/
GOTO/-59.376205,-8.738665,350.000000,$
GOTO/-57.456562,-8.832479,235.217712,$
-0.5484696627,0.0268039107,0.8357407451
EVENT/PLNG_S,-57.456562,-8.832479,235.217712,-1.371174,0.067010,2.089352
RAPD0/
FEDRAT/MMPM,0.000000
GOTO/-56.085388,-8.899488,233.128357,$
EVENT/PLNG_E,-56.085388,-8.899488,233.128357,-1.371174,0.067010,2.089352
EVENT/ZLVL_S,-56.085388,-8.899488,233.128357,-1.371174,0.067010,2.089352
ROW/START
GOTO/-56.358215,-8.873680,232.947525,$
-0.5509588718,0.0281450339,0.8340576291
GOTO/-56.487312,-8.857847,232.861954,$
-0.5520594716,0.0298723448,0.8332694173
GOTO/-56.678898,-8.831541,232.733704,$
-0.5534611940,0.0319229662,0.8322629333
GOTO/-56.860039,-8.806800,232.611847,$
-0.5547804236,0.0338823572,0.8313065767
GOTO/-57.227146,-8.754864,232.362869,$
那些是Mill/Turn的宣告命令? 找不到。
文件附上,请大家指点。:I
发表于 2003-5-19 09:49:59 | 只看该作者
OPERTN/6,-1,0  ----- 銑, Pocket
OPERTN/23,-1,0 ---- 銑, 5 Axis Project;)
发表于 2003-5-19 13:59:50 | 只看该作者
看来还是要学习APT语言,以前偷懒了。:I
18
发表于 2003-5-19 14:24:54 | 只看该作者
那個是 Surfcam在SPost (GPost)裡的代表APT語句 ...不是標準的
GMT+8, 2025-4-28 23:49 , Processed in 0.023575 second(s), 10 queries , Gzip On, Redis On.
