查看: 27772|回复: 42
[原创] 发自己的源代码,支持的顶
发表于 2009-1-9 09:51:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
int SHEET_ok ( int dialog_id,
             void * client_data,
             UF_STYLER_item_value_type_p_t callback_data)
     /* Make sure User Function is available. */
     if ( UF_initialize() != 0)
          return ( UF_UI_CB_CONTINUE_DIALOG );
    //变量申明
    char * sVariable="UGII_USER_DIR";
    char * sTranslation;
    char sSheetName[30]="";//视图名称
    UF_STYLER_item_value_type_t value;
    char sTemplatePath[255]="";//模板路径
    char sDTemplatePath[255]="";//标注模板
    int iSheetSelect=0;//图框选择
    char *sMillTemplate="\\application\\SheetTemplate\\A3_H_Mill.prt";
    char *sTurnTemplate="\\application\\SheetTemplate\\A3_H_Turn.prt";
    char *DraftingTemplate="\\application\\SheetTemplate\\template.prt";
    char buff[254]="";
    tag_t tPart_CurrPath;
    char sPart_Fspec[ 256 + 1 ];
    int  num_drawings;
    tag_p_t  drawing_tags;
    int                   mpi_array[100];
    double                mpr_array[70];
    char                  rad_symbol[27], dia_symbol[27];
    tag_t  part;
    UF_PART_load_status_t  error_status;
    tag_t  note_tag=NULL_TAG;
    double origin_3d[ 3 ]={57,-2.2,0};
    char * text_string[1];
    char str[254]="";
    UF_DRAW_info_t drawing_info;
    tag_t drawing_tag;
    drawing_info.drawing_scale=1;
    UF_import_part_modes_t modes;
        modes.layer_mode=0;
        modes.group_mode=1;
        modes.view_mode=0;
    double dest_csys[ 9],x_vec[ 3 ]={1,0,0},y_vec[ 3 ]={0,1,0};
    double dest_point[ 3 ]={0,0,0};
    tag_t  group ;
    drawing_info.units=UF_PART_METRIC;
    drawing_info.size_state=UF_DRAW_CUSTOM_SIZE;
    drawing_info.projection_angle=UF_DRAW_FIRST_ANGLE_PROJECTION;
    drawing_info.size.custom_size[0]=420;
    drawing_info.size.custom_size[1]=298;
    int SheetSign=0,PathSign=0,DraftingSign=0;
/********************************输入查询*********************************/
    //新图标识DraftingSign
     value.item_id=SHEET_NEW_DRAWING;
     value.item_attr=UF_STYLER_VALUE;
     UF_STYLER_ask_value (dialog_id, &value);
     DraftingSign=value.value.integer;
    //图框标识SheetSign
     value.item_id=SHEET_IMAGE;
     SheetSign=value.value.integer;
    //路径标识PathSign
     value.item_id=SHEET_PATH;
     PathSign=value.value.integer;
     //sprintf(buff,"%d;%d;%d",DraftingSign,SheetSign,PathSign);
     //uc1601(buff,1);
/********************************部件标识*********************************/
    tPart_CurrPath=UF_ASSEM_ask_work_part ( ); //获得当前工作部件标识
       UF_PART_ask_part_name (tPart_CurrPath,sPart_Fspec);  //查询部件路径
/********************************基本参数查询*********************************/
     //查询图框选择
     value.item_id=SHEET_SELECT ;
     iSheetSelect=value.value.integer;
     //取文件路径
     UF_translate_variable (sVariable, &sTranslation); //取环境变量
     strcpy(sTemplatePath,sTranslation);
     strcpy(sDTemplatePath,sTranslation);
     switch(iSheetSelect)
        {case 0: strcat(sTemplatePath,sMillTemplate); break;
         case 1: strcat(sTemplatePath,sTurnTemplate);  break;
         default: uc1601("图框选择错误!",1);
     strcat(sDTemplatePath,DraftingTemplate);
     //查询视图名字
     value.item_id=SHEET_NAME ;
     strcpy(sSheetName,value.value.string);
/*********************************功能选取*********************************/
/*********************************功能创建*********************************/
    UF_DRAW_ask_drawings (&num_drawings, &drawing_tags );
    //判断视图名称是否重复
    for(int i=0;i<num_drawings;i++){
        UF_OBJ_ask_name (drawing_tags, buff);
        if(strcmp(strupr(sSheetName),buff)==0){
            strcat(sSheetName,"_1");
            //uc1601(buff,1);
            i=0;
    UF_free (drawing_tags );
    //1:创建视图
    if(DraftingSign==1)
        UF_DRAW_create_drawing (sSheetName, &drawing_info, & drawing_tag );
    //2:导入图框
    if(SheetSign==1){
        UF_MTX3_initialize (x_vec, y_vec, dest_csys);
        UF_PART_import (sTemplatePath, &modes, dest_csys, dest_point, 1, &group );
    //3:设置标准模板参数
    UF_PART_open (sDTemplatePath, &part, &error_status );
    UF_DRF_ask_preferences (mpi_array,  mpr_array, rad_symbol, dia_symbol );
    UF_PART_close (part, 0, 1 );
    UF_PART_set_display_part (tPart_CurrPath );
    UF_DRF_set_preferences (mpi_array,  mpr_array, rad_symbol, dia_symbol );
    //4:创建路径标注
    text_string[0]=str;
    strcpy(str,"模型路径:");
    strcat(str,sPart_Fspec);
    if(PathSign==1)
        UF_DRF_create_note (1, text_string, origin_3d, 0, &note_tag );
    UF_terminate ();
    /* Callback acknowledged, terminate dialog             */
    /* It is STRONGLY recommended that you exit your       */
    /* callback with UF_UI_CB_EXIT_DIALOG in a ok callback.*/
    /* return ( UF_UI_CB_EXIT_DIALOG );                    */
    return (UF_UI_CB_EXIT_DIALOG);
收藏收藏1 分享淘帖 赞一下!赞一下!
发表于 2009-1-9 09:53:57 | 只看该作者
该程序功能:自动创建新图纸,自动设置制图参数,自动写路径,自动导入图框;以后我会继续发我的代码,希望大家顶起来,虽然程序功能不大,但是也是一个函数应用例子,看了请回!!!!
发表于 2009-1-9 11:10:51 | 只看该作者
恩恩。。。
学习借鉴一下!
发表于 2009-1-9 11:11:07 | 只看该作者
支持楼主!
加油!
发表于 2009-1-9 19:35:20 | 只看该作者
最好有NX/OPEN C++的
发表于 2009-1-9 20:27:03 | 只看该作者
支持源码。
再接再厉。
发表于 2009-1-10 07:58:28 | 只看该作者
支持,学习了
发表于 2009-5-4 20:57:58 | 只看该作者
支持,学习了
头像被屏蔽
发表于 2009-5-4 21:19:37 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-5-7 19:55:43 | 只看该作者
楼主能不能帮我搞个自动建立三视图并且标注三个方向的最大外形的小外挂啊
GMT+8, 2025-9-18 20:49 , Processed in 0.085715 second(s), 10 queries , Gzip On, Redis On.
