CATIA 快捷键集锦
发表于 2005-5-2 15:55:40 | 只看该作者
还有什么,高手指点指点
52
发表于 2005-5-3 12:43:27 | 只看该作者
收益非前,谢谢
53
发表于 2005-5-8 19:54:02 | 只看该作者
OK
54
发表于 2005-5-26 17:57:16 | 只看该作者
来点实用的:ctrl+pageup   放大
                ctrl+pagedown   缩小
55
发表于 2005-5-27 15:51:25 | 只看该作者
Thank you everyong, let me know more.
56
发表于 2005-5-27 17:38:59 | 只看该作者
就这些太少了吧我在UG里可以设置很多,很多命令都可以设置,设置好了又不变,有没有根据知己的爱好设置的,希望有人能赐教?
57
发表于 2005-5-27 19:21:21 | 只看该作者
F10 显示与隐藏,F11切换到背景模式,F4收缩机构树,F3隐去结构树。F9自由设置图面的比例。ctrl加N模块的建立。
58
发表于 2005-6-2 11:28:06 | 只看该作者
谢谢啦
59
发表于 2005-6-4 21:18:41 | 只看该作者
60
发表于 2005-6-5 15:27:52 | 只看该作者
Keyboard Shortcuts
Use this keyboard key (or combination)... To...
Escape           Exit the current dialog box (when there is one)
F1               Get contextual online help
Shift + F1     Get help on toolbar icons
Shift + F2    Toggle the specification tree overview on and off
F3              Toggle specification tree display on and off
Alt + F8       Run macros
Shift + F3    Activate the graph is the model is active and inversely
Home          Display the top of the graph
End             Display the bottom of the graph
Page Up      Relocate the graph one page up
Page Down  Relocate the graph one page down
Ctrl + Page Up          Zoom In the graph
Ctrl + Page Down      Zoom Out the graph
Up arrow      Relocate the graph 1/10th (one tenth) of a page to the top
Down arrow  Relocate the graph 1/10th (one tenth) of a page to the bottom
Left arrow    Relocate the graph 1/10th (one tenth) of a page to the left
Right arrow  Relocate the graph 1/10th (one tenth) of a page to the right
Ctrl + Tab    Swap active document windows
Alt + Enter   Run the Properties... command
Ctrl + C Run the Copy command
Ctrl + F Run the Search... command
Ctrl + G Run the Selection Sets... command
Ctrl + N Run the New... command
Ctrl + O Run the Open... command
Ctrl + P Run the Print... command
Ctrl + S Run the Save... command
Ctrl + V Run the Paste command
Ctrl + X Run the Cut command
Ctrl + Y Run the Redo command
Ctrl + Z Run the Undo command
Another useful shortcut
Clicking an icon lets you run the command associated with that icon only once. However, double-clicking an icon lets you use the associated command as many times as you want without having to click on the icon several times.
GMT+8, 2025-4-19 00:43 , Processed in 0.025534 second(s), 12 queries , Gzip On, Redis On.
