查看: 16631|回复: 3
[原创] 关于4轴旋转角度极限定义!!
发表于 2009-3-3 17:28:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
现在用PM编程序
使用的是旋转精加工..可是后处理不配套
对PM的后处理修改不是很熟悉!!
现在一切都已经OK
但是C轴现在是累计旋转的就是旋转到8万多度``
想修改一下极限形成,就是到359.999度自动更改从0开始计算
关于4轴旋转角度极限定义不知道怎么定义
如果有懂的朋友请帮忙`谢谢!!!!!!!!!1
发表于 2009-3-5 16:22:18 | 只看该作者
This will allow the rotary elevation axis to maintain constant direction of rotation +/- when the usual maximum limit of 30000 degrees rotation is reached.  That is, the post option will change the angles of 29880; 29881; 29882 to be output as 29880; 1 M94 C ; 2; 3; etc.
( 29880 / 360 = 83 full revolutions - the limiting value must always be exactly divisible by 360 )
At the machine control interface carry out the following :-
        1,         Go into Program and Edit mode.
        2,         Press the MOD KEY
        3,         Enter 95148 (password)
        4,        Go To  MP 810.3
        5,         This will probably be set to 0 (This is incorrect to run M94 Reducing angle)
        6,         Change to 360 ( Max angle of 360 )
        7,         Enter End
        8,         Exit Edit mode back to Manual
        9,         Soft Key Pass Over Ref. M94 only on Rotary Elevation axis should be necessary
发表于 2009-5-6 16:15:34 | 只看该作者
上面内容是我误解了你的意思发的不好意思!你把后置给我 我帮你修改下!
发表于 2009-5-6 20:12:49 | 只看该作者
二楼的    这资料也被你搞到了。。。。,应该我认得你。。。
GMT+8, 2025-2-28 15:30 , Processed in 0.024624 second(s), 10 queries , Gzip On, Redis On.
