查看: 24980|回复: 2
[求助] adams中关于motion驱动的问题。
发表于 2009-3-6 16:09:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
机构比较复杂,电机的转速在每一秒也不一样, 经过matlab高次拟合后的函数为p1 = 1.0299e-008;
  p2 = -4.1086e-007;
  p3 = 5.4341e-006;
  p4 = -2.2375e-005;
  p5 = -0.00030668;
  p6 = 0.00066864;
  p7 = 0.1325305;
y = p1*x.^6 + p2*x.^5 +p3*x.^4 + p4*x.^3 +p5*x.^2 + p6*x.^1 +p7 ;
写在adams里面,写成1.0299e-008*time*time*time*time*time*time  -4.1086e-007*time*time*time*time*time + 5.4341e-006*time*time*time*time -2.2375e-005*time*time*time  -0.00030668*time*time +0.00066864*time + 0.1325305
在仿真的时候就出错了,错误提示是WARNING:    Initial displacement of MOTION bakupingdongjigou0002.MOTION_1 differs from that of
   JOINT bakupingdongjigou0002.JOINT_9, on which it is located, by 0.13253 .
ERROR:      No convergence was achieved after 25 iterations while solving for
   the kinematic displacements.
ERROR:   Simulation failure detected
发表于 2009-9-7 17:38:59 | 只看该作者
楼主,你的motion的初始位置不一致的问题解决了吗,如果解决了,往能和你交流下,我也遇到了这个问题,253659448,回复adams,非常感谢了
发表于 2011-12-27 13:32:59 | 只看该作者
初始位移不一致。。。。。???
GMT+8, 2025-4-17 16:04 , Processed in 0.024423 second(s), 14 queries , Gzip On, Redis On.
