查看: 23937|回复: 8
[求助] adams内存不足的问题
发表于 2009-3-13 16:42:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
跪求,在view模块里我建的一个钢板弹簧,有点复杂,进行静力学仿真时没问题,进行动力学仿真时,提示内存不足,我改了一下设置,两种solver都试过,还是不行,下面是错误信息,请哪位大哥大姐帮帮忙啊?
ERROR:      ***** ADAMS MEMORY OVERFLOW *****
   A larger MD array is required.
   The error occurred in subroutine "SYMFAC" while allocating " DOUB" space
   from "SOLV" for the "Jacobian array".
   Space Available:  22764    Space Requested:  73802
   ADAMS/Solver requires more program memory to run this model.
   Be aware that the above figures for Space available and Space
   requested only reflect the current requirements.  Additional space
   may be required later in the solution process.
   Several off-the-shelf memory configurations are available and
   custom configurations may be created.  The available memory models
   and the corresponding array sizes are:
          NAME         MDSIZ
        STANDARD    1,100,000
        LARGE       3,000,000
        EX-LARGE   10,000,000
        HUGE       20,000,000
   where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
   the main memory array in ADAMS in words (one word is 4 bytes).
   To use an alternative setting, you have to start the ADAMS 'Settings'
   program.  It can be found using the Start menu:
     Start -> Programs -> MSC.Software -> MSC.ADAMS -> ADAMS-Settings
   Alternatively, you can start 'adams_settings.exe' in the 'utils\win32'
   folder of your ADAMS installation directory.
ERROR:   Abnormal termination encountered in ADAMS/Solver.
发表于 2009-3-13 16:46:55 | 只看该作者
对了,我机器4G的内存,酷睿双核E7400的处理器,XP的操作系统,跪求!
发表于 2009-3-18 10:36:43 | 只看该作者
应该不是内存问题,我也遇到过,是个很简单的模型,经过修改后就可以仿真了。
但我忘记是怎么修改的了。。。。
应该从模型上或者设置上找问题。
期待高人解答。
发表于 2009-8-6 20:21:17 | 只看该作者
这个嘛,在开始程序里面找到adams的安装目录,选择adams-settings,进去以后点左边的Aview旁边的+号,在下一级选项里选择prefencens,出现的右边第一个就是内存大小了,把value修改为huge,左边的Asolver也同样将内存改为huge就行了……
发表于 2009-8-6 20:22:37 | 只看该作者
如果还不懂的话加这个QQ810889549
发表于 2010-4-25 14:08:34 | 只看该作者
学习一下 iukdhahdk、
发表于 2010-6-9 12:44:38 | 只看该作者
这个嘛,在开始程序里面找到adams的安装目录,选择adams-settings,进去以后点左边的Aview旁边的+号,在下一级选项里选择prefencens,出现的右边第一个就是内存大小了,把value修改为huge,左边的Asolver也同样将内存改为huge.然后重起机子就OK
发表于 2010-7-4 14:34:36 | 只看该作者
哦,明白了
发表于 2014-3-23 07:55:08 | 只看该作者
谢谢楼主分享!!!!
GMT+8, 2025-4-10 17:09 , Processed in 0.111390 second(s), 13 queries , Gzip On, Redis On.
