查看: 21748|回复: 13
[求助] 一启动注册文件 proe就自动退出
发表于 2009-3-23 11:13:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我想添加一个菜单栏“拉深模设计” 和一个菜单栏按钮“筒形件拉深模具设计”
DLL文件已经在VC中成功组建  信息文件和注册文件(PRODD.DAT)也写好了
但是在proe里注册PRODD.DAT以后,一点启动PROE就自动退出了
下面是CPP文件及信息文件和注册文件内容,高手们给看看是怎么回事啊,谢谢!
// PRODD.cpp : Defines the initialization routines for the DLL.
#include "stdafx.h"
#include "PRODD.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
#include"ProMenu.h"
#include"ProUtil.h"
#include"ProMenubar.h"
// Note!
//  If this DLL is dynamically linked against the MFC
//  DLLs, any functions exported from this DLL which
//  call into MFC must have the AFX_MANAGE_STATE macro
//  added at the very beginning of the function.
//  For example:
//  extern "C" BOOL PASCAL EXPORT ExportedFunction()
//   AFX_MANAGE_STATE(AfxGetStaticModuleState());
//   // normal function body here
//  It is very important that this macro appear in each
//  function, prior to any calls into MFC.  This means that
//  it must appear as the first statement within the
//  function, even before any object variable declarations
//  as their constructors may generate calls into the MFC
//  DLL.
//  Please see MFC Technical Notes 33 and 58 for additional
//  details.
// CPRODDApp
BEGIN_MESSAGE_MAP(CPRODDApp, CWinApp)
//{{AFX_MSG_MAP(CPRODDApp)
  // NOTE - the ClassWizard will add and remove mapping macros here.
  //    DO NOT EDIT what you see in these blocks of generated code!
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CPRODDApp construction
CPRODDApp::CPRODDApp()
// TODO: add construction code here,
// Place all significant initialization in InitInstance
// The one and only CPRODDApp object
CPRODDApp theApp;
extern "C" int user_initialize()
    ProError status;
ProFileName MsgFile;
    uiCmdCmdId   PushButton_cmd_id1;
ProStringToWstring(MsgFile, "PRODD.txt");//设置菜单信息文件名
     添加菜单条
status=ProMenubarMenuAdd ("PRODD", "拉深模设计",
                        "Utilities", PRO_B_TRUE, MsgFile);
     菜单按钮设置
//设置菜单按钮的动作函数(例8-1)
    //添加菜单按钮
ProMenubarmenuPushbuttonAdd("PRODD", "bddCAD", "筒形件拉深模具设计",
             "筒形件拉深模具设计", NULL,
           PRO_B_TRUE, PushButton_cmd_id1, MsgFile);
return status;
FUNCTION: user_terminate()
extern "C" void user_terminate()
信息文件PRODD.TXT:
拉深模设计
PRODD
拉深模设计
筒形件拉深模具设计
bdcad
筒形件拉深模具设计
筒形件拉深模具设计
bdcad
筒形件拉深模具设计
注册文件:
NAME       PRODD
EXEC_FILE  E:\document\PROE二次开发\PRODD\Release\PRODD.dll
TEXT_DIR   E:\document\PROE二次开发\PRODD\Release\text
STARTUP    dll
ALLOW_STOP TRUE
DELAY_START TRUE
REVISION   2002
END
发表于 2009-3-23 14:16:26 | 只看该作者
//设置菜单按钮的动作函数(例8-1)
<这里应该有代码>
//添加菜单按钮.
发表于 2009-3-24 10:32:35 | 只看该作者
2# Easy2009
对 应该是有代码
我刚才加上了
结果还是自动退出  哎  不知道哪里的问题
新的CPP文件添加到附件了
高手帮忙再看看
发表于 2009-3-24 10:37:07 | 只看该作者
按钮的label 和帮助的label不能相同,否则系统无法区分该选用哪个。
发表于 2009-3-24 16:49:54 | 只看该作者
4# 5I3D
真是太谢谢您了
问题果然就是在这里,改了,成功启动
太感谢了
发表于 2009-3-26 20:04:05 | 只看该作者
不客气,共同进步嘛。
发表于 2009-4-19 11:19:46 | 只看该作者
bu dong
发表于 2009-5-14 08:07:39 | 只看该作者
我也来学习一下,好东东
发表于 2009-5-17 11:15:36 | 只看该作者
学习了,haodongdong
发表于 2009-7-17 10:07:58 | 只看该作者
1# LIRUI616
我也遇到了类似的问题,但是我菜单按钮的动作函数我也加了,按钮的label 和帮助的label也不相同,但是已注册还是自动退出,就是不知到问题在哪
GMT+8, 2025-7-11 11:34 , Processed in 0.030218 second(s), 12 queries , Gzip On, Redis On.
