[求助] 流水号刻印宏程序编制
发表于 2016-8-17 09:08:01 | 只看该作者
贴个可以刻0~99的,这个是写进(CREO)后处理的,所以没有旋转和比例缩放s
要刻多位只要改下就可以了
O1100
G90 G80 G49 G40 G98 G94
( / TOOL_TYPE : BASIC DRILL)
G91 G28 Z0.0
M00
T71 ( SDR-6-90-KZ )
T071 M06
M01
S10000 M03
M300 Q1
G5.1 Q1
G90 G00 G54 X0.0 Y0.0
M08
G00 G43 Z45. H71
G65 P8000 X50. Y-20. I7.7 J0. A1.
G00 Z45.
M09
G80
M05
G91 G28 Z0.0
G5.1 Q0
M30
O8000
IF[#600 EQ 1.]THEN #601=1.
IF[#600 EQ 1.]THEN #602=1.
IF[#600 EQ 1.]THEN #610=#1
#600=10.
IF[#610 GE 100.]GOTO999
IF[#610 LE 0.]GOTO999
#611=FIX[#610/10.]
#612=#610-#611*10.
#624=#24
#625=#25
N100
#630=1.
IF[#611 EQ 0.]GOTO 10
GOTO#611
N200
#630=2.
IF[#612 EQ 0.]GOTO 10
GOTO#612
N1
IF[#630 EQ 2.]THEN #624=#624+#4
IF[#630 EQ 2.]THEN #625=#625+#5
G52 X#624  Y#625
G00 Z45.
X3.12 Y12.
Z2.15
G01 Z-.15 F100.
Y0. F1200.
G00 Z45.
Y12.
Z1.7
G01 Z-.3 F100.
Y0. F1200.
G00 Z45.
G52X0. Y0.
IF[#630 EQ 2.]THEN GOTO1111
GOTO200
N2
G52 X#624  Y#625
G00 Z45.
Z2.15
G01 X3.12 Y0. Z-.15 F100.
X0. F1200.
X.39 Y3.
X1.17 Y5.
X2.73 Y7.
X3.12 Y8.
Y10.
X2.73 Y11.
X1.95 Y12.
X1.17
X.39 Y11.
X0. Y10.
G00 Z45.
X3.12 Y0.
Z1.7
G01 Z-.3 F100.
X0. F1200.
X.39 Y3.
X1.17 Y5.
X2.73 Y7.
X3.12 Y8.
Y10.
X2.73 Y11.
X1.95 Y12.
X1.17
X.39 Y11.
X0. Y10.
G00 Z45.
G52X0. Y0.
GOTO200
N3
G52 X#624  Y#625
G00 Z45.
X0. Y2.
Z2.15
G01 Z-.15 F100.
X.39 Y1. F1200.
X1.17 Y0.
X1.95
X2.73 Y1.
X3.51 Y3.
Y4.
X2.73 Y6.
X1.95 Y7.
X2.73 Y8.
X3.12 Y9.
Y10.
X2.73 Y11.
X1.95 Y12.
X1.17
X.39 Y11.
G00 Z45.
X0. Y2.
Z1.7
G01 Z-.3 F100.
X.39 Y1. F1200.
X1.17 Y0.
X1.95
X2.73 Y1.
X3.51 Y3.
Y4.
X2.73 Y6.
X1.95 Y7.
X2.73 Y8.
X3.12 Y9.
Y10.
X2.73 Y11.
X1.95 Y12.
X1.17
X.39 Y11.
G00 Z45.
X1.17 Y7.
Z1.85
G01 Z-.15 F100.
X1.95 F1200.
G00 Z45.
X1.17
Z1.7
G01 Z-.3 F100.
X1.95 F1200.
G00 Z45.
G52X0. Y0.
GOTO200
N4
G52 X#624  Y#625
G00 Z45.
X2.73 Y0.
Z2.15
G01 Z-.15 F100.
Y12. F1200.
X0. Y3.
X3.51
G00 Z45.
X2.73 Y0.
Z1.7
G01 Z-.3 F100.
Y12. F1200.
X0. Y3.
X3.51
G00 Z45.
G52X0. Y0.
GOTO200
N5
G52 X#624  Y#625
G00 Z45.
X3.12 Y12.
Z2.15
G01 Z-.15 F100.
X.78 F1200.
X.39 Y7.
X1.17 Y8.
X1.95
X2.73 Y7.
X3.12 Y6.
X3.51 Y4.
X3.12 Y2.
X2.73 Y1.
X1.95 Y0.
X1.17
X.39 Y1.
X0. Y2.
G00 Z45.
X3.12 Y12.
Z1.7
G01 Z-.3 F100.
X.78 F1200.
X.39 Y7.
X1.17 Y8.
X1.95
X2.73 Y7.
X3.12 Y6.
X3.51 Y4.
X3.12 Y2.
X2.73 Y1.
X1.95 Y0.
X1.17
X.39 Y1.
X0. Y2.
G00 Z45.
G52X0. Y0.
GOTO200
N6
G52 X#624  Y#625
G00 Z45.
X0. Y4.
Z2.15
G01 Z-.15 F100.
X.39 Y6. F1200.
X1.56 Y7.
X2.73 Y6.
X3.12 Y4.
X2.73 Y2.
X2.34 Y1.
X1.56 Y0.
X.78 Y1.
X.39 Y2.
X0. Y4.
Y8.
X.39 Y10.
X.78 Y11.
X1.56 Y12.
X2.34 Y11.
X2.73 Y10.
G00 Z45.
X0. Y4.
Z1.7
G01 Z-.3 F100.
X.39 Y6. F1200.
X1.56 Y7.
X2.73 Y6.
X3.12 Y4.
X2.73 Y2.
X2.34 Y1.
X1.56 Y0.
X.78 Y1.
X.39 Y2.
X0. Y4.
Y8.
X.39 Y10.
X.78 Y11.
X1.56 Y12.
X2.34 Y11.
X2.73 Y10.
G00 Z45.
G52X0. Y0.
GOTO200
N7
G52 X#624  Y#625
G00 Z45.
X1.56 Y0.
Z2.15
G01 Z-.15 F100.
X1.95 Y5. F1200.
X2.34 Y8.
X3.12 Y12.
X0.
G00 Z45.
X1.56 Y0.
Z1.7
G01 Z-.3 F100.
X1.95 Y5. F1200.
X2.34 Y8.
X3.12 Y12.
X0.
G00 Z45.
G52X0. Y0.
GOTO200
N8
G52 X#624  Y#625
G00 Z45.
X1.56 Y0.
Z2.15
G01 Z-.15 F100.
X2.34 F1200.
X3.12 Y1.
X3.9 Y3.
Y4.
X3.12 Y6.
X2.34 Y7.
X1.56
X.78 Y6.
X0. Y4.
Y3.
X.78 Y1.
X1.56 Y0.
Z-.3
X2.34
X3.12 Y1.
X3.9 Y3.
Y4.
X3.12 Y6.
X2.34 Y7.
X1.56
X.78 Y6.
X0. Y4.
Y3.
X.78 Y1.
X1.56 Y0.
G00 Z45.
Y7.
Z1.85
G01 Z-.15 F100.
X.78 Y8. F1200.
X.39 Y9.
Y10.
X.78 Y11.
X1.56 Y12.
X2.34
X3.12 Y11.
X3.51 Y10.
Y9.
X3.12 Y8.
X2.34 Y7.
G00 Z45.
X1.56
Z1.7
G01 Z-.3 F100.
X.78 Y8. F1200.
X.39 Y9.
Y10.
X.78 Y11.
X1.56 Y12.
X2.34
X3.12 Y11.
X3.51 Y10.
Y9.
X3.12 Y8.
X2.34 Y7.
G00 Z45.
G52X0. Y0.
GOTO200
N9
G52 X#624  Y#625
G00 Z45.
X3.12 Y8.
Z2.15
G01 Z-.15 F100.
X2.73 Y6. F1200.
X1.56 Y5.
X.39 Y6.
X0. Y8.
X.39 Y10.
X.78 Y11.
X1.56 Y12.
X2.34 Y11.
X2.73 Y10.
X3.12 Y8.
Y4.
X2.73 Y2.
X2.34 Y1.
X1.56 Y0.
X.78 Y1.
X.39 Y2.
G00 Z45.
X3.12 Y8.
Z1.7
G01 Z-.3 F100.
X2.73 Y6. F1200.
X1.56 Y5.
X.39 Y6.
X0. Y8.
X.39 Y10.
X.78 Y11.
X1.56 Y12.
X2.34 Y11.
X2.73 Y10.
X3.12 Y8.
Y4.
X2.73 Y2.
X2.34 Y1.
X1.56 Y0.
X.78 Y1.
X.39 Y2.
G00 Z45.
G52X0. Y0.
GOTO200
N10
G52 X#624  Y#625
G00 Z45.
X1.56 Y0.
Z2.15
G01 Z-.15 F100.
X2.34 Y1. F1200.
X2.73 Y2.
X3.12 Y4.
Y8.
X2.73 Y10.
X2.34 Y11.
X1.56 Y12.
X.78 Y11.
X.39 Y10.
X0. Y8.
Y4.
X.39 Y2.
X.78 Y1.
X1.56 Y0.
Z-.3
X2.34 Y1.
X2.73 Y2.
X3.12 Y4.
Y8.
X2.73 Y10.
X2.34 Y11.
X1.56 Y12.
X.78 Y11.
X.39 Y10.
X0. Y8.
Y4.
X.39 Y2.
X.78 Y1.
X1.56 Y0.
G00 Z45.
G52X0. Y0.
GOTO200
N1111
#601=#601+1.
IF[#601 GT #602]THEN #610=#610+1.
IF[#601 GT #602]THEN #601=1.
G00 G90 Z45.
N999
M99
32
发表于 2016-8-17 09:11:14 | 只看该作者
刻字宏程序使用方法和注意事项
1. 此刻字程序分为两部分,一为主程序二为宏程序子程序,主程序为手动输入【特别要注意坐标是否统一】,子程序为后处理出程序
(1)           主程序部分下面为例子
首次读取主程序需要把#600改为1.,才能读取A_后面数值,否知无法读取
T71 ( SDR-6-90-KZ )
T071 M06
M01
S10000 M03
M300 Q1
G5.1 Q1
M08
G00 G43 Z45. H71
G00 Z45.
M09
G80
M05
G91 G28 Z0.0
G5.1 Q0
M30
其中主要部分为G65 P8000 X50. Y-20. I7.7 J0. A1.
G65为调用宏程序
P8000 为宏程序程序名
X50. 为刻字原点到工件原点X方向之间的距离(需要在图档内测量)
Y-20. 为刻字原点到工件原点X方向之间的距离(需要在图档内测量)
I7.7 为两个字X方向之间的间距(需要在图档内测量或根据实际情况修改)
J0.  为两个字Y方向之间的间距(需要在图档内测量或根据实际情况修改)
A1.  为从第几个数字开始刻字
(2)子程序部分下面为例子
O8000
IF[#600 EQ 1.]THEN #601=1. (#601为刻字开始计数为1)
IF[#600 EQ 1.]THEN #602=1.  (#602同一个数字加工1次,可根据实际需要修改)
IF[#600 EQ 1.]THEN #610=#1   (读取主程序中A_后面的数值)
#600=10.        (这里增加的开关,主程序中A_读取必须把#600改为=1.)
IF[#610 GE 100.]GOTO999     (判断刻字数值是否大于100,大于程序结束)
IF[#610 LE 0.]GOTO999        (判断刻字数值是否小于0,大于程序结束)
33
发表于 2016-10-9 09:33:24 | 只看该作者
我是来学习的
34
发表于 2016-11-9 14:16:43 | 只看该作者
买台刻字机不就行了,不贵的,又方便
35
发表于 2016-12-4 22:00:23 | 只看该作者
宏程式博大精深呀
36
发表于 2016-12-5 11:10:58 | 只看该作者
学习学习
37
发表于 2016-12-5 11:14:24 | 只看该作者
学习学习
38
发表于 2016-12-5 11:15:08 | 只看该作者
学习学习
39
发表于 2018-6-27 21:34:36 | 只看该作者
学习学习,,没用过宏程序,希望有人指教指教!!谢谢
GMT+8, 2025-4-19 01:19 , Processed in 0.023394 second(s), 10 queries , Gzip On, Redis On.
