objlib.mnu內容 | |
file:///C:/Documents%20and%20Settings/Administrator/桌面/lwj/1/ProE_files/5.gif | BASIC#LIB # # /featurelib Commonly used engineering user-defined features. # /eng_part_lib Fasteners and standard parts - ANSI standards. # /metriclib Metric standard fasteners and parts-ANSI standard. # /isofastlib Fasteners and standard parts - ISO standards. # /jisfastlib Fasteners and standard parts - JIS standards. # |
metriclib.mnu內容 | |
file:///C:/Documents%20and%20Settings/Administrator/桌面/lwj/1/ProE_files/6.gif | PART/FASTENER ANSI/ASME and SAE Standards. # /aerospace_fast Metric Bolts, Screws and Nuts -External Wrenching -SAE MA 1518. # /hex_nuts Metric Hex Nuts. -(ANSI) # /hex_scr_bolt Metric Hex Screws and Bolts. -(ANSI) # /mach_scr Metric Machine Screws -ANSI/ASME B18.6.7M-1985. # /retain_rings General Purpose Tapered and Reduced Cross Section Retaining Rings. -(ANSI) # /rivets Metric Small Solid and Semi-Tubular Rivets. -(ANSI) # /rnd_head_bolts Metric Round Head Bolts - ANSI/ASME B18.5.2.2M-1982 and ANSI B18.5.2.1M-1981 # /sock_hd_scr Metric Socket Head Screws. -(ANSI) # /t_nut_bolt Metric T-bolts and T-nuts - ANSI/ASME B5.1M-1985. # /tapping_scr Metric Thread Forming and Thread Cutting Tapping Screws-ANSI/ASME B18.6.5M-1981. # /washers Metric Plain Washers -ANSI B18.22M-1984. # |
hex_scr_bolt.mnu內容 | |
file:///C:/Documents%20and%20Settings/Administrator/桌面/lwj/1/ProE_files/7.gif | HEX#SCREW&BOLT # # mhcs.prt Metric Hex Cap Screws -ANSI B18.2.3.1M-1979(1989). # mfhs.prt Metric Formed Hex Screws -ANSI B18.2.3.2M-1979(1989). # mhhs.prt Metric Heavy Hex Screws -ANSI B18.2.3.3M-1979(1989). # mhfs.prt Metric Hex Flange Screws -ANSI/ASME B18.2.3.4M-1984. # mhb.prt Metric Hex Bolts -ANSI B18.2.3.5M-1979(1989). # mhhb.prt Metric Heavy Hex Bolts -ANSI B18.2.3.6M-1979(1989). # mhsb.prt Metric Heavy Hex Structural Bolts -ANSI B18.2.3.7M-1979(1989). # mhls.prt Metric Hex Lag Screws -ANSI B18.2.3.8M-1981 # mhhf.prt Metric Heavy Hex Flange Screws -ANSI/ASME B18.2.3.9M-1984. # |
NAME | NOM. DIA. & THREAD PITCH | WRENCH DASH NO. | D THD DIA. | E1 FLANGE DIA. | F BEARING DIA. | G HEAD TOP DIA. | SHANK DIA. | L LENGTHS |
[url=]MASB01 | 4X0.7 | 06 | 4.00 | 8.30 | 7.50 | 6.00 | 4.00 | 18 to 56 by 2 |
MASB02 | 5X0.8 | 07 | 5.00 | 9.10 | 8.30 | 7.00 | 5.00 | 20 to 60 by 2, 64, 68 |
MASB03 | 6X1.0 | 08 | 6.00 | 10.60 | 9.80 | 8.00 | 6.00 | 22 to 58 by 2, 60 to 84 by 4 |
MASB04 | 7X1.0 | 09 | 7.00 | 12.10 | 11.30 | 9.00 | 7.00 | 24 to 58 by 2, 60 to 96 by 4 |
MASB05 | 8X1.0 | 10 | 8.00 | 13.60 | 12.80 | 10.00 | 8.00 | 26 to 58 by 2, 60 to 140 by 4 |
MASB06 | 10X1.25 | 12 | 10.00 | 16.70 | 15.70 | 12.00 | 10.00 | 32 to 58 by 2, 60 to 140 by 4 |
MASB07 | 12X1.25 | 14 | 12.00 | 19.90 | 18.80 | 14.00 | 12.00 | 36 to 58 by 2, 60 to 168 by 4 |
AREO FASTENER | ||||
Castellated Nuts | Hexagon Head Bolts | Plain Hexagon Nuts | Spline Wrenched Bolts | Spline Drive Nuts |
HEX NUTS | |||||
HEX Flange Nuts | Heavy Hex Nuts | Hex Jam Nuts | Hex Nuts,Style 1 | Hex Nuts,Style 2 | Slotted Hex Nuts |
欢迎光临 iCAx开思网 (https://www.icax.org/) | Powered by Discuz! X3.3 |
