返回列表 发新帖
【求助】如何快速删除多条重复的线条
发表于 2002-7-2 15:19:03 | 只看该作者
经坛主首肯..,公布源码让大家学习.
(defun deldup_error (s)
    (if (/= s "功能取消")
        (princ (strcat "\n错误: " s))
    (setq *error* old_error)
    (princ)
(defun help_dialog ()
    (if (setq help_file (findfile "deldup.hlp"))
        (progn (setq dia_id (load_dialog "deldub.dcl")
                     help_file (open help_file "r")
                     help_lijst (cons (read-line help_file) help_lijst)
               (new_dialog "help" dia_id)
               (while (setq help_regel (read-line help_file))
                      (setq help_lijst (cons help_regel help_lijst))
               (setq help_file (close help_file)
                     help_lijst (reverse help_lijst)
                     help_regel nil
               (start_list "help_lijst")
               (mapcar 'add_list help_lijst)
               (end_list)
               (setq help_lijst nil)
               (start_dialog)
        (alert "文件不完整!")
(defun line ()
    (while (> (sslength alles) 1)          (setq n 1
                 ent (entget (ssname alles 0))
                 b (cdr (assoc 10 ent))
                 e (cdr (assoc 11 ent))
                 leng (sslength alles)
           (repeat (- leng 1)
                   (setq nent (entget (ssname alles n))
                         nb (cdr (assoc 10 nent))
                         ne (cdr (assoc 11 nent))
                   (if (and (or (equal b nb deldub_tol)
                                (equal b ne deldub_tol)
                            (or (equal e nb deldub_tol)
                                (equal e ne deldub_tol)
                       (progn (ssadd (cdr (car nent)) wis_set)
                              (redraw (cdr (car nent)) 3)
                       (setq n (1+ n))
           (ssdel (cdr (car ent)) alles)
(defun arc ()
           (setq n 1
                 cen (cdr (assoc 10 ent))
                 rad (cdr (assoc 40 ent))
                 beg (cdr (assoc 50 ent))
                 ein (cdr (assoc 51 ent))
           (repeat (- leng 1)
                         ncen (cdr (assoc 10 nent))                        nrad (cdr (assoc 40 nent))
                         nbeg (cdr (assoc 50 nent))
                         nein (cdr (assoc 51 nent))
                   (if (and (equal cen ncen deldub_tol)
                            (equal rad nrad deldub_tol)
                            (or (equal beg nbeg deldub_tol)
                                (equal beg nein deldub_tol)
                            (or (equal ein nbeg deldub_tol)
                                (equal ein nein deldub_tol)
                       (setq n (1+ n))
(defun circle ()
           (setq n 1
                 ent (entget (ssname alles 0))                cen (cdr (assoc 10 ent))
           (repeat (- leng 1)
                   (if (and (equal cen xncen deldub_tol)
                       (setq n (1+ n))
(defun text ()
           (setq n 1
                 t (cdr (assoc 1 ent))
                 s (cdr (assoc 7 ent))
                 i (cdr (assoc 10 ent))
                 h (cdr (assoc 40 ent))
                 b (cdr (assoc 41 ent))
                 r (cdr (assoc 50 ent))
                 o (cdr (assoc 51 ent))
           (repeat (- leng 1)
                         nt (cdr (assoc 1 nent))
                         ns (cdr (assoc 7 nent))
                         ni (cdr (assoc 10 nent))
                         nh (cdr (assoc 40 nent))
                         nb (cdr (assoc 41 nent))
                         nr (cdr (assoc 50 nent))
                         no (cdr (assoc 51 nent))
                   (if (and (= t nt)
                            (= s ns)
                            (equal i ni deldub_tol)
                            (equal h nh deldub_tol)
                            (equal r nr deldub_tol)
                            (equal o no deldub_tol)
                       (setq n (1+ n))
(defun zoeken ()
    (princ "\r正在搜索 ")
    (princ teller)
    (cond ((= soort "LINE")
           (line)
          ((= soort "ARC")
           (arc)
          ((= soort "CIRCLE")
           (circle)
          ((= soort "TEXT")
           (text)
    (setq gewist (+ gewist (sslength wis_set)))
    (command "erase" wis_set "")
(defun verzamelen ()
    (setq alles (ssget "C" pt3 pt4 (list (cons 0 soort)))
          teller (1+ teller)
          wis_set (ssadd)
    (if alles
        (zoeken)
        (progn (princ "\r正在搜索 ")
               (princ teller)
    (rechthoek)
(defun rechthoek ()
    (setq vlist (list 256 pt3 (list (car pt4)(cadr pt3))
                      256 (list (car pt4)(cadr pt3)) pt4
                      256 pt4 (list (car pt3)(cadr pt4))
                      256 (list (car pt3)(cadr pt4)) pt3
    (grvecs vlist)
(defun deldup ()
    (if (= soort "TEXT")
        (setq deel (1+ (fix (/ (sslength alles) 100))))
    (setq teller 0
          gewist 0
          hoek (angle pt1 pt2)
          diag (/ (distance pt1 pt2) deel)
          ydir (angle pt1 (list (car pt1)(cadr pt2)))
          ylen (/ (distance pt1 (list (car pt1)(cadr pt2))) deel)
          pt3 pt1
          pt4 (polar pt3 hoek (* deel diag))
    (rechthoek)
    (prompt (strcat "\r分割域" (itoa (* deel deel)) "部分, 正在搜索...\n"))
    (repeat deel
            (setq pt4 (polar pt3 hoek diag))
            (rechthoek)
            (verzamelen)
            (repeat (- deel 1)
                    (setq pt3 (polar pt4 (- ydir pi) ylen)
                    (rechthoek)
                    (verzamelen)
            (setq pt3 (polar pt1 ydir ylen)
                  pt1 pt3
    (redraw)
    (prompt (strcat "\r共删除" (itoa gewist) "个重复" soort))
(defun tel ()
;   (prompt (strcat "\n窗选包含重复 " soort "的面域."))
    (setq pt1 (getpoint "\n第一点: ")
          pt2 (getcorner pt1 "\r对角点: ")
;         alles (ssget "C" pt1 pt2 (list (cons 0 soort)))
    (SETQ ALLES (SSGET "X" (LIST (CONS 0 "LINE"))))
    (if alles
        (deldup)
        (alert (strcat "找不到" soort "."))
(defun deldup_dialog ()
    (setq dia_id (load_dialog "deldup")
          soort "LINE"
    (if (not (new_dialog "deldup" dia_id))
        (alert (strcat "I can't find the file \"DELDUP.DCL\"."
                       "\nI can only search for duplicate \"LINE\"."
        (progn (set_tile "tole" (rtos deldub_tol 2 5))
               (start_dialog)
(defun c:deldup ()
    (setvar "cmdecho" 0)
    (alert "本程序由HTTP://idesign2002.com提供!")
    (setq old_error *error*         *error* deldup_error
    (if (= deldub_tol nil)
        (setq deldub_tol 0.0)
    (deldup_dialog)
    (if soort
        (tel)
    (princ)
(defun c:dp()
    (c:deldup)
);end
GMT+8, 2025-1-22 21:06 , Processed in 0.020005 second(s), 9 queries , Gzip On, Redis On.
