[求助] CAD自动标注
发表于 2009-10-11 23:27:48 | 只看该作者
我也想要个零件自动标注~~~冲模的~~
发表于 2009-10-30 19:17:01 | 只看该作者
我本来是来索取的
百来了哦
发表于 2009-12-17 19:48:22 | 只看该作者
这个有点难
发表于 2009-12-26 11:58:14 | 只看该作者
(defun ss_ssxx ()
  (setq        ssx nil
        ssy nil
        ssoo nil
        po-check-multy
        po-check-multx
        po-check-multo
  (if ss
    (progn
      (setq i (sslength ss))
      (while (> i 0)
        (setq i (- i 1))
        (setq ee (ssname ss i))
        (setq e (entget ee))
        (setq p10 (cdr (assoc 10 e)))
        (setq p11 (cdr (assoc 11 e)))
        (cond
          ((< (abs (- (nth 0 p10) (nth 0 p11))) 0.0001)
           (if (not (member (nth 0 p10) po-check-multy))
             (setq po-check-multy
                                   (append (list (nth 0 p10)) po-check-multy)
                   po-check-multy1 po-check-multy
           (if (= n5-value "1")
             (progn
               (if
                 (or
                   (< (abs (rem (- (nth 0 p10) (nth 0 cen)) 5.0)) 0.001)
                     (abs (- (abs (rem (- (nth 0 p10) (nth 0 cen)) 5.0))
                             5.0
                     0.001
                  (if (null ssy)
                    (setq ssy (ssadd ee))
                    (setq ssy (ssadd ee ssy))
             (progn
               (if (null ssy)
          ((< (abs (- (nth 1 p10) (nth 1 p11))) 0.0001)
           (if (not (member (nth 1 p10) po-check-multx))
             (setq po-check-multx
                                   (append (list (nth 1 p10)) po-check-multx)
                   po-check-multx1 po-check-multx
             (progn
               (if
                 (or
                   (< (abs (rem (- (nth 1 p10) (nth 1 cen)) 5.0)) 0.001)
                     (abs (- (abs (rem (- (nth 1 p10) (nth 1 cen)) 5.0))
                             5.0
                     0.001
                  (if (null ssx)
                    (setq ssx (ssadd ee))
                    (setq ssx (ssadd ee ssx))
             (progn
               (if (null ssx)
  (if sso
    (progn
      (setq i (sslength sso))
      (while (> i 0)
        (setq i (- i 1))
        (setq ee (ssname sso i))
        (if (not (member p10 po-check-multo))
          (setq        po-check-multo
                 (append (list p10) po-check-multo)
          (progn
            (if
              (or
                  (abs
                    (- (abs (rem (- (nth 0 p10) (nth 0 cen)) 5.0)) 5.0)
                  0.001
               (if (null ssoo)
                 (setq ssoo (ssadd ee))
                 (setq ssoo (ssadd ee ssoo))
          (progn
            (if        (null ssoo)
(defun draw_ssx        (/ cen1)
  (setq i (sslength ssx))
  (while (> i 0)
    (setq i (- i 1))
    (setq ee (ssname ssx i))
    (if        (= mult-ad-value "0")
        (setq p10 nil
              p11 nil
               (vl-remove (nth 1 p10) po-check-multx)
    (if        (and p10 p11)
      (progn
        (if (> (nth 0 p10) (nth 0 p11))
          (setq        pd p10
                px p11
          (setq        pd p11
                px p10
        (setq
          pd (list (- (nth 0 pd) (nth 0 cen))
                   (- (nth 1 pd) (nth 1 cen))
        (setq
          px (list (- (nth 0 px) (nth 0 cen))
                   (- (nth 1 px) (nth 1 cen))
        (setq cen1 (list 0 0))
        (if (< (abs (nth 1 pd)) 0.0001)
          (progn
            (setq j (atoi check-inters-len1-value))
            (while (< j (atoi check-inters-len-value))
              (setq pp (polar pd 0 (* a j (getvar "DIMTXT"))))
              (if
                (ssget "C" pp (polar pp 0 (* a (getvar "DIMTXT") 2.0)))
                 (setq j (+ j (atoi check-inters-len1-value)))
                 (setq j (atoi check-inters-len-value))
            (vl-cmdf "_.dimordinate" pd pp)
             (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                  "尺寸图层:" (nth 9 lcad_set_layer_list)
                         "\n"
                  "尺寸样式:" (getvar "DIMSTYLE")
            (prompt ".")
          (set-description (entlast) linkstr " ")
            (if        (null ss1)
              (setq ss1 (ssadd (entlast)))
              (setq ss1 (ssadd (entlast) ss1))
              (setq pp (polar px pi (* a j (getvar "DIMTXT"))))
              (if
                (ssget "c" pp (polar pp pi (* a (getvar "DIMTXT") 2.0)))
            (vl-cmdf "dimordinate" px pp)
            (prompt ".")
            (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
            (if        (null ss1)
          (progn
            (if        (> (- (distance px cen1) (distance pd cen1)) 0.0001)
              (progn
                  (if (ssget "c"
                             pp
                (prompt ".")
                (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
                (if (null ss1)
              (progn
                  (if (ssget "c"
                             pp
                (vl-cmdf "dimordinate" pd pp)
                (prompt ".")
                (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
                (if (null ss1)
(defun draw_ssy        (/ cen1)
  (setq i (sslength ssy))
  (while (> i 0)
    (setq i (- i 1))
    (setq ee (ssname ssy i))
        (setq p10 nil
              p11 nil
               (vl-remove (nth 0 p10) po-check-multy)
    (if        (and p10 p11)
      (progn
        (if (> (nth 1 p10) (nth 1 p11))
          (setq        pd p10
                px p11
          (setq        pd p11
                px p10
        (setq
        (setq
        (if (< (abs (nth 0 pd)) 0.0001)
          (progn
              (setq pp (polar pd (* pi 0.5) (* a j (getvar "DIMTXT"))))
              (if
                (ssget "c"
                       pp
                       (polar pp (* pi 0.5) (* a (getvar "DIMTXT") 2.0))
            (prompt ".")
            (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
            (if        (null ss1)
              (setq pp (polar px (* pi 1.5) (* a j (getvar "DIMTXT"))))
              (if
                (ssget "c"
                       pp
                       (polar pp (* pi 1.5) (* a (getvar "DIMTXT") 2.0))
            (prompt ".")
            (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
            (if        (null ss1)
          (progn
              (progn
                  (setq
                  (if
                    (ssget
                      "c"
                      pp
                (prompt ".")
                (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
                (if (null ss1)
              (progn
                  (setq
                  (if
                    (ssget
                      "c"
                      pp
                (prompt ".")
                (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
                (if (null ss1)
(defun draw_ssoo (/ cen1)
  (setq i (sslength ssoo))
  (while (> i 0)
    (setq i (- i 1))
    (setq ee (ssname ssoo i))
    (setq p11 p10)
      (progn
        (if (member p10 po-check-multo)
          (setq po-check-multo (vl-remove p10 po-check-multo))
          (setq        p10 nil
                p11 nil
        (if p10
          (if (member (nth 0 p10) po-check-multy1)
            (setq p10 nil)
        (if p11
          (if (member (nth 1 p11) po-check-multx1)
            (setq p11 nil)
    (if        (or p10 p11)
      (progn
        (if p10
          (setq pd p10)
        (if p11
          (setq pd p11)
        (setq
        (if (< (nth 0 pd) 0.0001)
          (progn
              (setq pp (polar pd pi (* a j (getvar "DIMTXT"))))
              (if
                (ssget "C" pp (polar pp pi (* a (getvar "DIMTXT") 2.0)))
            (prompt ".")
            (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
            (if        (null ss1)
          (progn
              (if
            (prompt ".")
            (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
            (if        (null ss1)
        (if (> (nth 1 pd) 0.0001)
          (progn
              (if
                (ssget "C"
                       pp
            (prompt ".")
            (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
            (if        (null ss1)
          (progn
              (setq pp (polar pd (* pi 1.5) (* a j (getvar "DIMTXT"))))
              (if
                (ssget "C"
                       pp
            (prompt ".")
            (setq linkstr
                 (strcat "LCAD命令:AD"
                         "\n"
                         "\n"
            (if        (null ss1)
(defun set_adim_la ()
  (if sel_la_n
    (if        (not (member (nth (atoi sel_la_n) adim_la_list) adim_la_add)
      (progn
        (setq adim_la_add
               (append (list (nth (atoi sel_la_n) adim_la_list))
                       adim_la_add
        (input_clb "adim-la" adim_la_add)
  (if (< (atoi sel_la_n) (- (length adim_la_list) 1))
    (progn
      (setq sel_la_n (itoa (+ (atoi sel_la_n) 1)))
      (set_tile "all-la" sel_la_n)
      (set_tile "adim-la" sel_la_n_r)
(defun remove_adim_la ()
  (if (and sel_la_n_r adim_la_add)
    (progn
      (setq adim_la_add
             (vl-remove        (nth (atoi sel_la_n_r) adim_la_add)
                        adim_la_add
  (if (> (atoi sel_la_n_r) 0)
    (progn
      (setq sel_la_n_r (itoa (- (atoi sel_la_n_r) 1)))
(defun get-sel-value ()
  $value
(defun get-sel-all-line-value ()
  (setq all-line-value $value)
  (cond        ((= all-line-value "0")
         (mode_tile "add-la" 0)
         (mode_tile "remove-la" 0)
         (mode_tile "all-la" 0)
         (mode_tile "adim-la" 0)
        ((= all-line-value "1")
         (mode_tile "add-la" 1)
         (mode_tile "remove-la" 1)
         (mode_tile "all-la" 1)
         (mode_tile "adim-la" 1)
         (setq adim-la-value nil
               adim_la_add   adim-la-value
         (input_clb "adim-la" adim-la-value)
(defun cancel-value ()
  (setq        userclick nil
         (get_tile "check-inters-len")
         (get_tile "check-inters-len1")
(defun accept-value ()
  (setq        userclick T
发表于 2009-12-26 11:58:25 | 只看该作者
(defun c:ad (/                  old               cen            ss
             ssx          ssy               ee            e
             i                  j               p10            p11
             a                  pd               px            pp
             oldla          xx               xxx            ss1
             dcl_id          adim_la_list make_la_name make_la_name1
             sel_la_n          key-add      adim_la_add  sel_la_n_r
             userclick          ssget-list   make-ssget-i corner-po1
             corner-po2          ssget-list1  ssget-list2  sso
             po-check-multy               po-check-multx
             po-check-multo               ssoo            po-check-multy1
             po-check-multx1               check-p10    old_adim_osmode
             old_adim_layer               aaa            b
             n                  nn               pcfill commandlist
      (grtext -1 "***LCAD 自动坐标尺寸标注***")
      (lcad-err-rec)
      (if (not (tblsearch "DIMSTYLE" "LCAD"))
        (c:cc)
       (if (= lcaddimscale 0)
              (progn
                (initget 7)
                (setq a (getreal "\n 尺寸标注比例不能=0! DIMSCALE="))
                (setvar "dimscale" a)
              (progn
                (setvar "dimscale" lcaddimscale)
                (setq a lcaddimscale)
      (setvar "osmode" 45)
      (setq adim_la_list '())
      (setq make_la_name (tblnext "LAYER" T))
      (while make_la_name
        (setq make_la_name1 (cdr (assoc 2 make_la_name)))
        (setq adim_la_list (append (list make_la_name1) adim_la_list))
        (setq make_la_name (tblnext "LAYER"))
      (setq adim_la_list (reverse adim_la_list))
      (setq dcl_id (load_dialog "adset.DCL"))
      (if (not (new_dialog "adimset" dcl_id))
        (exit)
      (setq key-add "adim-la"
            adim_la_add
            sel_la_n "0"
            sel_la_n_r
             "0"
      (input_clb "all-la" adim_la_list)
      (if adim-la-value
        (progn
          (setq adim_la_add adim-la-value)
      (if (null dot-value)
        (setq dot-value "0")
      (if (null xx-value)
        (setq xx-value "0")
      (if (null n5-value)
        (setq n5-value "1")
      (if (null mult-ad-value)
        (setq mult-ad-value "1")
      (if (null ins-po-value)
        (setq ins-po-value "0")
      (if (null circen-value)
        (setq circen-value "0")
      (if (null all-line-value)
        (setq all-line-value "1")
      (set_tile "dot" dot-value)
      (set_tile "xx" xx-value)
      (set_tile "circen" circen-value)
      (set_tile "mult-ad" mult-ad-value)
      (set_tile "n5" n5-value)
      (set_tile "all-line" all-line-value)
      (set_tile "ins-po" ins-po-value)
      (if (null check-inters-len-value)
        (set_tile "check-inters-len" "10")
        (set_tile "check-inters-len" check-inters-len-value)
      (if (null check-inters-len1-value)
        (set_tile "check-inters-len1" "1")
        (set_tile "check-inters-len1" check-inters-len1-value)
      (if (= all-line-value "1")
        (progn
      (mode_tile "xx" 1)
      (action_tile "all-la" "(setq sel_la_n $value)")
      (action_tile "add-la" "(set_adim_la)")
      (action_tile "adim-la" "(setq sel_la_n_r $value)")
      (action_tile "remove-la" "(remove_adim_la)")
      (action_tile "n5" "(setq n5-value (get-sel-value))")
      (action_tile "xx" "(setq xx-value (get-sel-value))")
      (action_tile "circen" "(setq circen-value (get-sel-value))")
      (action_tile "all-line" "(get-sel-all-line-value))")
      (action_tile "ins-po" "(setq ins-po-value (get-sel-value))")
      (action_tile "dot" "(setq dot-value (get-sel-value))")
      (action_tile
        "mult-ad"
        "(setq mult-ad-value (get-sel-value))"
      (action_tile "accept" "(accept-value) (done_dialog)")
      (action_tile "cancel" "(cancel-value)")
      (start_dialog)
      (cond
        ((= userclick T)
         (setvar "osmode" 0)
         (setq adim-la-value adim_la_add
               ssget-list    nil
         (setq corner-po1 (getpoint "\n选择标注范围:"))
         (if corner-po1
           (setq corner-po2 (getcorner corner-po1))
         (if (and (= all-line-value "0") (> (length adim-la-value) 0))
           (progn
             (setq make-ssget-i 0)
             (while (< make-ssget-i (length adim-la-value))
               (setq ssget-list1
                      (ssget
                        "c"
                        corner-po1
                        corner-po2
                        (list
                          (cons        8
                                (nth make-ssget-i adim-la-value)
                          (cons 0 "LINE")
               (if ssget-list1
                 (setq i (sslength ssget-list1))
                 (setq i 0)
               (while (> i 0)
                 (setq i (- i 1))
                 (if (null ssget-list)
                   (setq ssget-list (ssadd (ssname ssget-list1 i)))
                   (setq ssget-list
                                 ssget-list
               (setq make-ssget-i (+ make-ssget-i 1))
             (setq ss              ssget-list
                   ssget-list nil
         (if (and (= all-line-value "1") (= (length adim-la-value) 0))
           (setq ss (ssget "c" corner-po1 corner-po2 '((0 . "LINE"))))
         (if (= dot-value "1")
           (progn
             (setq ssget-list1
                    (ssget "c"
                           corner-po1
                           corner-po2
                           (list (cons 0 "POINT"))
             (if ssget-list1
               (setq i 0)
             (while (> i 0)
               (setq i (- i 1))
                 (setq ssget-list
                        (ssadd (ssname ssget-list1 i) ssget-list)
             (setq sso ssget-list)
         (if (= ins-po-value "1")
           (progn
             (setq ssget-list1
                    (ssget "c"
                           corner-po1
                           corner-po2
                           (list (cons 0 "INSERT"))
             (if ssget-list1
               (setq i 0)
             (while (> i 0)
               (setq i (- i 1))
                 (setq ssget-list
         (if (= circen-value "1")
           (progn
             (setq ssget-list1
                    (ssget "c"
                           corner-po1
                           corner-po2
                           (list (cons -4 "<OR")
                                 (cons 0 "CIRCLE")
                                 (cons 0 "ARC")
                                 (cons -4 "OR>")
             (if ssget-list1
               (setq i 0)
             (while (> i 0)
               (setq i (- i 1))
                 (setq ssget-list
        ((= userclick nil)
         (setq adim-la-value
                nil
               n5-value        "1"
               mult-ad-value
                "1"
               dot-value "0"
               xx-value        "0"
               ins-po-value
                "0"
               circen-value
                "0"
               all-line-value
                "1"
         (setvar "osmode" 0)
         (if corner-po1
      (setq cen (getpoint "\n 请选择原点:"))
      (if cen
        (progn
          (prompt "\n请稍等")
          (setvar "osmode" 0)
          (vl-cmdf "_.zoom"
                   "c"
                   cen
                   (abs (- (nth 1 corner-po1) (nth 1 corner-po2)))
          (vl-cmdf "_.ucs" "o" cen)
          (setq commandlist '())
          (if (or ss sso)
            (ss_ssxx)
          (if ssy
            (draw_ssy)
          (if ssx
            (draw_ssx)
          (if ssoo
            (draw_ssoo)
          (if ss1
            (vl-cmdf "_.change"
                     ss1
                     "p"
                     "la"
  (prompt "\n*LCAD 自动坐标标注完成*")
  (princ)
发表于 2009-12-26 11:58:43 | 只看该作者
adimset:dialog{
       label = "LCAD自动尺寸标注设置";
       :boxed_row{
       label = "选择自动标注设置";
          :list_box{
            label = "层列表";
            key = "all-la";
            width = 15;
            height = 15;
          :column{
             spacer;
             spacer;
            :button{
            label = ">>";
            key = "add-la";
           :button{
            label = "<<";
            key = "remove-la";
            spacer;
             spacer;
         :list_box{
            label = "自动标注层";
            key = "adim-la";
            width = 15;
            height = 15;
         :boxed_column{
             label = "其它选择";
             spacer;
             :toggle{
              label = "所有直线";
              key = "all-line";
            :toggle{
              label = "圆心";
              key = "circen";
           :toggle{
              label = "插入点";
              key = "ins-po";
           :toggle{
              label = "斜线";
              key = "xx";
            :toggle{
              label = "点";
              key = "dot";
            :toggle{
              label = "5 * n";
              key = "n5";
              value = 1;
            :toggle{
              label = "允许重复标注";
              key = "mult-ad";
              value = 1;
            :boxed_column{
              label = "判定干涉(N*L)";
            :row{
             :text{
              label = "步数N";
            :text{
              label = "*";
            :text{
              label = "步长L";
              :row{
            :edit_box{
              key = "check-inters-len";
              width = 2;
            :edit_box{
              key = "check-inters-len1";
              width = 2;
            spacer;
    :row{
    spacer;
    :button{
    label = "自定义设置标注";
    is_default = true;
    key = "accept";
    width = 6;
    fixed_width = true;
   : button {    // 定义“Cancel”按钮
    label = "默认设置标注";
    is_cancel = true;
    key = "cancel";
    width = 6;
    fixed_width = true;
  spacer;
发表于 2009-12-26 12:06:39 | 只看该作者
自己编的,使用中,可以自动判断尺寸和线条的干涉
坐标标注
18
发表于 2009-12-26 20:04:53 | 只看该作者
不错的思路,以前都没有想过这个问题.
19
发表于 2010-1-7 14:20:02 | 只看该作者
是所谓的坐标标注吗?
我有...
20
发表于 2010-1-7 22:38:39 | 只看该作者
燕秀不错。。
GMT+8, 2025-4-10 17:08 , Processed in 0.023954 second(s), 10 queries , Gzip On, Redis On.
