查看: 18561|回复: 4
[求助] 请问有人知道如何获取曲线或者边界端点的切线矢量吗?
发表于 2009-11-5 00:09:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
曲线或者边界,一般都有两个端点
其几何属性通过分析菜单是可以查得到的
不知道用API如何获取?
谢谢
发表于 2009-11-5 07:28:28 | 只看该作者
这里有:
UF_MODL_ask_curve_props [url=mkMSITStore:E:\UGS\NX%206.0\UGDOC\html_files\nxopen_net_ref\net_ref.chm::/ugopen_doc/uf_modl/uf_modl_curves.html#UF_MODL_ask_curve_props](view source)[/url]
Defined in: uf_modl_curves.h
Overview
Returns the point, tangent, unit principal normal, unit binormal,
torsion, and radius of curvature on a curve at a given parameter.
The input curve parameter, parm, is normalized between 0 and 1.
UF_EVAL_evaluate should be used to evaluate curves and edges instead
of using this routine. For a full circle, the routines may return
different results, as the parameterization of the circle may be done in
two different directions.
Environment
Internal and External
See Also
[url=mkMSITStore:E:\UGS\NX%206.0\UGDOC\html_files\nxopen_net_ref\net_ref.chm::/ugopen_doc/uf_eval/global.html#UF_EVAL_evaluate]UF_EVAL_evaluate[/url]
Required License(s)
gateway
int UF_MODL_ask_curve_props
tag_t curve_id,
double parm,
double point [ 3 ] ,
double tangent [ 3 ] ,
double p_norm [ 3 ] ,
double b_norm [ 3 ] ,
double * torsion,
double * rad_of_cur
[url=mkMSITStore:E:\UGS\NX%206.0\UGDOC\html_files\nxopen_net_ref\net_ref.chm::/ugopen_doc/uf_defs/uf_defs.html#tag_t]tag_t[/url]curve_idInputCurve identifier.
doubleparmInputCurve parameter.
doublepoint [ 3 ] OutputPoint on curve (3 element array).
doubletangent [ 3 ] OutputTangent of curve (3 element array).
doublep_norm [ 3 ] OutputUnit Principal normal of curve (3 element array).
doubleb_norm [ 3 ] OutputUnit Binormal of curve (3 element array).
double *torsionOutputTorsion.
double *rad_of_curOutputRadius of Curvature.
发表于 2009-11-5 07:30:20 | 只看该作者
其中第二个参数取值范围从0到1.
为0,表示起点信息,为1,表示终点信息
发表于 2009-11-5 09:28:06 | 只看该作者
谢谢!
我用NXOpen的AnalysisManager类做的(这个操作录制能录制到),但是在裁剪过的曲线一个端点总是出现巨大的数
所以只好找API试试
非常感谢!
发表于 2009-11-5 16:32:00 | 只看该作者
学习了学习了。
GMT+8, 2025-10-17 13:02 , Processed in 0.026544 second(s), 11 queries , Gzip On, Redis On.
