【原创】手把手Pro/E二次开发
发表于 2003-6-24 09:20:58 | 只看该作者
下面为Pro/E风格对话框的添加:
32
发表于 2003-6-24 09:27:01 | 只看该作者
到此,pro/e的开发已经算人门了
不在详细介绍
pro/e对话框风格在user guide有:
33
发表于 2003-6-24 09:28:50 | 只看该作者
编写调用程序:
34
发表于 2003-6-24 09:29:21 | 只看该作者
      确认对话框添加程序(Pro/E 风格对话框)
int UsrConfirmAction(char *question,ProBoolean *confirm);
  int UsrExample()
   &nbsproBoolean confirm;
    UsrConfirmAction("ro/E Dialog by TOOL", [$confirm)]
  return(1);
  FUNCTION : UsrOKAction() PURPOSE  : Action function for the OK button
  void UsrOKAction(
     char *dialog,
     char *component,
    &nbsproAppData data)
    &nbsproUIDialogExit(dialog, OK);
  FUNCTION : UsrCancelAction()
 &nbspURPOSE  : Action function for the Cancel button
  void UsrCancelAction(
     char *dialog,
     char *component,
     ProAppData data)
     ProUIDialogExit(dialog, CANCEL);
  FUNCTION : UsrConfirmAction()
  PURPOSE  : Utility to prompt the user with  question, and OK and Cancel
             buttons.
     char *question,
     ProLine wline;
     int status;
  Load the dialog from the resource file
  ProUIDialogCreate("confirm","confirm");
  Set the OK and Cancel button actions
  ProUIPushbuttonActivateActionSet("confirm","OK",UsrOKAction, NULL);
  ProUIPushbuttonActivateActionSet("confirm","Cancel",UsrCancelAction,NULL);
  Set the Question test in the label
  ProStringToWstring(wline, question);
     ProUILabelTextSet("confirm","Question",wline);
  Display and activate the dialog
  ProUIDialogActivate("confirm", [$status)]
  Set confirm according to which button was used to close the dialog
  *confirm = (status == OK) ? PRO_B_TRUE : PRO_B_FALSE;
  Remove the dialog from memory
  ProUIDialogDestroy("confirm");
    return(1);
35
发表于 2003-6-24 09:29:54 | 只看该作者
添加相关头文件
36
发表于 2003-6-24 09:36:18 | 只看该作者
编写消息注册文件(重要):
37
发表于 2003-6-24 09:38:20 | 只看该作者
注册运行:
弹出确认对话框
38
发表于 2003-6-24 09:40:14 | 只看该作者
今日暂时到此
39
发表于 2003-6-24 09:46:01 | 只看该作者
两个字”历害“!
40
发表于 2003-6-24 11:35:43 | 只看该作者
全部程序是不是这样子,放在.cpp中,编译出问题.请帮助
#include &ltroToolkit.h>
#include &ltroMenu.h>
#include &ltroMenuBar.h>
#include &ltroUtil.h>
void Check()
  AfxMessageBox("haha");
FUNCTION : user_initialize()
PURPOSE : Pro/TOOLKIT程序的总入口,完成初始化工作
extern "C" int user_initialize(
    int argc,
    char *argv[],
    char *version,
    char *build,
    wchar_t errbuf[80])
 &nbsproError status;
  uiCmdCmdId cmd_id;
  ProFileName mf;
  ProStringToWstring(mf,"usermsg.txt");
  status = ProMenubarMenuAdd ("Menu0", "USER Menu0",
        "Help", PRO_B_TRUE, mf);
  // 0添加父菜单Menu0
  status = ProMenubarmenuMenuAdd ("Menu0", "Menu1", "USER Menu1",
     NULL, PRO_B_TRUE, mf);
  添加弹出式菜单Menu1
  status = ProCmdActionAdd("Menu2", (uiCmdCmdActFn)Check,
    uiCmdPrioDefault, Check, PRO_B_TRUE, PRO_B_TRUE, [$cmd_id)]
  -1菜单Menu2动作
  status = ProMenubarmenuPushbuttonAdd ("Menu1", "Menu2",
     "USER Menu2", "USER Menu2 help", NULL, PRO_B_TRUE,cmd_id, mf);
  -1添加菜单Menu2
  return 0;
extern "C" user_terminater()
  return 0;
GMT+8, 2025-4-29 02:18 , Processed in 0.025236 second(s), 10 queries , Gzip On, Redis On.
