查看: 16787|回复: 1
[讨论] 求助 用Lisp写的齿轮程序不能运行
发表于 2010-4-24 16:19:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
写了个关于直尺圆柱齿轮的程序  运行出错  能大虾们 帮我看看那里出错了  非常感谢
(defun c:gear()
  (setp os(getvar"osmode"))
   (setvar"osmode"0)
   (setq m(getreal"输入模数:M=")
  z(getint"输入齿轮:Z=")
  h(getreal"输入齿轮宽度:H=")
  zj(getreal"输入齿轮轴径:ZJ=")
  lf(getreal"输入齿轮厚度:LF=")
  (if(> h lf)(progn
   (setq gr(getreal"输入轮毂端面半径:gr="))
(setq yr(getreal"输入轮缘端面半径:yr="))
(setq s(/(- h lf)2))
(setq l(- h s))
   (setq rf(/(*(- z 2.5)m)2)
  rj(/(* m z 0.939693)2)
  r(/(* z m)2)
  ra(/(*(+z2)m)2)
  tt(* m pi)
  pj(/36.0z)
  a(/(* 1.25m)(cos(*20(/pi 180))))
  pt0(list200.0 30.0 0.0)
  pt1(polar pt0 0(/tt4))
  pt2(polar pt0 pi(/tt4))
  pt3(polar pt1 (* 110(/pi 180))a)
  pt5(polar pt1 (* -70(/pi 180))a)
  pt4(polar pt2 (* 70(/pi 180))a)
  pt6(polar pt2 (* 250(/pi 180))a)
  pt7(polar pt6 (* -90(/pi 180))2)
  (command "layer" "m" "11" "c" 1 "" ""
     "layer" "m" "12" "c" 2 "" ""
     "layer" "m" "13" "c" 252 "" ""
     "layer" "s" "13" ""
     "pline" pt7 pt6 pt4 pt3 pt5
   (setq i 1)
   (while (<=i 7)
     (setq pt6(polar pt6 0 tt)
    pt4(polar pt4 0 tt)
    pt3(polar pt3 0 tt)
    pt5(polar pt5 0 tt)
   (command pt7 pt6 pt4 pt3 pt5)
   (setq i(+i 1))
   (setq pt8 (polar pt5(*-90(/pi 180))2))
   (command pt8 "c")
   (setq pt(polar pt0(* 180(/pi 180))(*4 tt)))
   (command "move" "1" ""pt0 pt)
   (setq e0(entlast))
   (command "layer" "s" 11"")
   (setq p0(polar pt0(* 90(/pi 180))r))
   (command "circle"p0 ra)
   (command "region" "1" "")
   (setq e10(entlast))
   (command "layer" "s" "12" "")
   (setq j 1)
   (while (<=j z)
      (setq i 1)
      (while (<=i 10)
         (command "rotate"e10""p0 pj)
         (setq yd(*r pj(/pi 180)i))
         (setq pt(polar pt0 0 yd))
         (command "copy" e0"" pt0 pt)
         (setq e1(entlast))
         (command "subtract" e10""e1"")
         (setq i(+i 1))
      (setq j(+j 1))
    (command "layer" "s" "11" "")
    (command "extrude" e10""h 0)
    (setq e5(entlast))
    (command "erase" e0"")
    (if(>h if(progn
    (command "circle"p0 yr)
    (setq e1(entlast))
    (command "extrude" e1""s 5)
    (setq e1(entlast))
    (command "circle"p0 gr)
    (setq e2(entlast))
    (command "extrude" e2""s -5)
    (setq e2(entlast))
    (command "subtract" e1 ""e2"")
    (setq pt(list(car p0)(car(cdr p0))h))
    (setq s(-0 s)
    (command "circle"pt yr)
    (setq e3(entlast))
    (command "extrude" e3""s 10)
    (setq e3(entlast))
    (command "circle"pt gr)
    (setq e4(entlast))
    (command "extrude" e4""s -10)
    (setq e4(entlast))
    (command "subtract" e3 ""e4"")
    (command "cylinder" p0(/zj 2)h)
    (setq e4(entlast))
    (command "subtract" e5 ""e1 e3 e4"")
               (progn(command "cylinder" p0(/zj 2)h)
    (setq e4(entlast))
    (command "subtract" e5 ""e4"")
     (setvar "osmode" os)
发表于 2010-8-17 21:57:40 | 只看该作者
把变量加上试试(DEFUN C:GEAR (/ z M 等)
GMT+8, 2025-4-10 17:07 , Processed in 0.021447 second(s), 13 queries , Gzip On, Redis On.
