查看: 17774|回复: 8
[求助] cam开发 操作余量获取
发表于 2010-9-9 15:25:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
double  stock_part;
UF_PARAM_ask_double_value(group,UF_PARAM_STOCK_PART,&stock_part);
char stock[133];
sprintf(stock,"程序余量是:%0.2f",tool_diam);
uc1601(stock,1);
发表于 2010-9-9 15:26:38 | 只看该作者
得出的数据很大,根本就不对,为何 !那位兄弟知道!
发表于 2010-9-9 15:27:21 | 只看该作者
char stock[133];
sprintf(stock,"程序余量是:%0.2f",stock_part);
uc1601(stock,1);
上面写错了,不好意思!
发表于 2010-9-10 18:27:17 | 只看该作者
己解决,现在主轴转速和进给没找到,有知道的说一声,谢谢!
发表于 2010-9-10 20:30:17 | 只看该作者
行不行啊楼主哥哥
发表于 2012-12-6 13:16:25 | 只看该作者
楼主 求学习
发表于 2012-12-10 14:58:45 | 只看该作者
我来告诉你:
转速是4005。进给是17
        UF_PARAM_ask_double_value(oper,4003,&double_t);  //UF_PARAM_SURFACE_SPEED      4003
        sprintf(temp,"UF_PARAM_SURFACE_SPEED=:%0.3f",double_t);
        list_w(temp);
        UF_PARAM_ask_double_value(oper,4004,&double_t);  //UF_PARAM_FEED_PER_TOOTH   4004
        sprintf(temp,"UF_PARAM_FEED_PER_TOOTH=:%0.3f",double_t);
        list_w(temp);
        UF_PARAM_ask_double_value(oper,4005,&double_t);  //UF_PARAM_SPINDLE_RPM   4005
        sprintf(temp,"Speed RPM=:%0.3f",double_t);
        list_w(temp);
        UF_PARAM_ask_int_value(oper,4013,&int_t);    //UF_PARAM_SPINDLE_RPM_TOG 4013*  0 -- Inactive   1 -- Active
        sprintf(temp,"使用RPM(1:激活):%d",int_t);
        list_w(temp);
        UF_PARAM_ask_int_value(oper,4008,&int_t);    //UF_PARAM_SPINDLE_MODE   4008
        sprintf(temp,"UF_PARAM_SPINDLE_MODE:%d",int_t);
        list_w(temp);
        UF_PARAM_ask_str_value(oper,4009,char_t);    //UF_PARAM_SPINDLE_RANGE_TEXT   4009
        sprintf(temp,"Spindle Range text:%s",char_t);
        list_w(temp);
        UF_PARAM_ask_str_value(oper,4010,char_t);    //UF_PARAM_SPINDLE_TEXT      4010
        sprintf(temp,"Spindle text:%s",char_t);
        list_w(temp);
        /* Second Page */
        UF_PARAM_ask_subobj_ptr_value(oper,UF_PARAM_FEED_RAPID,&h_feed);  //UF_PARAM_FEED_RAPID   10
        sprintf(temp,"RAPID:%0.1f",h_feed.value);
        list_w(temp);
        UF_PARAM_ask_subobj_ptr_value(oper,UF_PARAM_FEED_APPROACH,&h_feed);  //UF_PARAM_FEED_APPROACH   13
        sprintf(temp,"APPROACH:%0.1f",h_feed.value);
        list_w(temp);
        UF_PARAM_ask_subobj_ptr_value(oper,UF_PARAM_FEED_ENGAGE,&h_feed);  //UF_PARAM_FEED_ENGAGE   11
        sprintf(temp,"ENGAGE:%0.1f",h_feed.value);
        list_w(temp);
        UF_PARAM_ask_subobj_ptr_value(oper,UF_PARAM_FEED_FIRST_CUT,&h_feed);   //UF_PARAM_FEED_FIRST_CUT   18
        sprintf(temp,"FIRST_CUT:%0.1f",h_feed.value);
        list_w(temp);
        UF_PARAM_ask_subobj_ptr_value(oper,UF_PARAM_FEED_STEPOVER,&h_feed);   //UF_PARAM_FEED_STEPOVER   19
        sprintf(temp,"STEPOVER :%0.1f",h_feed.value);
        list_w(temp);
        UF_PARAM_ask_subobj_ptr_value(oper,UF_PARAM_FEED_CUT,&h_feed);   //UF_PARAM_FEED_CUT   17
        sprintf(temp,"FEED_CUT:%0.1f",h_feed.value);
        list_w(temp);
        UF_PARAM_ask_subobj_ptr_value(oper,UF_PARAM_FEED_TRAVERSAL,&h_feed);  //UF_PARAM_FEED_TRAVERSAL   16
        sprintf(temp,"TRAVERSAL:%0.1f",h_feed.value);
        list_w(temp);
        UF_PARAM_ask_subobj_ptr_value(oper,UF_PARAM_FEED_RETRACT,&h_feed);  //UF_PARAM_FEED_RETRACT   12
        sprintf(temp,"RETRACT:%0.1f",h_feed.value);
        list_w(temp);
        UF_PARAM_ask_subobj_ptr_value(oper,UF_PARAM_FEED_RETURN,&h_feed);  //UF_PARAM_FEED_RETURN   15
        sprintf(temp,"RETURN:%0.1f",h_feed.value);
        list_w(temp);
        //Third Page
发表于 2012-12-10 20:54:08 | 只看该作者
icaxhjy88 发表于 2012-12-10 14:58
我来告诉你:
转速是4005。进给是17
我拜你为师好不
发表于 2012-12-28 21:25:50 | 只看该作者
楼主威武。。向楼主学习。。
GMT+8, 2025-4-20 00:15 , Processed in 0.058147 second(s), 11 queries , Gzip On, Redis On.
