[灌水] E10可以用了
发表于 2010-12-11 10:34:23 | 只看该作者
期待e10的到来    还望分享一下破解
22
发表于 2010-12-11 13:15:26 | 只看该作者
支持.但愿不要失望
23
发表于 2010-12-11 21:29:03 | 只看该作者
4.        What’s New in General NC Enhancements?
SuperBox – The Productivity Acceleration Platform for NC Programmers
Background Calculations                后台计算
Cutters and Holders                                夹持
New Separate Cutters and Holder Libraries                新的分离的刀具夹持库
Cutter Table Enhancements                                        刀柄改进
Any Shaped Cutter                                                         支持任意成型刀
Simulation                                                模拟
New User Interface                        新的界面
Turbo Mode Enhancements
New Double Check Mode                新的检查模式
Contours                                                        轮廓
Contour Enhancements and Preview        轮廓改进及预览
Support Nested Contours                                支持嵌套轮廓
NC Report                                                NC报告
NC Report Enhancements        改进报告
Keep and Show Execution Log Information per Procedure
User Experience
Process Manager (Redesign of Icons and Flags) Improvements in Part/Check Surfaces Display        零件、检查曲面显示及程式管理器图标改进
Additional Enhancements
Post Processor Enhancements        后处理改进
64-Bit Enhancements                        支持64bit系统
5.        What’s New in NC 2.5-5 Axis Strategies?
2.5 Axis Milling                2.5轴铣削
Cutter Compensation – Output Toolpath “As Geometry” 输出刀具补偿
5-Axis Stock                        五轴毛坯
Rough with Undercut Stock        粗加工毛坯改进
Rough Operations        粗加工
“Second” Rough        二次开粗
Minimum Stock Width Improvements        改进最小毛坯宽度
Improved Performance of Consecutive Rough Operations        改善多次开粗性能
Improved Toolpath Quality – Final Pass        改进刀具路径质量 – 最终补刀
Optimized Rough                                                        优化粗加工
Plunging Into Pre-Drilled Holes                        增加预钻孔
Finish Operations        精加工
Finish Helical Milling Strategy        螺旋精加工策略
Hit Planes        平面补刀
Machining Order Mixed Optimized (Top to Bottom) Control Offset from Final Pass in Parallel Milling        根据角度精铣增加自上往下加工
Remachine Operations        清角
Cleanup                清角
Any Cutters Combination                参考任何刀具
User Control over horizontal/vertical angle        用户控制分割角度
5-Axis Milling
Improved 5-Axis Tilting Toolpath and Resulting Surface Quality
改良因倾斜来提高曲面质量
Various Additional Enhancements        其他功能改进
General                通用
        User Control over Connection Distance                用户控制连接距离
6.        What’s New in General Enhancements?
Display        显示
Texture Improvements        增加材质
Shader                                        阴影显示
New Shader                        新的阴影
Zebra Shader                斑马条纹
PMI
Import PMI from Siemens NX (UG)                支持NX的PMI输入
Coordinate Label                                标签
Additional Symbols                        标记
Dragging                                        支持拖拽
Automatic Update Online        自动在线更新
Downloadable Reviewer        可以下载评论
24
发表于 2010-12-11 21:30:58 | 只看该作者
LZ别太张扬,免得给别人惹事。
25
发表于 2010-12-12 13:33:11 | 只看该作者
Cleanup                清角
真的吗??????
26
发表于 2010-12-12 14:32:11 | 只看该作者
Any Cutters Combination                参考任何刀具?
真的吗?????? 菜刀? ^_^     ^_^     ^_^     ^_^
27
发表于 2010-12-12 14:32:27 | 只看该作者
28
发表于 2010-12-12 17:17:15 | 只看该作者
哈哈,清角加参考刀的吧
29
发表于 2010-12-12 17:41:19 | 只看该作者
参考任何刀具的意思是说现在可以参考牛鼻刀了
之前的版本是参考球刀的
30
发表于 2010-12-12 18:42:34 | 只看该作者
非常期待,希望能早日用上。
GMT+8, 2025-2-25 23:51 , Processed in 0.023450 second(s), 9 queries , Gzip On, Redis On.
