[分享] 获得ug文件的预览图片的控件
发表于 2010-12-29 15:17:21 | 只看该作者
再顶一下啊,期待楼主出现。。
发表于 2011-3-2 20:53:06 | 只看该作者
控件的代码:
发表于 2011-3-2 20:54:03 | 只看该作者
void OnPaint()
        if (IsIconic())
                CPaintDC dc(this); // 用于绘制的设备上下文
                SendMessage(WM_ICONERASEBKGND, reinterpret_cast<WPARAM>(dc.GetSafeHdc()), 0);
                // 使图标在工作矩形中居中
                int cxIcon = GetSystemMetrics(SM_CXICON);
                int cyIcon = GetSystemMetrics(SM_CYICON);
                CRect rect;
                GetClientRect(&rect);
                int x = (rect.Width() - cxIcon + 1) / 2;
                int y = (rect.Height() - cyIcon + 1) / 2;
                // 绘制图标
                dc.DrawIcon(x, y, m_hIcon);
        else
                CDialog::OnPaint();
                if ( m_bShowShortCut )
                        showShortCutAsFile( this->GetDC(), m_hBitmap );
发表于 2011-3-2 20:55:36 | 只看该作者
HRESULT  CreateThumbnail(DWORD dwWidth, DWORD dwHeight, HBITMAP* pThumbnail)
        LPITEMIDLIST pidlItems = NULL, pidlURL = NULL, pidlWorkDir = NULL;
        ULONG   ulParseLen = 0;
        HRESULT hr;
        WCHAR pszPath[MAX_PATH];
        DWORD dwPriority = 0, dwFlags = IEIFLAG_ASPECT;
        SIZE size = { dwWidth, dwHeight };
        IExtractImage* peiURL = NULL;        // nterface is used to request a thumbnail image from a Shell folder
        IShellFolder* psfDesktop = NULL;
        IShellFolder* psfWorkDir = NULL;
        IMalloc*          pMalloc = NULL;
        wstring wsDir,wsFile,wsTempFile;
        // 初始化Com库
        if ( CoInitialize( NULL ) != 0 )
                AfxMessageBox( _T( "初始化Com库失败!" ) );
                goto OnExit;
        hr = SHGetMalloc( &pMalloc );
        if ( FAILED( hr ) )
                goto OnExit;
        hr = SHGetDesktopFolder(&psfDesktop);
        if(FAILED(hr)) goto OnExit;
        wsDir = m_wsDir;
        wsFile = m_wsFile;
        wcscpy(m_wsBuffer,wsDir.c_str());
        hr = psfDesktop->ParseDisplayName(NULL, NULL, m_wsBuffer, &ulParseLen, &pidlWorkDir, NULL);
        hr = psfDesktop->BindToObject(pidlWorkDir, NULL, IID_IShellFolder, (LPVOID*)&psfWorkDir);
        psfDesktop->Release();
        psfDesktop = NULL;
        pMalloc->Free(pidlWorkDir);
        pidlWorkDir = NULL;
        wcscpy(m_wsBuffer,wsFile.c_str());
        hr = psfWorkDir->ParseDisplayName(NULL, NULL, m_wsBuffer, &ulParseLen, &pidlURL, NULL);
        hr = psfWorkDir->GetUIObjectOf(NULL, 1, (LPCITEMIDLIST*)&pidlURL, IID_IExtractImage, NULL, (LPVOID*)&peiURL);
        hr = peiURL->GetLocation(pszPath, MAX_PATH, &dwPriority, &size, 16, &dwFlags);
        hr = peiURL->Extract(pThumbnail);
        peiURL->Release();
        peiURL = NULL;
OnExit:
        if(peiURL != NULL) peiURL->Release();
        if(pidlURL != NULL) pMalloc->Free(pidlURL);
        if(pidlWorkDir != NULL) pMalloc->Free(pidlWorkDir);
        if(psfDesktop != NULL) psfDesktop->Release();
        if(psfWorkDir != NULL) psfWorkDir->Release();
        CoUninitialize();
        return hr;
发表于 2011-3-2 20:56:00 | 只看该作者
void  showShortCutAsFile( CDC* pDC, HBITMAP hBitmap )
        BITMAP  bmpPic;
        GetObject( hBitmap, sizeof BITMAP, &bmpPic );        // 图片大小与控件大小不一致,缩放
        HBITMAP hOdBmp = static_cast<HBITMAP>( SelectObject( m_pMemDC->m_hDC, hBitmap ) );
        ::StretchBlt( pDC->m_hDC,
                                  m_rectStatic.left,
                                  m_rectStatic.top,
                                  m_rectStatic.Width(),
                                  m_rectStatic.Height(),
                                  m_pMemDC->m_hDC,
                                  0,
                                  0,
                                  bmpPic.bmWidth,
                                  bmpPic.bmHeight,
                                  +SRCCOPY );
        SelectObject( m_pMemDC->m_hDC, hOdBmp );
发表于 2011-3-2 20:56:57 | 只看该作者
显示图片
void  OnBnClickedButtonShowShortCut()
        // TODO: 在此添加控件通知处理程序代码
        DWORD dwWeight = 320;
        DWORD dwHeight = 240;
        CFileDialog dlg( TRUE,_T("prt" ));
        dlg.m_ofn.lpstrFilter = _T( "Microsoft Excel Files(*.xls)\0*.xls\0All Files(*.*)\0*.*\0\0" );
        int nRetVal = dlg.DoModal();
        if ( nRetVal == IDCANCEL )
                return ;
        CString strFilePath = dlg.GetPathName();
        m_wsDir = (LPCWSTR)strFilePath.Left( strFilePath.ReverseFind( _T( '\\' ) ) + 1 ); // 带"\"
        m_wsFile = (LPCWSTR)dlg.GetFileName();
        HRESULT hr;
        HBITMAP hBitmap;
        hr = CreateThumbnail( dwWeight, dwHeight, &hBitmap );
        if ( FAILED( hr ) )
                AfxMessageBox( _T( "获得缩略图失败!" ) );
                return ;
        m_hBitmap = hBitmap;
        m_bShowShortCut = TRUE;
        showShortCutAsFile( this->GetDC(), hBitmap );
发表于 2011-3-2 20:57:38 | 只看该作者
给你的都是控件的类成员代码
剩余的就是调用控件了
18
发表于 2011-3-2 20:58:20 | 只看该作者
我把类名删除了 你自己根据自己的类名 在函数前添加即可
19
发表于 2011-3-2 20:59:07 | 只看该作者
类的成员函数
// 实现
protected:
        HICON m_hIcon;
        // 生成的消息映射函数
        virtual BOOL OnInitDialog();
        afx_msg void OnSysCommand(UINT nID, LPARAM lParam);
        afx_msg void OnPaint();
        afx_msg HCURSOR OnQueryDragIcon();
        DECLARE_MESSAGE_MAP()
public:
        // 获取缩略图的句柄
        HRESULT CreateThumbnail( DWORD dwWidth,  DWORD dwHeight,
                                                         HBITMAP* pThumbnail );
        // 在界面上显示缩略图
        void showShortCutAsFile( CDC* pDC, HBITMAP hBitmap );
private:
        // 内存位图
        CRect        m_rect;
        CRect        m_rectStatic;
        CDC*        m_pMemDC;
        CBitmap m_bmpMem;
        // 获取缩略图
        // 文件夹路径
        wstring m_wsDir;
        // 文件名称
        wstring m_wsFile;
        // 临时缓冲区
        wchar_t m_wsBuffer[255];
        // 为了刷新
        HBITMAP m_hBitmap;
        BOOL        m_bShowShortCut;
        CBrush  m_brushShortCut;
        afx_msg void OnBnClickedButtonShowShortCut();
20
发表于 2011-3-2 20:59:42 | 只看该作者
自己复制粘帖一下就可以了
看不懂代码也没有什么关系 只要会用就可以
GMT+8, 2025-4-18 16:22 , Processed in 0.028610 second(s), 10 queries , Gzip On, Redis On.
