查看: 16635|回复: 0
[求助] 10.0版本的问题
发表于 2011-2-28 10:14:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个问题已经困扰我很久,没有找到人回答。
就是有时候不小点动了哪里,搞得转不进也转不出如igs,stp等格式。
出现提示如下:
Open i-deas initialization failed because ORB initialization timed out. The most likely reason for this is that one of the Orbix services is not responding.It is reconmmended that you terminate I-DEAS immediately and check whether the Orbix services are working.Click ok to terminate I-DEAS.
GMT+8, 2025-4-12 08:38 , Processed in 0.019535 second(s), 11 queries , Gzip On, Redis On.
