我使用NX7.5 Block Style创建的对话框,生成语言为C++, 可是在代码编译时在
30 TextDlg::theUI = UI::GetUI();
31 theDialogName = "TextDlg.dlx";
32 theDialog = TextDlg::theUI->CreateDialog(theDialogName.c_str());
在32行出现如下错误
error C2059: syntax error : ',' c:\program files (x86)\ugs\nx 6.0\ugopen\nxopen\ui.hxx 117 1 NxOpen
Error 6 error C2059: syntax error : ',' d:\project\nxopen\nxopen\textdlg.cpp 65 1 NxOpen
其中textdlg.cpp自动生成的代码,
求救,谢谢各位大侠,小弟感激万分。
生成cpp代码如下:
// WARNING!! This file is overwritten by the Block Styler while generating
// the automation code. Any modifications to this file will be lost after
// generating the code again.
// Filename: D:\project\MFCDll\Dialog\TextDlg.cpp
// This file was generated by the NX Block Styler
// Created by: user
// Version: NX 6
// Date: 07-26-2011 (Format: mm-dd-yyyy)
// Time: 10:04 (Format: hh-mm)
// Purpose: This TEMPLATE file contains C++ source to guide you in the
// construction of your Block application dialog. The generation of your
// dialog file (.dlx extension) is the first step towards dialog construction
// within NX. You must now create a NX Open application that
// utilizes this file (.dlx).
// The information in this file provides you with the following:
// 1. Help on how to load and display your Block Styler dialog in NX
// using APIs provided in NXOpen.BlockStyler namespace
// 2. The empty callback methods (stubs) associated with your dialog items
// have also been placed in this file. These empty methods have been
// created simply to start you along with your coding requirements.
// The method name, argument list and possible return values have already
// been provided for you.
//These includes are needed for the following template code
#include "stdafx.h"
#include "TextDlg.hpp"
#include "string.h"
using namespace NXOpen;
using namespace NXOpen::BlockStyler;
// Initialize static variables
Session *(TextDlg::theSession) = NULL;
UI *(TextDlg::theUI) = NULL;
// Declaration of global variables
TextDlg *theTextDlg;
// Constructor for NX Styler class
TextDlg::TextDlg()
try
// Initialize the NX Open C++ API environment
TextDlg::theSession = NXOpen::Session::GetSession();
// Registration of callback functions
theDialog->AddApplyHandler(make_callback(this, &TextDlg::apply_cb));
theDialog->AddOkHandler(make_callback(this, &TextDlg: k_cb));
theDialog->AddUpdateHandler(make_callback(this, &TextDlg::update_cb));
theDialog->AddInitializeHandler(make_callback(this, &TextDlg::initialize_cb));
theDialog->AddDialogShownHandler(make_callback(this, &TextDlg::dialogShown_cb));
catch(exception& ex)
//---- Enter your exception handling code here -----
throw ex;
// Destructor for NX Styler class
TextDlg::~TextDlg()
if (theDialog != NULL)
delete theDialog;
theDialog = NULL;
//------------------------------- DIALOG LAUNCHING ---------------------------------
// Before invoking this application one needs to open any part/empty part in NX
// because of the behavior of the blocks.
// Make sure the dlx file is in one of the following locations:
// 1.) From where NX session is launched
// 2.) $UGII_USER_DIR/application
// 3.) For released applications, using UGII_CUSTOM_DIRECTORY_FILE is highly
// recommended. This variable is set to a full directory path to a file
// containing a list of root directories for all custom applications.
// e.g., UGII_CUSTOM_DIRECTORY_FILE=<NX install directory>\ugii\menus\custom_dirs.dat
// You can create the dialog using one of the following way:
// 1. USER EXIT
// 1) Create the Shared Library -- Refer "Block Styler programmer's guide"
// 2) Invoke the Shared Library through File->Execute->NX Open menu.
extern "C" DllExport void ufusr(char *param, int *retcod, int param_len)
try
theTextDlg = new TextDlg();
// The following method shows the dialog immediately
theTextDlg->Show();
TextDlg::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox: ialogTypeError, ex.what());
delete theTextDlg;
// This method specifies how a shared image is unloaded from memory
// within NX. This method gives you the capability to unload an
// internal NX Open application or user exit from NX. Specify any
// one of the three constants as a return value to determine the type
// of unload to perform:
// Immediately : unload the library as soon as the automation program has completed
// Explicitly : unload the library from the "Unload Shared Image" dialog
// AtTermination : unload the library when the NX session terminates
// NOTE: A program which associates NX Open applications with the menubar
// MUST NOT use this option since it will UNLOAD your NX Open application image
// from the menubar.
extern "C" DllExport int ufusr_ask_unload()
//return (int)Session: ibraryUnloadOptionExplicitly;
return (int)Session: ibraryUnloadOptionImmediately;
//return (int)Session: ibraryUnloadOptionAtTermination;
// Following method cleanup any housekeeping chores that may be needed.
// This method is automatically called by NX.
extern "C" DllExport void ufusr_cleanup(void)
try
//---- Enter your callback code here -----
int TextDlg::Show()
try
theDialog->Show();
return 0;
//---------------------Block Styler Callback Functions--------------------------
//Callback Name: initialize_cb
void TextDlg::initialize_cb()
try
group0 = theDialog->TopBlock()->FindBlock("group0");
button0 = theDialog->TopBlock()->FindBlock("button0");
//Callback Name: dialogShown_cb
//This callback is executed just before the dialog launch. Thus any value set
//here will take precedence and dialog will be launched showing that value.
void TextDlg::dialogShown_cb()
try
//Callback Name: apply_cb
int TextDlg::apply_cb()
try
TextDlg::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox::DialogTypeError, ex.what());
return 0;
//Callback Name: update_cb
int TextDlg::update_cb(NXOpen::BlockStyler::UIBlock* block)
try
if(block == button0)
//---------Enter your code here-----------
return 0;
//Callback Name: ok_cb
int TextDlg: k_cb()
try
apply_cb();
return 0;
小弟拜谢了。
