返回列表 发新帖
MY MPA anasys 1
发表于 2003-8-20 17:52:29 | 只看该作者
能否加分!!!!!!!!!!!!
发表于 2003-8-20 19:36:33 | 只看该作者
zjxwhu wrote:
Release Level: 6.0
  shengmen_stl
  Part Name: shengmen
  Material Supplier: GE Plastics (USA)
  Material Grade: Cycoloy C7210A
  Max Injection Pressure: 140.00 MPa
  Mold Temperature: 55.00 deg.C
  Melt Temperature: 255.00 deg.C
  Model Suitability: Part model was highly suitable for analysis.
  shengmen_stl
  Moldability: Your part may be difficult to fill and part quality may be unacceptable.
  View the Confidence of Fill plot and use the Dynamic Adviser to get help on how to improve the filling of the part.
  Confidence: Medium
  Injection Time: 2.99 sec
  Injection Pressure: 133.58 MPa
  Weld Lines: Yes
  Air Traps: Yes
  Shot Volume (cavity, runner): 2030.17 cu.cm ( 1635.91, 394.27 )
  Filling Clamp Force: 1576.72 tonne
  Packing Clamp Force Estimate @20%: ( 26.72 )MPa 735.01 tonne
  Packing Clamp Force Estimate @80%: ( 106.86 )MPa 2940.04 tonne
  Packing Clamp Force Estimate @120%: ( 160.30 )MPa 4410.05 tonne
  Clamp Force Area: 2697.25 sq.cm
  Cycle Time: 18.56 sec
  Warnings: The complexity of the current model will probably result in a longer analysis
  time than usual, and may require hardware above the minimum specification.
::y不错能否对这些内容进行一下解释:-P
发表于 2003-8-21 09:58:24 | 只看该作者
楼上,此零件为冰箱的门面板,热流道公司建议为9个热嘴(想多赚钱),现用4个热嘴分析,但压力用了138MPA,故目前模具上使用了6个热嘴,零件质量OK!
发表于 2003-8-21 10:00:01 | 只看该作者
楼上,我是宁波宁海人,现在广东工作!你呢?在那里?
发表于 2003-8-21 19:52:25 | 只看该作者
我在宁波市区工作
给你PM啦有空聊聊::b
发表于 2003-8-22 11:20:01 | 只看该作者
我在用MPI,但是MPI的网格修补功能太差,好多的实体无法修补!你的建议呢?
GMT+8, 2025-3-14 13:40 , Processed in 0.020810 second(s), 9 queries , Gzip On, Redis On.
