查看: 17922|回复: 0
[原创] vs2010和AUTOCAD2010环境下,的三维实体小球的运动
发表于 2012-3-8 22:11:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我看的一本书vb和AUTOCAD二次开发运行的是三维实体小球沿正玄曲线的运动,但是不能出结果,什么原因,环境是vs2010和AUTOCAD2010,能够运行,但是没有结果,只是能够打开AUTOCAD,但是里面没有图,求解,附代码,急啊,大侠们。
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports System.Math
Public Class Form1
    Dim AcadApp As New AcadApplication           'AcadApplication是CAD对象接口
    Dim acadDoc As AcadDocument                 'AcadDocument是CAD文件
    Dim moSpace As AcadModelSpace               'AcadModelSpace是模型空间
    Dim paSpace As AcadPaperSpace               'AcadPaperSpace是图纸空间
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        'On Error Resume Next
        '完成AutoCAD的连接与启动
        AcadApp = GetObject(, "AutoCAD.Application")
        If Err.Number Then          'err.number=0表示没有出错 err.number<>0表示有错
            Err.Clear()
            AcadApp = CreateObject("AutoCAD.Application")
            If Err.Number Then
                MsgBox("不能运行AutoCAD 2010,请检查是否安装了AutoCAD2010")
                Exit Sub
            End If
        End If
        AcadApp.Visible = True
        'Autocad窗口最大化
        AcadApp.WindowState = AcWindowState.acMax
        'acadDoc = AcadApp.ActiveDocument
        'moSpace = acadDoc.ModelSpace
        'paSpace = acadDoc.PaperSpace
        '设置Gouraud着色
        AcadApp.ActiveDocument.SendCommand("_Shademode" + vbCr + "_G" + vbCr)
        '时钟初始化
        Me.Timer1.Interval = 1   '设置当前定时器的间隔时间
        Me.Timer1.Enabled = False
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Me.Timer1.Enabled = Not Me.Timer1.Enabled
    End Sub
    Private Sub Timer1_Timer()
        Dim Xmax As Single
        Dim Ymax As Single
        Xmax = AcadApp.ActiveDocument.Width / 1.2
        Ymax = AcadApp.ActiveDocument.Height / 3
        '创建spline为轨迹
        Dim splineObj As AcadSpline         '样条曲线
        Dim noOfPoints As Integer
        Dim startTan(0 To 2) As Double
        Dim endTan(0 To 2) As Double
        Dim fitPoints(0 To 35 * 3 + 2) As Double
        noOfPoints = 36
        startTan(0) = 0.5 : startTan(1) = 0.5 : startTan(2) = 0
        endTan(0) = 0.5 : endTan(1) = 0.5 : endTan(2) = 0
        Dim i As Integer
        Dim k As Integer
        For i = 0 To 350 Step 10
            k = i / 10
            fitPoints(3 * k + 0) = i * Xmax / 360
            fitPoints(3 * k + 1) = Sin(i * 3.14 / 180) * Ymax + Ymax
            fitPoints(3 * k + 2) = 0
        Next i
        splineObj = AcadApp.ActiveDocument.ModelSpace._AddSpline(fitPoints, startTan, endTan)
        splineObj.Update()
        '创建球体
        Dim SphereObj As Acad3DSolid
        Dim center(0 To 2) As Double
        Dim radius As Double
        center(0) = 0.0# : center(1) = Ymax : center(2) = 0
        radius = 30
        SphereObj = AcadApp.ActiveDocment.ModelSpace.AddSphere_(center, radius)
        SphereObj.color = ACAD_COLOR.acRed
        SphereObj.Update()
        '球体沿正玄曲线运动
        For i = 0 To 360 Step 10
            SphereObj.Move(SphereObj.Centroid, center)
            center(0) = i * Xmax / 360          '改变球体X坐标
            center(1) = Sin(i * 3.14 / 180) * Ymax + Ymax      '改变球体Y坐标
            SphereObj.Update()                   '立即重绘、更新小球
        Next i
    End Sub
End Class
GMT+8, 2025-4-12 00:53 , Processed in 0.021976 second(s), 13 queries , Gzip On, Redis On.
