【原创】Surfcam MPostwin解釋兼教程
 关闭 [复制链接]
11
发表于 2003-11-9 15:52:35 | 只看该作者
數值 的 乘 與  除
发表于 2003-11-9 15:55:55 | 只看该作者
分數 與 加
发表于 2003-11-9 15:58:10 | 只看该作者
數值 要 減 怎麼辦?
先回答出來 加分
发表于 2003-11-11 13:25:41 | 只看该作者
ModalLetters X Y Z F R                      # 哪些位址碼是缺省l
ModalGs 0 1 2 3 73 74 76 80 81 82 83 84 85  # G 碼缺省l
Sequence#s N 0 1 1                  ---        # Char, freq, incr & start
First#? N                                  --- # Y or N  'Output 1st sequence no.
Last#? N                                  ---   # Y or N  'Output last sequence no.
HCode X                                  ---   # X or X U  'Horizontal char.
VCode Y                                  ---  # Y or Y V  'Vertical char.
Dcode Z                                  ---   # Depth char.
FeedCode F                             ---     # Feed rate char.
Comment ( )                           ----   # Begin End comment char.
Spindle 3 4 5                             ---  # Cw, ccw & stop m codes
Coolant 8 9 7 61 62 63 64              ---     # Flood, Off, Mist and Thru Spindle M codes
DComp 41 42 40                           ---   # Left, Right & Cancel m codes
LComp 43 49                               --  # On & Off codes
Feed G01                                   --  # Linear move
Rapid G00                                  --  # Rapid positioning word
ArcPlane G 17 18 19                   --    # G19, G18, G17 Arc Plane selection
ReturnPlane 98 99                       --    # G98 G99 Return Plane selection
Cw G2                                     --  # Circular move clockwise
Ccw G3                                   --   # Circular move counter clockwise
Inc/Abs G 91 90                         --    #Inc& Abs char. & values
CtrCode I J K                             --  # I J or R or I J K L
Helical? Y
Spaces? Y                               --    # Y or N  'Spaces between words
Incremental? Y                         --     # Y or N  'Inc or abs output
CtrIncremental? Y                     --      # Y or N  'Inc or abs I & J
ByQuadrants? Y                       --       # Y or N  'Break arcs at quadrants
UppercaseComments? Y               # Y or N 'Require uppercase comments
发表于 2003-11-11 13:29:34 | 只看该作者
CtrCode I J K 改成 CtrCode R
就 輸出 G02/ G03 X Y R
发表于 2003-11-11 13:31:49 | 只看该作者
鑽孔循環等 定義:
Drill                                       # Drilling canned/manual cycle
G81 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
CSink
G82 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate] P[Dwell]
end cancel
Peck                                        # Pecking canned/manual cycle
G83 G[RetPlane] X[H] Y[V] Z[D] Q[VBite] R[Vclear] F[FRate]
end cancel
Tap                                         # Tapping canned/manual cycle
if [Rigid] > 0
G93           G93 to lock Z to spindle rotation.
G84 G[RetPlane] X[H] Y[V] Z[D] P[Dwell] R[VClear] F[FRate]
else
G84 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate]
Endif
end cancel
LTap                                        # Left handed tapping cycle
G74 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate] Q[VBite]
end cancel
Ream                                        # Reaming canned/manual cycle
G85 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Bore                                        # Boring canned/manual cycle
G86 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Back                                        # Back boring canned/manual cycle
G87 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Cancel                                      # Cancel a canned/manual cycle
G80
if [Rigid] > 0
G94          Unlock Z if w/ rigid tap.
endif
End
发表于 2003-11-11 13:44:56 | 只看该作者
程序起始
StartCode                                   # Start of the program
%0
O&ltrogram#>
G17 G40 G80 G90
G91 g28 x0 y0 z0
End
18
发表于 2003-11-11 13:46:33 | 只看该作者
第一次換刀的時候輸出 定義:
1stToolChange                               # First tool change
ask <Val1> " If this operation is without Cycle, please enter 1" "1"
N[Block] T[Tool] M6
(0 d[ToolRad] e[ToolDiam] f[corner] )0
M[Direct] S[Speed]
if [Val1] = 1
^0
G0 G[54] X[H] Y[V]
G43 z[D] H[Lcomp]
M[Cool]
else
G0 G[54] X[H] Y[V]
G43 z[D] H[Lcomp]
M[Cool]
endif
End
19
发表于 2003-11-11 14:03:57 | 只看该作者
因為要判斷 有 鑽孔循環的 時候 不輸出G5.1 Q1
所以 加了Ask <Val1> 問使用者...內定值 1,  代表 不是 Canned Cycle
^0
輸出 G5.1 Q1
偶在後處理配置文件 最後面有一行
replace "d" with "Tool Radius "
replace "e" with "Tool Diam "
replace "f" with "Corner Rad. "
Replace "^" with "G5.1 Q1"
Replace "&" with "G5.1 Q0"
輸出( 刀具半徑, 刀具直徑, 刀鼻半徑)
20
发表于 2003-11-11 14:06:18 | 只看该作者
G0 G[54] X[H] Y[V]
G43 Z[D] H[Lcomp]
M[Cool]
建議改成
G0 G[Work] X[H] Y[V]
G43 Z[D] H[Lcomp]
M[Cool]
Work 是 G54 -- G59的變數...後處理的時候 系統會問你 要輸出什麼值
GMT+8, 2025-4-3 02:31 , Processed in 0.049891 second(s), 9 queries , Gzip On, Redis On.
