返回列表 发新帖
【求助】誰能告訴我AUTOCAD使用中的諸多快捷鍵?
发表于 2003-11-19 15:53:38 | 只看该作者
;  AutoCAD Program Parameters File For AutoCAD 2004
;  External Command and Command Alias Definitions
;  Copyright (C) 1997-2002 by Autodesk, Inc.
;  Each time you open a new or existing drawing, AutoCAD searches
;  the support path and reads the first acad.pgp file that it finds.
;  -- External Commands --
;  While AutoCAD is running, you can invoke other programs or utilities
;  such Windows system commands, utilities, and applications.
;  You define external commands by specifying a command name to be used
;  from the AutoCAD command prompt and an executable command string
;  that is passed to the operating system.
;  -- Command Aliases --
;  You can abbreviate frequently used AutoCAD commands by defining
;  aliases for them in the command alias section of acad.pgp.
;  You can create a command alias for any AutoCAD command,
;  device driver command, or external command.
;  Recommendation: back up this file before editing it.
;  External command format:
;  <Command name>,[<DOS request>],<Bit flag>,
  • &ltrompt>,
    ;  The bits of the bit flag have the following meanings:
    ;  Bit 1: if set, don't wait for the application to finish
    ;  Bit 2: if set, run the application minimized
    ;  Bit 4: if set, run the application "hidden"
    ;  Bit 8: if set, put the argument string in quotes
    ;  Fill the "bit flag" field with the sum of the desired bits.
    ;  Bits 2 and 4 are mutually exclusive; if both are specified, only
    ;  the 2 bit is used. The most useful values are likely to be 0
    ;  (start the application and wait for it to finish), 1 (start the
    ;  application and don't wait), 3 (minimize and don't wait), and 5
    ;  (hide and don't wait). Values of 2 and 4 should normally be avoided,
    ;  as they make AutoCAD unavailable until the application has completed.
    ;  Bit 8 allows commands like DEL to work properly with filenames that
    ;  have spaces such as "long filename.dwg".  Note that this will interfere
    ;  with passing space delimited lists of file names to these same commands.
    ;  If you prefer multiplefile support to using long file names, turn off
    ;  the "8" bit in those commands.
    ;  Examples of external commands for command windows
    CATALOG,   DIR /W,         8,File specification: ,
    DEL,       DEL,            8,File to delete: ,
    DIR,       DIR,            8,File specification: ,
    EDIT,      START EDIT,     9,File to edit: ,
    SH,        ,               1,*OS Command: ,
    SHELL,     ,               1,*OS Command: ,
    START,     START,          1,*Application to start: ,
    TYPE,      TYPE,           8,File to list: ,
    ; Examples of external commands for Windows
    ; See also the (STARTAPP) AutoLISP function for an alternative method.
    EXPLORER,  START EXPLORER, 1,,
    NOTEPAD,   START NOTEPAD,  1,*File to edit: ,
    PBRUSH,    START PBRUSH,   1,,
    ; Command alias format:
    ;   <Alias>,*<Full command name>
    ;  The following are guidelines for creating new command aliases.
    ;  1. An alias should reduce a command by at least two characters.
    ;      Commands with a control key equivalent, status bar button,
    ;      or function key do not require a command alias.
    ;      Examples: Control N, O, P, and S for New, Open, Print, Save.
    ;  2. Try the first character of the command, then try the first two,
    ;      then the first three.
    ;  3. Once an alias is defined, add suffixes for related aliases:
    ;      Examples: R for Redraw, RA for Redrawall, L for Line, LT for
    ;      Linetype.
    ;  4. Use a hyphen to differentiate between command line and dialog
    ;      box commands.
    ;      Example: B for Block, -B for -Block.
    ; Exceptions to the rules include AA for Area, T for Mtext, X for Explode.
    ;  -- Sample aliases for AutoCAD commands --
    ;  These examples include most frequently used commands.
    3A,        *3DARRAY
    3DO,       *3DORBIT
    3F,        *3DFACE
    3P,        *3DPOLY
    A,         *ARC
    ADC,       *ADCENTER
    AA,        *AREA
    AL,        *ALIGN
    AP,        *APPLOAD
    AR,        *ARRAY
    -AR,       *-ARRAY
    ATT,       *ATTDEF
    -ATT,      *-ATTDEF
    ATE,       *ATTEDIT
    -ATE,      *-ATTEDIT
    ATTE,      *-ATTEDIT
    B,         *BLOCK
    -B,        *-BLOCK
    BH,        *BHATCH
    BO,        *BOUNDARY
    -BO,       *-BOUNDARY
    BR,        *BREAK
    C,         *CIRCLE
    CH,        *PROPERTIES
    -CH,       *CHANGE
    CHA,       *CHAMFER
    CHK,       *CHECKSTANDARDS
    COL,       *COLOR
    COLOUR,    *COLOR
    CO,        *COPY
    CP,        *COPY
    D,         *DIMSTYLE
    DAL,       *DIMALIGNED
    DAN,       *DIMANGULAR
    DBA,       *DIMBASELINE
    DBC,       *DBCONNECT
    DC,        *ADCENTER
    DCE,       *DIMCENTER
    DCENTER,   *ADCENTER
    DCO,       *DIMCONTINUE
    DDA,       *DIMDISASSOCIATE
    DDI,       *DIMDIAMETER
    DED,       *DIMEDIT
    DI,        *DIST
    DIV,       *DIVIDE
    DLI,       *DIMLINEAR
    DO,        *DONUT
    DOR,       *DIMORDINATE
    DOV,       *DIMOVERRIDE
    DR,        *DRAWORDER
    DRA,       *DIMRADIUS
    DRE,       *DIMREASSOCIATE
    DS,        *DSETTINGS
    DST,       *DIMSTYLE
    DT,        *TEXT
    DV,        *DVIEW
    E,         *ERASE
    ED,        *DDEDIT
    EL,        *ELLIPSE
    EX,        *EXTEND
    EXIT,      *QUIT
    EXP,       *EXPORT
    EXT,       *EXTRUDE
    F,         *FILLET
    FI,        *FILTER
    G,         *GROUP
    -G,        *-GROUP
    GR,        *DDGRIPS
    H,         *BHATCH
    -H,        *HATCH
    HE,        *HATCHEDIT
    HI,        *HIDE
    I,         *INSERT
    -I,        *-INSERT
    IAD,       *IMAGEADJUST
    IAT,       *IMAGEATTACH
    ICL,       *IMAGECLIP
    IM,        *IMAGE
    -IM,       *-IMAGE
    IMP,       *IMPORT
    IN,        *INTERSECT
    INF,       *INTERFERE
    IO,        *INSERTOBJ
    L,         *LINE
    LA,        *LAYER
    -LA,       *-LAYER
    LE,        *QLEADER
    LEN,       *LENGTHEN
    LI,        *LIST
    LINEWEIGHT, *LWEIGHT
    LO,        *-LAYOUT
    LS,        *LIST
    LT,        *LINETYPE
    -LT,       *-LINETYPE
    LTYPE,     *LINETYPE
    -LTYPE,    *-LINETYPE
    LTS,       *LTSCALE
    LW,        *LWEIGHT
    M,         *MOVE
    MA,        *MATCHPROP
    ME,        *MEASURE
    MI,        *MIRROR
    ML,        *MLINE
    MO,        *PROPERTIES
    MS,        *MSPACE
    MT,        *MTEXT
    MV,        *MVIEW
    O,         *OFFSET
    OP,        *OPTIONS
    ORBIT,     *3DORBIT
    OS,        *OSNAP
    -OS,       *-OSNAP
    P,         *PAN
    -P,        *-PAN
    PA,        *PASTESPEC
    PARTIALOPEN, *-PARTIALOPEN
    PE,        *PEDIT
    PL,        *PLINE
    PO,        *POINT
    POL,       *POLYGON
    PR,        *PROPERTIES
    PRCLOSE,   *PROPERTIESCLOSE
    PROPS,     *PROPERTIES
    PRE,       *PREVIEW
    PRINT,     *PLOT
    PS,        *PSPACE
    PTW,       *PUBLISHTOWEB
    PU,        *PURGE
    -PU,       *-PURGE
    R,         *REDRAW
    RA,        *REDRAWALL
    RE,        *REGEN
    REA,       *REGENALL
    REC,       *RECTANG
    REG,       *REGION
    REN,       *RENAME
    -REN,      *-RENAME
    REV,       *REVOLVE
    RO,        *ROTATE
    RPR,       *RPREF
    RR,        *RENDER
    S,         *STRETCH
    SC,        *SCALE
    SCR,       *SCRIPT
    SE,        *DSETTINGS
    SEC,       *SECTION
    SET,       *SETVAR
    SHA,       *SHADEMODE
    SL,        *SLICE
    SN,        *SNAP
    SO,        *SOLID
    SP,        *SPELL
    SPL,       *SPLINE
    SPE,       *SPLINEDIT
    ST,        *STYLE
    STA,       *STANDARDS
    SU,        *SUBTRACT
    T,         *MTEXT
    -T,        *-MTEXT
    TA,        *TABLET
    TH,        *THICKNESS
    TI,        *TILEMODE
    TO,        *TOOLBAR
    TOL,       *TOLERANCE
    TOR,       *TORUS
    TP,        *TOOLPALETTES
    TR,        *TRIM
    UC,        *UCSMAN
    UN,        *UNITS
    -UN,       *-UNITS
    UNI,       *UNION
    V,         *VIEW
    -V,        *-VIEW
    VP,        *DDVPOINT
    -VP,       *VPOINT
    W,         *WBLOCK
    -W,        *-WBLOCK
    WE,        *WEDGE
    X,         *EXPLODE
    XA,        *XATTACH
    XB,        *XBIND
    -XB,       *-XBIND
    XC,        *XCLIP
    XL,        *XLINE
    XR,        *XREF
    -XR,       *-XREF
    Z,         *ZOOM
    ; The following are alternative aliases and aliases as supplied
    ;  in AutoCAD Release 13.
    AV,        *DSVIEWER
    CP,        *COPY
    DIMALI,    *DIMALIGNED
    DIMANG,    *DIMANGULAR
    DIMBASE,   *DIMBASELINE
    DIMCONT,   *DIMCONTINUE
    DIMDIA,    *DIMDIAMETER
    DIMED,     *DIMEDIT
    DIMTED,    *DIMTEDIT
    DIMLIN,    *DIMLINEAR
    DIMORD,    *DIMORDINATE
    DIMRAD,    *DIMRADIUS
    DIMSTY,    *DIMSTYLE
    DIMOVER,   *DIMOVERRIDE
    LEAD,      *LEADER
    TM,        *TILEMODE
    ; Aliases for Hyperlink/URL Release 14 compatibility
    SAVEURL, *SAVE
    OPENURL,   *OPEN
    INSERTURL, *INSERT
    ; Aliases for commands discontinued in AutoCAD 2000:
    AAD,        *DBCONNECT
    AEX,        *DBCONNECT
    ALI,        *DBCONNECT
    ASQ,        *DBCONNECT
    ARO,        *DBCONNECT
    ASE,        *DBCONNECT
    DDATTDEF,   *ATTDEF
    DDATTEXT,   *ATTEXT
    DDCHPROP,   *PROPERTIES
    DDCOLOR,    *COLOR
    DDLMODES,   *LAYER
    DDLTYPE,    *LINETYPE
    DDMODIFY,   *PROPERTIES
    DDOSNAP,    *OSNAP
    DDUCS,      *UCS
    ; Aliases for commands discontinued in AutoCAD 2004:
    ACADBLOCKDIALOG,  *BLOCK
    ACADWBLOCKDIALOG,  *WBLOCK
    ADCENTER,          *ADCENTER
    BMAKE,              *BLOCK
    BMOD,              *BLOCK
    BPOLY,              *BOUNDARY
    CONTENT,          *ADCENTER
    DDATTE,              *ATTEDIT
    DDIM,              *DIMSTYLE
    DDINSERT,          *INSERT
    DDPLOTSTAMP,      *PLOTSTAMP
    DDRMODES,          *DSETTINGS
    DDSTYLE,          *STYLE
    DDUCS,              *UCSMAN
    DDUCSP,              *UCSMAN
    DDUNITS,          *UNITS
    DDVIEW,              *VIEW
    DIMHORIZONTAL,      *DIMLINEAR
    DIMROTATED,          *DIMLINEAR
    DIMVERTICAL,      *DIMLINEAR
    DOUGHNUT,          *DONUT
    DTEXT,              *TEXT
    DWFOUT,              *PLOT
    DXFIN,              *OPEN
    DXFOUT,              *SAVEAS
    PAINTER,          *MATCHPROP
    PREFERENCES,      *OPTIONS
    RECTANGLE,          *RECTANG
    SHADE,              *SHADEMODE
    VIEWPORTS,          *VPORTS
    ; MCAD aliases
    ; Command names with MCAD prefixes are LISP defined commands.
    AA,  *AMDTAA
    B,  *BREAK
    BB,  *AMDTBB
    CC,  *AMUPDATE
    D,  *AMDTD
    DD,  *AMDTDD
    EE,  *AMFILLET
    F,  *AMDTF
    FF,  *AMDTFF
    G,  *AMEXTRUDE
    GG,  *AMREVOLVE
    HH,  *AMHOLE
    II,  *AMPARDIM
    J,  *AMDTJ
    JJ,  *AMADDCON
    K,  *AMTWEAK
    KK,  *AMDELTWEAKS
    LL,  *AMEDITFEAT
    MM,  *COPY
    N,  *AMNEW
    NN,  *AMCATALOG
    OO,  *3DORBIT
    PP,  *AMPROFILE
    Q,  *AMDWGVIEW
    QQ,  *AMEDITVIEW
    RR,  *REGENALL
    S,  *SPLINE
    SS,  *AMSKPLN
    TT,  *TRIM
    UU,  *AMDTUU
    VV,  *AMVISIBLE
    W,  *AMDTW
    WW,  *AMVARS
    X,  *AMDTX
    XX,  *AMDTXX
    Y,  *AMTRAIL
    YY,  *AMDELTRAIL
    ZZ,  *AMDTZZ
    1,  *AMDT1
    2,  *AMDT2
    3,  *AMDT3
    4,  *AMDT4
    5,  *AMDT5
    55,  *AMDT55
    6,  *AMDT6
    66,  *AMDT66
    7,  *AMDT7
    77,  *AMDT77
    8,  *AMDT8
    88,  *AMDT88
    9,  *AMDT9
    0,  *HIDE
    [,  *AMDT[
    ],  *AMDT]
    =,  *AMDT=
    -,  *AMDT-
    5U,  *AMDT5U
    6U,  *AMDT6U
    7U,  *AMDT7U
    5D,  *AMDT5D
    6D,  *AMDT6D
    7D,  *AMDT7D
    PD,     *ampowerdim
  • 您需要登录后才可以回帖 登录 | 注册
    GMT+8, 2025-4-18 23:36 , Processed in 0.021001 second(s), 11 queries , Gzip On, Redis On.
