【原创】【分享】GPost(SPost)釋意與教程
 关闭 [复制链接]
91
发表于 2004-3-29 10:32:13 | 只看该作者
在Spost中应设置: Correct
发表于 2004-3-29 10:45:01 | 只看该作者
在mpost中,可以设置:
Ctrcode I J
ctrincrement? N
如:
name Fadal Format 1 with Sub Programs Calls
% 00
! 00
/ 00
O >4
N >4
Sequence#s N 0 1 1                    # Char, freq, incr & start
First#? N                             # Y or N  'Output 1st sequence no.
Last#? N                              # Y or N  'Output last sequence no.
Inc/Abs G 91 90                       # Inc & Abs char. & values
CtrCode I J                           # I J or R or I J K L
CtrIncremental? Y                     # Y or N  'Inc or abs I & J
ByQuadrants? N                        # Y or N  'Break arcs at quadrants
Subs1st? Y                            # Y or N 'Orders main & sub programs
UppercaseComments? Y                  # Y or N 'Require uppercase comments
WorkDefault 1                         # Work offset register default
93
发表于 2004-3-29 11:14:57 | 只看该作者
zzhzzhzzh wrote:
在mpost中,可以设置:
  Ctrcode I J
  ctrincrement? N
  如:
  % 00
  ! 00
  / 00
  O >4
  N >4
CtrIncremental? N
94
发表于 2004-4-8 18:39:46 | 只看该作者
请问SURFCAM处理后的NCC文件怎么样才能和MASTERCAM的NC文件一样自动显出刀具信息?
如下图
发表于 2004-4-10 00:46:46 | 只看该作者
用GPost的話 ----- 寫FIL
用MPost的話 ----- 改xxxxx.M3 or xxxx.M4
GMT+8, 2025-4-27 05:21 , Processed in 0.024019 second(s), 10 queries , Gzip On, Redis On.
