返回列表 发新帖
求UG18的FANAC 的後處理器
发表于 2002-8-25 19:54:33 | 只看该作者
# Description
#     This is the event handler file for generic 3axis mill
# Revisions
#   Date        Who   Reason
# 02-jul-1998   whb   Original
# 31-jul-1998   whb   make system independent
# 26-aug-1998   dty   Add path for ugpost_base.tcl
# 02-dec-1998   bmp   Modified the path for sourced files
# 06-feb-1999   Binu  Changed the environment varibale UGII_CAM_RESOURCE to
#                     UGII_CAM_RESOURCE.
# 24-mar-1999   DTY   Remove source paths
# 20-apr-1999   whb   fix I J K output for arcs
# 01-jun-1999   whb   fix MOM_sequence_number
# 21-Jun-1999   whb   check equality within tolerance ('EQ')
# 27-Jul-1999   whb     add CHECK_OPER_TYPE
# 31-Jan-2000   whb   add nurbs, make corrections for a working post.
# $HISTORY$
# EVENT HANDLER SECTION
#   This section contains the control section for mill3ax post processor.
#   This program logic determinies the output to the post processor file.
#   The following procedures are performed in the order the events are
#   generated.
#______________________________________________________________________________
#The following command invokes the debugging mode.
#       source [MOM_ask_env_var UGII_CAM_DEBUG_DIR]mom_debug.tcl
#        source [MOM_ask_env_var UGII_CAM_DEBUG_DIR]mom_review.tcl
#********Setting the debug mode ON/OFF
#        MOM_set_debug_mode ON
#The following command invokes the warning mode and the default settings.
         source [MOM_ask_env_var UGII_CAM_POST_DIR]ugpost_base.tcl
#The following file consists of default values set for G & M codes
#********M code declaration
  set mom_kin_min_arc_length      0.001
#   set mom_kin_arc_output_mode        "QUADRANT"
         set mom_sys_program_stop_code              0
         set mom_sys_optional_stop_code             1
         set mom_sys_end_of_program_code            30
         set mom_sys_spindle_direction_code(CLW)    3
         set mom_sys_spindle_direction_code(CCLW)   4
         set mom_sys_spindle_direction_code(OFF)    5
         set mom_sys_tool_change_code               6
         set mom_sys_coolant_code(MIST)             7
         set mom_sys_coolant_code(FLOOD)            8
         set mom_sys_coolant_code(TAP)              8
         set mom_sys_coolant_code(OFF)              9
         set mom_sys_clamp_code(ON)                 10
         set mom_sys_clamp_code(OFF)                11
         set mom_sys_clamp_code(AXISON)             10
         set mom_sys_clamp_code(AXISOFF)            11
#********G code declaration
         set mom_sys_rapid_code                     0
         set mom_sys_linear_code                    1
         set mom_sys_circle_code(CLW)               2
         set mom_sys_circle_code(CCLW)              3
         set mom_sys_delay_code(REVOLUTIONS)        4
         set mom_sys_delay_code(SECONDS)            4
         set mom_sys_nurbs_precision_code           5
         set mom_sys_nurbs_code                     6.2
         set mom_sys_cutcom_plane_code(XY)          17
         set mom_sys_cutcom_plane_code(ZX)          18
         set mom_sys_cutcom_plane_code(YZ)          19
         set mom_sys_cutcom_code(OFF)               40
         set mom_sys_cutcom_code(LEFT)              41
         set mom_sys_cutcom_code(RIGHT)             42
         set mom_sys_inch_code                      70
         set mom_sys_metric_code                    71
         set mom_sys_cycle_breakchip_code           73
         set mom_sys_cycle_bore_no_drag_code        76
         set mom_sys_cycle_off                      80
         set mom_sys_cycle_drill_code               81
         set mom_sys_cycle_drill_dwell_code         82
         set mom_sys_cycle_drill_deep_code          83
         set mom_sys_cycle_tap_code                 84
         set mom_sys_cycle_bore_code                85
         set mom_sys_cycle_bore_drag_code           86
         set mom_sys_cycle_bore_back_code           87
         set mom_sys_cycle_bore_manual_code         88
         set mom_sys_cycle_bore_manual_dwell_code   89
         set mom_sys_cycle_bore_dwell_code          89
         set mom_sys_output_code(ABSOLUTE)          90
         set mom_sys_output_code(INCREMENTAL)       91
#_______________________________________________________________________________
# Kinematic Declarations
         set mom_kin_machine_type                   3_axis_mill
         set mom_kin_machine_resolution             .0001
         set mom_kin_nurbs_output_type              BSPLINE
# Global Variable Declaration
         set mom_sys_list_file_columns              132
         set mom_sys_list_file_rows                 50
         set mom_sys_commentary_output              OFF
         set mom_sys_list_output                    OFF
         set mom_sys_group_output                   OFF
         set nurbs_move_flag                        0
         set nurbs_knot_count                       0
         set anchor_flag                            0
         set coolant_flag                           0
         set mom_tool_number                        0
         set mom_spindle_rpm                        0
# Machine Time Variable Declaration
   global accumulated_time
         set accumulated_time 0
proc  MOM_start_of_program {} {
# This procedure is executed at the very begining of the program.
# It gets called before any command is read from the task file.
         global mom_seqnum
         global mom_part_name
         global mom_logname
         global mom_date
         global mom_spindle_speed
         global mom_output_file_basename
#********The following procedure opens the warning and listing files
         OPEN_files
#********The following procedure lists the header information in commentary data
         LIST_FILE_HEADER
#  MOM_set_seq_off
  set mom_seqnum 100
#         MOM_output_literal "(TASK  : $mom_part_name)"
#         MOM_output_literal "(Created By   : $mom_logname)"
#         MOM_output_literal "(Creation Date: $mom_date)"
         MOM_suppress always N
         MOM_output_literal "%"
#         MOM_output_literal "G00 G40 G80 G54 G90"
#         MOM_output_literal "(PROGRAM NAME - $mom_output_file_basename)"
          MOM_output_literal "O0000"
          MOM_suppress off    N
#          MOM_output_literal "G90G80G00G17G40"
#          MOM_output_literal "G21"
#    MOM_output_literal "G0G90G17"
proc  MOM_start_of_path {} {
# This procedure is executed at the begining of each path in the task
# It gets called after all the general parameters of the path are loaded
# like the path name and the tool name.
         global mom_path_name
         global mom_tool_name
         global mom_tool_length_adjust_register
         global mom_tool_corner1_radius
         global mom_tool_diameter
         global mom_tool_number
#        MOM_set_seq_off
         MOM_output_literal "(----------------------------------------------------)"
         MOM_output_literal "(Start: $mom_path_name with tool: $mom_tool_name)"
         MOM_output_literal "(Tool Name - $mom_tool_name)"
         MOM_output_literal "(Tool Diameter - [ format  "%.2f" $mom_tool_diameter])"
         MOM_output_literal "(Tool Radius - [ format  "%.2f" $mom_tool_corner1_radius])"
#      MOM_output_literal "(TOOL - [ format "%1d" $mom_tool_number] DIA. - [ format "%.2f" $mom_tool_diameter])"
       MOM_suppress off    N
         CHECK_OPER_TYPE
proc  MOM_tool_change {} {
# This procedure is executed at any time there is a tool change.
# It gets called after the tool change data is loaded like the tool number
# and the register numbers.
        global first_tool
        set first_tool 0
proc  MOM_first_tool {} {
# This procedure is executed for the first operation, with a tool, in the task.
        global first_tool
        set first_tool 1
proc  MOM_initial_move {} {
# This procedure is executed for the initial move of each operation.  It assumes
# the tool is moving from a safe position at rapid to the start of the operation.
        global   mom_tool_number mom_next_tool_number
        global   mom_coolant_status mom_coolant_mode
        global   mom_spindle_rpm
        global   mom_warning_info
        global   anchor_flag
        global   coolant_flag
        global first_tool
        set anchor_flag 1
  #      if { [info exists mom_tool_number] == 0 } {
  #         set mom_warning_info "TOOL NUMBER NOT SET, DEFAULTING TO 0"
  #         MOM_catch_warning
  #         set mom_tool_number 0
       if {$coolant_flag == 1} {
            if {$mom_coolant_mode == "" && $mom_coolant_status == "SAME"} {
                set mom_coolant_mode FLOOD
            if {$mom_coolant_status != "OFF"} {
                set mom_coolant_status $mom_coolant_mode
                MOM_force once coolant_m
#      if {$first_tool == 0} {
#            MOM_spindle_off
#            MOM_coolant_off
#     MOM_force once T M
#  MOM_do_template tool_change
        MOM_force once motion_g H G X Y S spindle_m
                MOM_force once S spindle_m
                MOM_do_template spindle_start
#        if {[info exists mom_spindle_rpm] != 0} {
#            if {$mom_spindle_rpm != 0} {
#                MOM_force once S spindle_m
#                MOM_do_template spindle_start
#            } else {
#                set mom_warning_info "SPINDLE RPM IS 0"
#                MOM_catch_warning
  MOM_force once length_g H Z
  MOM_suppress once motion_g
  MOM_do_template rapid_z
      MOM_do_template rapid_xy
proc  MOM_first_move {} {
# This procedure is executed before the motion event is activated.
         global mom_motion_event
      #      } else {
      #          MOM_catch_warning
      #   catch {MOM_$mom_motion_event}
proc  MOM_linear_move {} {
# This procedure is executed for each linear move. It gets called after
# the positioning varables, position and tool axis (X,Y,Z,TAX,TAY,TAZ) are loaded.
         global mom_cutcom_mode
         global mom_cutcom_status
         global   anchor_flag
         global tempxpos
         global tempypos
     global tempzpos
         global mom_pos
         set tempxpos $mom_pos(0)
         set tempypos $mom_pos(1)
         set tempzpos $mom_pos(2)
         set      anchor_flag 1
         if {$mom_cutcom_status == "ON"} {
            set mom_cutcom_status $mom_cutcom_mode
         } elseif {$mom_cutcom_status == "OFF"} {
            MOM_suppress once cutcom_g
         MOM_do_template linear
proc  MOM_circular_move {} {
# This procedure is executed for each circular move. It gets called after
# the circle data are loaded (end point and center).
         global mom_pos_arc_axis
         global g_plane
         global mom_cutcom_status mom_cutcom_mode
         global   anchor_flag
         global tempxpos
         global tempypos
         global mom_pos
   global tempzpos
        set checkfull 0
  #        set a [expr $mom_pos(0)-$tempxpos]
  #        set b [expr $mom_pos(1)-$tempypos]
#   set c [expr $mom_pos(2)-$tempzpos]
         set      anchor_flag 1
#   if {[expr abs($a)] == 0.0 && [expr abs($b)] == 0.0 && [expr abs($c)] == 0.0} {set checkfull 1}
#&nbsp;&nbsp; if {[expr abs($a)] < 0.001 && [expr abs($b)] < 0.001 && [expr abs($c)] < 0.001 && $checkfull == 0} {
#&nbsp;&nbsp; &nbsp;&nbsp;return}
&nbsp;&nbsp; set tempxpos $mom_pos(0)
&nbsp;&nbsp; set tempypos $mom_pos(1)
&nbsp;&nbsp; set tempzpos $mom_pos(2)
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {$mom_cutcom_status == "ON"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set mom_cutcom_status $mom_cutcom_mode
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_cutcom_status == "OFF"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress once cutcom_g
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {[EQ_is_equal abs($mom_pos_arc_axis(2)) 1.0]} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set g_plane "17"
&nbsp;&nbsp;&nbsp;&nbsp; MOM_force once X Y motion_g I J
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress once K
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {[EQ_is_equal abs($mom_pos_arc_axis(1)) 1.0]} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set g_plane "18"
&nbsp;&nbsp;&nbsp;&nbsp; MOM_force once X Z motion_g I K
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress once J
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {[EQ_is_equal abs($mom_pos_arc_axis(0)) 1.0]} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set g_plane "19"
&nbsp;&nbsp;&nbsp;&nbsp; MOM_force once Y Z motion_g J K
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress once I
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template circle
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress off motion_g X Y Z I J K R
proc  MOM_helix_move {} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_pos_arc_axis
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global g_plane
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_cutcom_status mom_cutcom_mode
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global   anchor_flag
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set      anchor_flag 1
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress always K
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress always J
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress always I
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template helix
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress off I J K
proc  MOM_rapid_move {} {
# This procedure is executed for each rapid move. It gets called after
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_last_pos
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_coolant_mode
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set mom_coolant_status $mom_coolant_mode
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {[EQ_is_gt $mom_pos(2) $mom_last_pos(2)]} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {![EQ_is_zero [expr ($mom_pos(2)-$mom_last_pos(2))]]} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template rapid_z
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {![EQ_is_zero [expr (abs($mom_pos(0)-$mom_last_pos(0))+abs($mom_pos(1)-$mom_last_pos(1)))]]} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template rapid_xy
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} else {
proc  MOM_end_of_path {} {
# This procedure is executed at the end of a path.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_path_name
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global nurbs_move_flag
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {$nurbs_move_flag == 1} {MOM_output_literal "G05 P0"}
#        MOM_set_seq_off
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress once length_g H coolant_m
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_force once Z
#         MOM_spindle_off
#&nbsp;&nbsp;MOM_output_literal "M09"
  #        MOM_output_literal "(End Of Path $mom_path_name)"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set nurbs_move_flag 0
# Machine Time
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_machine_time
&nbsp;&nbsp; global accumulated_time
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_operation_name
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set op_time [expr $mom_machine_time - $accumulated_time]
#         MOM_output_literal "(------------------------------------------)"
#MOM_output_literal "Operation    : $mom_operation_name"
#MOM_output_literal "Machine Time : [ format  "%.2f" $op_time]"
#         MOM_output_literal "([format "Operation: %s  Time: %.2f" $mom_operation_name $op_time])"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set accumulated_time $mom_machine_time
proc     MOM_end_of_program {} {
# This procedure is executed at the end of the program after all
# the paths are traversed.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_part_name
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template end_of_program
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_spindle_off
&nbsp;&nbsp;   MOM_coolant_off
#        MOM_set_seq_off
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress always N
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_output_literal "%"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_output_literal "(END OF TASK: $mom_part_name)"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_suppress off    N
# Machine Time
&nbsp;&nbsp; global mom_machine_time
&nbsp;&nbsp; MOM_suppress always N
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_output_literal "(==========================================)"
&nbsp;&nbsp; MOM_output_literal "(TOTAL Machine Time: [ format  "%.2f" $mom_machine_time])"
&nbsp;&nbsp; MOM_output_literal "(------------------------------------------)"
#********The following procedure lists the tool list with time in commentary data
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LIST_FILE_TRAILER
#********The following procedure closes the warning and listing files
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLOSE_files
proc MOM_nurbs_move {} {
# This procedure is executed for each nurbs move.
&nbsp;&nbsp;global mom_nurbs_knot_count
&nbsp;&nbsp;global mom_nurbs_point_count
&nbsp;&nbsp;global mom_nurbs_order
&nbsp;&nbsp;global nurbs_knot_count
&nbsp;&nbsp;global nurbs_precision
&nbsp;&nbsp;if {$nurbs_move_flag == 0} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set nurbs_precision 10000
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template nurbs_start
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set nurbs_move_flag 1
&nbsp;&nbsp;}
&nbsp;&nbsp;FEEDRATE_SET
&nbsp;&nbsp;if {$anchor_flag == 1} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template anchor_point
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set anchor_flag 0
&nbsp;&nbsp;}
&nbsp;&nbsp;set nurbs_knot_count 0
&nbsp;&nbsp;MOM_set_address_format motion_g nurb_code
&nbsp;&nbsp;MOM_force once motion_g order X Y Z
&nbsp;&nbsp;while {$nurbs_knot_count < $mom_nurbs_point_count} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template nurbs
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set nurbs_knot_count [expr $nurbs_knot_count + 1]
&nbsp;&nbsp;}
&nbsp;&nbsp;while {$nurbs_knot_count < $mom_nurbs_knot_count} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template knots
&nbsp;&nbsp;}
&nbsp;&nbsp;MOM_set_address_format motion_g Register_2
proc  MOM_before_output {} {
# This procedure is executed just before a line is about to be output
# to the file. It loads the line into a variable MOM_o_buffer and then calls
# this procedure. When it returns from this procedure, the variable MOM_o_buffer
# is read and written to the file.
#########The following procedure invokes the listing file with warnings.
&nbsp;&nbsp;&nbsp;&nbsp;global mom_seqnum
&nbsp;&nbsp;&nbsp;&nbsp;if { $mom_seqnum == 10000 } { set mom_seqnum 100 }
proc  cycle_set {} {
# This procedure is executed for each new cycle.  This will make sure all
# non-modal addresses and Cycle parameters are output that need to be output
# at the start of a new cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_cycle_retract_mode
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global g_return
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_force once motion_g X Y Z R cycle_dwell cycle_nodrag cycle_step
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {$mom_cycle_retract_mode == "MANUAL"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set g_return 99
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_cycle_retract_mode == "AUTO"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set g_return 98
proc  MOM_cycle_plane_change {} {
# This procedure is executed at the end of cycle motion when there is a cycle
# move occuring at a higher level than the previous position.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template cycle_plane_change
proc  MOM_cycle_off {} {
# This procedure is executed at the end of cycle motion.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template cycle_off
proc  MOM_drill {} {
# This procedure is executed at the begining of a drill cycle.
&nbsp;&nbsp; cycle_set
proc  MOM_drill_move {} {
# This procedure is executed for the goto of a drill cycle.
&nbsp;&nbsp; MOM_do_template cycle_drill
proc  MOM_drill_dwell {} {
# This procedure is executed at the begining of a drill dwell cycle.
proc  MOM_drill_dwell_move {} {
# This procedure is executed for the goto of a drill dwell cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MOM_do_template cycle_drill_dwell
proc  MOM_drill_counter_sink {} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_drill
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
proc  MOM_drill_counter_sink_move {} {
&nbsp;&nbsp; MOM_drill_move
proc  MOM_drill_csink_dwell {} {
&nbsp;&nbsp; MOM_drill_dwell
proc  MOM_drill_csink_dwell_move {} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MOM_drill_dwell_move
proc  MOM_drill_deep {} {
# This procedure is executed at the begining of a deep cycle.
proc  MOM_drill_deep_move {} {
# This procedure is executed for the goto of a  deep cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MOM_do_template cycle_drill_deep
proc  MOM_drill_break_chip {} {
# This procedure is executed at the begining of a brkchp cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; cycle_set
proc  MOM_drill_break_chip_move {} {
# This procedure is executed for the goto of a  brkchp cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MOM_do_template cycle_breakchip
proc  MOM_tap {} {
# This procedure is executed at the begining of a tap cycle.
proc  MOM_tap_move {} {
# This procedure is executed for the goto of a tap cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MOM_do_template cycle_tap
proc  MOM_bore {} {
# This procedure is executed at the begining of a bore cycle.
proc  MOM_bore_move {} {
# This procedure is executed for the goto of a bore cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template cycle_bore
proc  MOM_bore_dwell {} {
proc  MOM_bore_dwell_move {} {
# This procedure is executed for the goto of a bore dwell cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template cycle_bore_dwell
proc  MOM_bore_drag {} {
# This procedure is executed at the begining of a bore drag cycle.
proc  MOM_bore_drag_move {} {
# This procedure is executed for the goto of a bore_drag cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template cycle_bore_drag
proc  MOM_bore_no_drag {} {
# This procedure is executed at the begining of a bore nodrag cycle.
proc  MOM_bore_no_drag_move {} {
# This procedure is executed for the goto of a bore nodrag cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MOM_do_template cycle_bore_no_drag
proc  MOM_bore_back {} {
# This procedure is executed at the begining of a bore back cycle.
proc  MOM_bore_back_move {} {
# This procedure is executed for the goto of a back bore cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MOM_do_template cycle_bore_back
proc  MOM_bore_manual {} {
# This procedure is executed at the begining of a bore manual cycle.
proc  MOM_bore_manual_move {} {
# This procedure is executed for the goto of a manual bore cycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MOM_do_template cycle_bore_manual
proc  MOM_bore_manual_dwell {} {
# This procedure is executed at the begining of a bore manual dwell bore cycle.
proc  MOM_bore_manual_dwell_move {} {
# This procedure is executed for the goto of a manual dwell borecycle.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; MOM_do_template cycle_bore_manual_dwell
proc  MOM_load_tool {} {
# This procedure is executed for the LOAD/TOOL command.  All output for the LOAD
# command will take place with the initial move.
proc  MOM_sequence_number {} {
# This procedure is executed for the Sequence Number command.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_sequence_mode
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_sequence_number
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_sequence_increment
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_sequence_frequency
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_sequence_text
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_warning_info
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {[isset mom_sequence_mode] == "y"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {$mom_sequence_mode == "OFF"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_set_seq_off
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_sequence_mode == "ON"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_sequence_mode == "AUTO"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set mom_warning_info \
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;"SEQNO/AUTO not implemented: Event Name: MOM_sequence_number"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_sequence_mode == "N"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_reset_sequence $mom_sequence_number $mom_sequence_increment \
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;$mom_sequence_frequency
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} else {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;"MOM_SEQUENCE_MODE UNKNOWN: Event Name: MOM_sequence_number"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_catch_warning
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_reset_sequence $mom_sequence_number $mom_sequence_increment $mom_sequence_frequency
proc  MOM_set_modes {} {
# This procedure is executed for the Set Mode command.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_output_mode
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_arc_mode
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_feed_rate_output_mode
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_parallel_to_axis
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_machine_mode
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global mom_modes_text
# "ABSOLUTE", "INCREMENTAL"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {$mom_output_mode == "ABSOLUTE"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_incremental OFF X Y Z
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_output_mode == "INCREMENTAL"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_incremental ON X Y Z
# "LINEAR", "CIRCULAR"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {$mom_arc_mode == "LINEAR"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_arc_mode == "CIRCULAR"} {
# "OFF", "IPM", "IPR", "MMPM", "MMPR", "INVERSE"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {$mom_feed_rate_output_mode == "FPM"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_feed_rate_output_mode == "FPR"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_feed_rate_output_mode == "INVERSE"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_feed_rate_output_mode == "OFF"} {
# "ZAXIS", "WAXIS", "UAXIS"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {$mom_parallel_to_axis == "ZAXIS"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_parallel_to_axis == "WAXIS"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_parallel_to_axis == "UAXIS"} {
# "MILL", "TURN", "UNCH", "LASER", "TORCH", "WIRE"
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if {$mom_machine_mode == "MILL"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_machine_mode == "TURN"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_machine_mode == "UNCH"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_machine_mode == "LASER"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_machine_mode == "TORCH"} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;} elseif {$mom_machine_mode == "WIRE"} {
proc  MOM_cutcom_on {} {
# This procedure is executed when the Cutcom command is activated.
proc  MOM_cutcom_off {} {
# This procedure is executed when the Cutcom command is deactivated.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template cutcom_off
proc  MOM_spindle_rpm {} {
# This procedure is executed when the Spindle command is activated.
proc  MOM_spindle_off {} {
# This procedure is executed when the Spindle command is deactivated.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template spindle_off
proc  MOM_coolant_on {} {
# This procedure is executed when the Coolant command is activated.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;global   coolant_flag
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;set coolant_flag 1
proc  MOM_coolant_off {} {
# This procedure is executed when the Coolant command is deactivated.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template coolant_off
proc  MOM_opstop {} {
# This procedure is executed when the Optional Stop command is activated.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template opstop
proc  MOM_stop {} {
# This procedure is executed when the Program Stop command is activated.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template stop
proc  MOM_opskip_on {} {
# This procedure is executed when the Optional skip command is activated.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_set_line_leader always "/"
proc  MOM_opskip_off {} {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_set_line_leader off "/"
proc  MOM_delay {} {
# This procedure is executed when the Delay command is activated.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_force_block Once delay
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOM_do_template delay
proc  MOM_auxfun {} {
# This procedure is executed when the Auxiliary command is activated.
发表于 2002-8-25 19:55:52 | 只看该作者
# Description
#     This is the definition file for mill3ax
# Revisions
#   Date        Who   Reason
# 31-jul-1998   whb   load_tool_number now tool_number
# 20-apr-1999   whb   feed rates are now feed(set in FEEDRATE_SET)
# 19-may-1999   whb   add opt for mom_cycle_delay
# 02-Jun-1999   whb   fix commentary
# 24-jun-1999   whb   convert FORMATS from % to & formats
#                     rename Socket_x FORMATS
# 29-jul-1999   vb    modify turret configuration
# 29-Jul-1999   whb   default Seqno to 5 digits, default Coordinate to 5 digits
# 24-Aug-1999   jm    Modify holding system in POCKET description
#                     to 330 (taper shank 50) so that some milling
#                     tools of the library fit.
# 31-aug-1999   mjr   Add holders 300,310,320 to all pockets. Increase pockets
#                     from 12 to 30 total.
# 02-Sep-1999   whb   remove carriage returns which were added by NT.
# 16-Nov-1999   gbs   Include the ude file for udes
# 25-Jan-2000   whb   update for usable output
# $HISTORY$
MACHINE mill3ax
INCLUDE
&nbsp;&nbsp;&nbsp;$UGII_CAM_USER_DEF_EVENT_DIR/ude.cdl
FORMATTING
  WORD_SEPARATOR     ""
  END_OF_LINE        ""
  SEQUENCE Seq_no    2 2 1
  FORMAT  Coordinate "&__5.3_"
  FORMAT  Dwell_sec  "&__3.3_"
  FORMAT  Spindle    "&__5_00"
  FORMAT  Seqno      "&__5_00"
  FORMAT  nurb_code  "&_02.1_"
  FORMAT  Register_2 "&_02_00"
  FORMAT  Register_3 "&_03_00"
  FORMAT  Register_5 "&_05_00"
  FORMAT  T_Register "&_02_00"
  FORMAT  Feed_IPM   "&__3.2_"
  FORMAT  Feed_IPR   "&__4.2_"
  FORMAT  Feed_MMPM  "&__5.1_"
  FORMAT  Feed_MMPR  "&__6.2_"
  FORMAT  Feed_FRN   "&__4.3_"
  FORMAT  Feed_INV   "&__6.2_"
  FORMAT  Feed_DPM   "&__6.2_"
  FORMAT  Feed       "&__7.1_"
  FORMAT  zero       "&_02_00"
  FORMAT  zero_coord "&_01.0_"
  FORMAT  zero_spin  "&_01_00"
  #FORMAT  zero_coord "%1d"
  FORMAT  EventNum   "%-5d"
  FORMAT  AbsCoord   "%9.4f"
  FORMAT  RotCoord   "%8.3f"
  FORMAT  ComFeed    "%7.2f"
  FORMAT  Rev        "%5d"
  FORMAT  Minutes    "%9.4f"
  ADDRESS N  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT Seqno
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORCE  off
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MAX    9999
  ADDRESS G  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT Register_2
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ZERO_FORMAT zero
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MIN    0
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORCE  always
  ADDRESS motion_g {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LEADER "G"
  ADDRESS length_g {
  ADDRESS plane_g {
  ADDRESS cutcom_g {
  ADDRESS return_g {
  ADDRESS mode_g {
  ADDRESS X  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ZERO_FORMAT zero_coord
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT Coordinate
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MAX    9999.9999
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MIN    -9999.9999
  ADDRESS Y  {
  ADDRESS Z  {
  ADDRESS A  {
  ADDRESS B  {
  ADDRESS C  {
  ADDRESS R  {
  ADDRESS I  {
  ADDRESS J  {
  ADDRESS K  {
  ADDRESS RISE  {
  ADDRESS cycle_dwell  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT Dwell_sec
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MAX    99999.999
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MIN    0.001
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LEADER ""
  ADDRESS dwell  {
  ADDRESS cycle_step  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LEADER "Q"
  ADDRESS cycle_nodrag  {
  ADDRESS F  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT Feed
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MIN    0.1
  ADDRESS S  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ZERO_FORMAT zero_spin
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT Spindle
  ADDRESS T  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT T_Register
  ADDRESS coolant_m  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LEADER "M"
  ADDRESS spindle_m  {
  ADDRESS M  {
  ADDRESS D  {
  ADDRESS H  {
  ADDRESS precision_g {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LEADER "G0"
  ADDRESS precision {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT Register_5
  ADDRESS nurbs_g {
  ADDRESS knot {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LEADER "K"
  ADDRESS order {
# Addresses for the lpt file output
  ADDRESS ENUM  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT EventNum
  ADDRESS ABSX  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT AbsCoord
  ADDRESS ABSY  {
  ADDRESS ABSZ  {
  ADDRESS AXIS4  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT RotCoord
  ADDRESS AXIS5  {
  ADDRESS FEED  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT ComFeed
  ADDRESS RPM  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT Rev
  ADDRESS TIME {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FORMAT Minutes
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE Seq_no  { N[$mom_seqnum]  }
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE from    {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;X[$mom_pos(0)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Y[$mom_pos(1)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Z[$mom_pos(2)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE rapid_xy {
#                                     mode_g[$mom_sys_output_code($mom_output_mode)]\opt
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_rapid_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;  #   G[15]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;  #   H[1]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;coolant_m[$mom_sys_coolant_code(FLOOD)]\opt
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;    }
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE rapid_z {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#           length_g[56]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#           H[$mom_tool_length_adjust_register]\opt
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_plane_change {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;X[$mom_cycle_clearance_pos(0)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Y[$mom_cycle_clearance_pos(1)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Z[$mom_cycle_clearance_pos(2)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE linear  {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;     cutcom_g[$mom_sys_cutcom_code($mom_cutcom_status)]\opt
#                                     plane_g[$mom_sys_cutcom_plane_code($mom_cutcom_plane)]\opt
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_linear_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;F[$feed]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;D[$mom_cutcom_adjust_register]\opt
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE circle  {
#                                     plane_g[$g_plane]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_circle_code($mom_arc_direction)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R[$mom_arc_radius]
#                                     I[$mom_pos_arc_center(0)-$mom_prev_pos(0)]
#                                     J[$mom_pos_arc_center(1)-$mom_prev_pos(1)]
#                                     K[$mom_pos_arc_center(2)-$mom_prev_pos(2)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE helix   {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;plane_g[$g_plane]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;I[$mom_pos_arc_center(0)-$mom_prev_pos(0)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;J[$mom_pos_arc_center(1)-$mom_prev_pos(1)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;K[$mom_pos_arc_center(2)-$mom_prev_pos(2)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;RISE[$mom_helix_pitch]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_drill {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_drill_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;X[$mom_cycle_feed_to_pos(0)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Y[$mom_cycle_feed_to_pos(1)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Z[$mom_cycle_feed_to_pos(2)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R[$mom_cycle_rapid_to_pos(2)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;           }
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_drill_dwell {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_drill_dwell_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;     cycle_dwell[$mom_cycle_delay]\opt
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_drill_deep {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_drill_deep_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;     cycle_step[$mom_cycle_step1]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_breakchip {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_breakchip_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_tap {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_tap_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_bore {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_bore_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_bore_dwell {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_bore_dwell_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_bore_drag {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_bore_drag_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_bore_no_drag {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_bore_no_drag_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;     cycle_nodrag[$mom_cycle_retract_to]\opt
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_bore_back {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_bore_back_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_bore_manual {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_bore_manual_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_bore_manual_dwell {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE cycle_off {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_cycle_off]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE nurbs_start {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;precision_g[$mom_sys_nurbs_precision_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;precision[$nurbs_precision]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE anchor_point {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;X[$mom_nurbs_points(0,0)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Y[$mom_nurbs_points(0,1)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Z[$mom_nurbs_points(0,2)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE nurbs {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;motion_g[$mom_sys_nurbs_code]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;order[$mom_nurbs_order]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;knot[$mom_nurbs_knots($nurbs_knot_count)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;X[$mom_nurbs_points($nurbs_knot_count,0)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Y[$mom_nurbs_points($nurbs_knot_count,1)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Z[$mom_nurbs_points($nurbs_knot_count,2)]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;F[$feed]\opt\nows
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE knots {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;knot[$mom_nurbs_knots($nurbs_knot_count)]\nows
#            BLOCK_TEMPLATE spindle_start  {
#                                            spindle_m[$mom_sys_spindle_direction_code($mom_spindle_direction)]
#                                            S[$mom_spindle_rpm]
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BLOCK_TEMPLATE spindle_start  {
&nbs
发表于 2002-8-25 19:59:16 | 只看该作者
# template_post config file - Event Handler and Definition files for
#                             Generic Machine
# REVISIONS
#   Date       Who           Reason
# 15-Nov-1999  Joachim Meyer Move WIRE EDM to top of the list.
#                            This is necessary because this list is the
#                            list of posts for the generic machine and thus
#                            the first post must not have any
#                            Turret/Pocket definitions.
# 28-Apr-2000  Satya         Added mill-turn posts to standard list of posts.
# 12-Sep-2000  whb           added mill3ax_nurbs
OKUMA_Mill_3Axis,${UGII_CAM_POST_DIR}Okuma.tcl,${UGII_CAM_POST_DIR}Okuma.def
发表于 2002-8-25 20:10:11 | 只看该作者
1=OKUMA.TCL 2=OKUMA.DEF 3=template_post.dat 做成文本文档放入
D:\UGS180\MACH\resource\postprocessor
OK
发表于 2002-10-26 21:28:55 | 只看该作者
我有。
大家还要什么,说不定我也有。
希望能广交朋友,我以前一般上海信。
  Email:mryjw163@163.com
发表于 2002-10-26 21:30:43 | 只看该作者
发表于 2002-10-26 21:31:21 | 只看该作者
发表于 2002-12-1 01:09:19 | 只看该作者
各为大师:我还不知如何在UGNX里调用,与MASTERCAM不一样,不象MASTERCAM改POST文件那样方便,能告诉我吗?谢谢!我后处理后,格式总不对,没有机械坐标G54,有M07又M08.
19
发表于 2005-12-3 13:11:35 | 只看该作者
good
20
发表于 2011-7-9 16:28:53 | 只看该作者
呆B
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
GMT+8, 2025-4-24 16:55 , Processed in 0.045856 second(s), 10 queries , Gzip On, Redis On.
