举报
iDesign wrote: Chain Selection -------------------------------------------------------------------------------- You can now chain select curves without using the Class Selection dialog. Just make sure Select General Objects is on, and select the first curve in the chain. Then place the cursor over the last curve you want to select in the chain, and use Alt Shift Select. 这个试验不出来,不知道什么原因?!
haha wrote: [quote]iDesign wrote: Chain Selection -------------------------------------------------------------------------------- You can now chain select curves without using the Class Selection dialog. Just make sure Select General Objects is on, and select the first curve in the chain. Then place the cursor over the last curve you want to select in the chain, and use Alt Shift Select. 这个试验不出来,不知道什么原因?!
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2025-4-14 03:04 , Processed in 0.031831 second(s), 12 queries , Gzip On, Redis On.
