123
返回列表 发新帖
[资料] 模具维修及总结
发表于 2012-12-10 10:11:26 | 只看该作者
  下来看看
22
发表于 2012-12-10 22:13:37 | 只看该作者
怎么下不了啊
23
发表于 2012-12-12 16:59:52 | 只看该作者
有没有塑胶的?
24
发表于 2012-12-12 18:08:13 | 只看该作者
下了,先谢谢了
25
发表于 2012-12-13 16:15:53 | 只看该作者
顶一下
26
发表于 2012-12-13 19:05:20 | 只看该作者
顶你!!!
27
发表于 2013-8-9 23:41:51 来自手机 | 只看该作者
下来看看
28
发表于 2014-4-20 13:23:04 | 只看该作者
冲压英语
冲压常词汇
stamping, press冲压
punch press, dieing out press冲床
uncoiler & strainghtener整平机
feeder送料机
rack, shelf, stack料架
cylinder油缸
robot机械手
taker取料机
conveyer belt输送带
transmission rack输送架
top stop上死点
bottom stop下死点
one stroke一行程
inch寸动
to continue, cont.连动
to grip(material)吸料
location lump, locating piece, block stop 定位块
reset复位
smoothly顺利
dent压痕
scratch刮伤
deformation变形
filings铁削
to draw holes抽孔
inquiry, search for查寻
to stock, storage, in stock库存
receive领取
approval examine and verify审核
processing, to process加工
delivery, to deliver 交货
to return delivenry to.
to send delinery back
to retrn of goods退货
registration登记
registration card登记卡
to control管制
to put forward and hand in提报
safe stock安全库存
acceptance = receive验收
to notice通知
application form for purchase请购单
consume, consumption消耗
to fill in填写
abrasion磨损
reverse angle = chamfer倒角
character die字模
to collect, to gather收集
failure, trouble故障
statistics统计
demand and supply需求
career card履历卡
to take apart a die卸下模具
to load a die装上模具
to tight a bolt拧紧螺栓
to looser a bolt拧松螺栓
to move away a die plate移走模板
easily damaged parts易损件
standard parts标准件
breaking.(be)broken,(be)cracked 断裂
to lubricate润滑
common vocabulary for die engineering
模具工程常用词汇
die 模具
figure file, chart file图档
cutting die, blanking die冲裁模
progressive die, follow (-on)die 连续模
compound die复合模
punched hole冲孔
panel board镶块
to cutedges=side cut=side scrap切边
to bending折弯
to pull, to stretch拉伸
Line streching, line pulling线拉伸
engraving, to engrave刻印
upsiding down edges翻边
to stake铆合
designing, to design设计
design modification设计变化
die block模块
folded block折弯块
sliding block滑块
location pin定位销
lifting pin顶料销
die plate, front board模板
padding block垫块
stepping bar垫条
upper die base上模座
lower die base下模座
upper supporting blank上承板
upper padding plate blank上垫板
spare dies模具备品
spring 弹簧
bolt螺栓
29
发表于 2014-6-1 23:14:49 | 只看该作者
学习了!!@
GMT+8, 2025-4-8 21:26 , Processed in 0.022685 second(s), 11 queries , Gzip On, Redis On.
