查看: 14559|回复: 8
[原创] 扩大一个片体并消参
发表于 2013-3-12 19:07:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
char *message="选择";
char *title="选择";
int  scope=UF_UI_SEL_SCOPE_NO_CHANGE;
int response;
tag_t object_tag;
double cursor[3];
tag_t view;
int type=0;
char * percent_size[4]={"0","0","0","0"};
double tolerance=0.02;
tag_t feat_obj_tag;
UF_UI_select_with_single_dialog (message,title,scope,set_selection_filter,NULL,&response,&object_tag,cursor,&view );
UF_DISP_set_highlight(object_tag,0);
UF_MODL_create_enlarge(object_tag,type,percent_size,tolerance,&feat_obj_tag );
但是创建完之后怎么把获得的片体消参。。。。、???求帮助。。谢谢了
发表于 2013-3-13 19:40:49 | 只看该作者
在ug中录制一段代码就行了,NXOPEN是将来的发展方向
发表于 2013-3-13 19:43:14 | 只看该作者
extern "C" DllExport void ufusr(char *param, int *retCode, int paramLen)
    Session *theSession = Session::GetSession();
    Part *workPart(theSession->Parts()->Work());
    Part *displayPart(theSession->Parts()->Display());
    //   Menu: Edit->Feature->Remove Parameters...
    Session::UndoMarkId markId1;
    markId1 = theSession->SetUndoMark(Session::MarkVisibilityVisible, "Start");
    Features::RemoveParametersBuilder *removeParametersBuilder1;
    removeParametersBuilder1 = workPart->Features()->CreateRemoveParametersBuilder();
    theSession->SetUndoMarkName(markId1, NXString("Remove Parameters \345\257\271\350\257\235\346\241\206", NXString::UTF8));
    Body *body1(dynamic_cast<Body *>(workPart->Bodies()->FindObject("UNPARAMETERIZED_FEATURE(0)")));
    bool added1;
    added1 = removeParametersBuilder1->Objects()->Add(body1);
    Session::UndoMarkId markId2;
    markId2 = theSession->SetUndoMark(Session::MarkVisibilityInvisible, "Remove Parameters");
    theSession->DeleteUndoMark(markId2, NULL);
    Session::UndoMarkId markId3;
    markId3 = theSession->SetUndoMark(Session::MarkVisibilityInvisible, "Remove Parameters");
    NXObject *nXObject1;
    nXObject1 = removeParametersBuilder1->Commit();
    theSession->DeleteUndoMark(markId3, NULL);
    theSession->SetUndoMarkName(markId1, "Remove Parameters");
    removeParametersBuilder1->Destroy();
    //   Menu: Tools->Journal->Stop Recording
发表于 2013-3-13 19:43:52 | 只看该作者
去掉其中的无用代码就行了
发表于 2013-3-13 20:31:49 | 只看该作者
zhangcanwei 发表于 2013-3-13 19:43
去掉其中的无用代码就行了
谢谢,但是有没有c语言函数?录制的是c++
发表于 2013-4-2 21:25:52 | 只看该作者
高手,学习了~~
发表于 2013-4-6 11:38:34 | 只看该作者
自己结贴,消参得获取到目标体的tag值,将feat_obj_tag转化为tag
发表于 2013-6-23 16:06:57 | 只看该作者
谢谢楼主,支持!!!!
发表于 2013-6-23 16:33:03 | 只看该作者
谢谢楼主,支持!!!!
GMT+8, 2025-4-18 16:11 , Processed in 0.030358 second(s), 13 queries , Gzip On, Redis On.
