查看: 14493|回复: 2
[求助] C#二次开发的菜单问题
发表于 2013-6-19 22:51:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
注册程序大致如下,想请教下,为什么在菜单上选择第二次 或者重新在菜单上选择另一项 UG便会直接崩溃退出!!十分棘手啊!!
            NXOpen.UF.UFMb.Action[] uaActions = new NXOpen.UF.UFMb.Action[7];
            uaActions[0].action_name = "ABOUT";
            uaActions[0].action_cb.cb = new UFMb.CallbackT(ABOUT);
            uaActions[1].action_name = "CONFIGURATION";
            uaActions[1].action_cb.cb = new UFMb.CallbackT(CONFIGURATION);
            uaActions[2].action_name = "CREATE_PART_CODE";
            uaActions[2].action_cb.cb = new UFMb.CallbackT(CREATE_PART_CODE);
            uaActions[3].action_name = "NEW_PART";
            uaActions[3].action_cb.cb = new UFMb.CallbackT(NEW_PART);
            uaActions[4].action_name = "DEL_PART";
            uaActions[4].action_cb.cb = new UFMb.CallbackT(DEL_PART);
            uaActions[5].action_name = "OPEN_PART";
            uaActions[5].action_cb.cb = new UFMb.CallbackT(OPEN_PART);
            uaActions[6].action_name = null;
            uaActions[6].action_cb = new NXOpen.UF.UFMb.Cb();
            uaActions[6].action_cb.cb = null;
            uaActions[6].action_cb.cb_data = System.IntPtr.Zero;
            ufs.Mb.AddActions(uaActions);
    static NXOpen.UF.UFMb.CbStatus ABOUT(IntPtr w, IntPtr client_data, IntPtr button)
        Class.Class1.About();
        return UFMb.CbStatus.CbContinue;
    static NXOpen.UF.UFMb.CbStatus CONFIGURATION(IntPtr w, IntPtr client_data, IntPtr button)
        Class.Class1.thedialog();
    static NXOpen.UF.UFMb.CbStatus CREATE_PART_CODE(IntPtr w, IntPtr client_data, IntPtr button)
        Class.Class1.theCreatPartCode();
    static NXOpen.UF.UFMb.CbStatus NEW_PART(IntPtr w, IntPtr client_data, IntPtr button)
        Class.Class1.prt_new();
    static NXOpen.UF.UFMb.CbStatus DEL_PART(IntPtr w, IntPtr client_data, IntPtr button)
        Class.Class1.deletePart();
    static NXOpen.UF.UFMb.CbStatus OPEN_PART(IntPtr w, IntPtr client_data, IntPtr button)
        Class.Class1.openPart();
发表于 2013-8-25 09:52:25 | 只看该作者
能否贴出整个源码啊!
发表于 2014-5-18 12:19:54 | 只看该作者
别人不支持,我先支持了
GMT+8, 2025-7-4 14:16 , Processed in 0.022875 second(s), 12 queries , Gzip On, Redis On.
