查看: 14007|回复: 0
[求助] 请教如何引用另一个part里的直线?
发表于 2013-7-28 19:03:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在part1里面建了草图并在草图里面建了几条直线。想在part2里面用part1里的线条做基准约束part2草图里面的直线。宏如下:
Language="VBSCRIPT"
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set product1 = productDocument1.Product
Set products1 = product1.Products
Set product2 = products1.AddNewComponent("Part", "")
Set documents1 = CATIA.Documents
Set partDocument1 = documents1.Item("Part2.CATPart")
Set partDocument0 = documents1.Item("Part1.CATPart")
Set part1 = partDocument1.Part
Set part0 = partDocument0.Part
Set bodies0 = part0.Bodies
Set body0 = bodies0.Item("零件几何体")
Set sketches0 = body0.Sketches
Set sketch0 = sketches0.Item("草图.1")
Set bodies1 = part1.Bodies
Set body1 = bodies1.Item("零件几何体")
Set sketches1 = body1.Sketches
Set originElements1 = part1.OriginElements
Set reference1 = originElements1.PlaneXY
Set sketch1 = sketches1.Add(reference1)
Dim arrayOfVariantOfDouble1(8)
arrayOfVariantOfDouble1(0) = 0.000000
arrayOfVariantOfDouble1(1) = 0.000000
arrayOfVariantOfDouble1(2) = 0.000000
arrayOfVariantOfDouble1(3) = 1.000000
arrayOfVariantOfDouble1(4) = 0.000000
arrayOfVariantOfDouble1(5) = 0.000000
arrayOfVariantOfDouble1(6) = 0.000000
arrayOfVariantOfDouble1(7) = 1.000000
arrayOfVariantOfDouble1(8) = 0.000000
sketch1.SetAbsoluteAxisData arrayOfVariantOfDouble1
part1.InWorkObject = sketch1
Set factory2D1 = sketch1.OpenEdition()
Set geometricElements1 = sketch1.GeometricElements
Set axis2D1 = geometricElements1.Item("绝对轴")
Set line2D1 = axis2D1.GetItem("横向")
line2D1.ReportName = 1
Set line2D2 = axis2D1.GetItem("纵向")
line2D2.ReportName = 2
Set point2D1 = factory2D1.CreatePoint(51.876303, -14.673396)
point2D1.ReportName = 3
Set point2D2 = factory2D1.CreatePoint(128.967033, 77.136205)
point2D2.ReportName = 4
Set line2D3 = factory2D1.CreateLine(51.876303, -14.673396, 128.967033, 77.136205)
line2D3.ReportName = 5
line2D3.StartPoint = point2D1
line2D3.EndPoint = point2D2
Set geometricElements0 = sketch0.GeometricElements
Set Line2D0=geometricElements0.item("直线.2")
Set reference0 = part0.CreateReferenceFromObject(Line2D0)
Set geometricElements2 = factory2D1.CreateProjections(reference0)
Set geometry2D1 = geometricElements2.Item("标记.1")
geometry2D1.Construction = True
Set constraints1 = sketch1.Constraints
Set reference3 = part1.CreateReferenceFromObject(geometry2D1)
Set reference4 = part1.CreateReferenceFromObject(line2D3)
Set constraint1 = constraints1.AddBiEltCst(catCstTypePerpendicularity, reference3, reference4)
constraint1.Mode = catCstModeDrivingDimension
sketch1.CloseEdition
part1.InWorkObject = body1
part1.UpdateObject sketch1
End Sub
里面Set geometricElements2 = factory2D1.CreateProjections(reference0) 这里报错,有人能指点一下吗?高手一般怎么引用呢?
谢谢。
GMT+8, 2025-4-6 13:25 , Processed in 0.027452 second(s), 13 queries , Gzip On, Redis On.
