[原创] Solidworks拼图打印程序(源码公布)
发表于 2014-2-13 19:19:03 | 只看该作者
  1. Imports System.Drawing
  2. Imports System.Drawing.Graphics
  3. Module PictureRelated
  4.     Sub joinPicture()
  5.         '每一张大图
  6.         Dim mm As Integer = 1
  7.         For Each ds As ptPaper In FinalPapers
  8.             '图片大小
  9.             newBMape = New Bitmap(CInt(841 * intDPI / 25.4), CInt(594 * intDPI / 25.4))
  10.             '设置分辨率
  11.             newBMape.SetResolution(intDPI, intDPI)
  12.             g1 = Graphics.FromImage(newBMape)
  13.             g1.Clear(Color.White)
  14.             For Each sdraw As SwDraw In ds.inNerPapers
  15.                 myImage = Image.FromFile(sdraw.drawDir)
  16.
  17.                 If sdraw.PaperSize = "A2" Then
  18.                     myImage.RotateFlip(RotateFlipType.Rotate90FlipNone)
  19.                     '如果是A2,则宽高翻转,同时将图像进行90度翻转
  20.                     theHeight = CInt(sdraw.drawWidth * intDPI / 25.4)
  21.                     theWidth = CInt(sdraw.drawHeight * intDPI / 25.4)
  22.
  23.                 Else
  24.                     theHeight = CInt(sdraw.drawHeight * intDPI / 25.4)
  25.                     theWidth = CInt(sdraw.drawWidth * intDPI / 25.4)
  26.
  27.                 End If
  28.                 If sdraw.PaperSize = "A4" Then
  29.                     theX = CInt(sdraw.insertPosX * intDPI * 210 / 25.4)
  30.                     theY = CInt(sdraw.insertPosY * intDPI * 297 / 25.4)
  31.                 End If
  32.                 If sdraw.PaperSize = "A3" Then
  33.                     theX = CInt(sdraw.insertPosX * intDPI * 210 / 25.4)
  34.                     theY = CInt(sdraw.insertPosY * intDPI * 297 / 25.4)
  35.                 End If
  36.                 If sdraw.PaperSize = "A2" Then
  37.                     theX = CInt(sdraw.insertPosX * intDPI * 210 / 25.4)
  38.                     theY = CInt(sdraw.insertPosY * intDPI * 297 / 25.4)
  39.                 End If
  40.
  41.                 g1.DrawImage(myImage, theX, theY)
  42.                 myImage.Dispose()
  43.             Next
  44.             If Form1.CBoxPaperSize.SelectedIndex = 1 Then
  45.                 newBMape.RotateFlip(RotateFlipType.Rotate90FlipNone)
  46.             End If
  47.             If Form1.CBoxPrint.Checked = True Then
  48.                 printThepaper()
  49.             End If
  50.             If Form1.CBoxPicSave.Checked = True Then
  51.                 newBMape.Save(Application.StartupPath + "\outputimage\xx" + mm.ToString + ".jpg", System.Drawing.Imaging.ImageFormat.Jpeg)
  52.             End If
  53.             mm += 1
  54.             g1.Dispose()
  55.             newBMape.Dispose()
  56.         Next
  57.
  58.     End Sub
  59. End Module
复制代码
发表于 2014-2-13 19:19:46 | 只看该作者
  1. Imports System.IO
  2. Imports System.Drawing.Printing
  3. Module printRelated
  4.     Sub printThepaper()
  5.         If Form1.CBoxPaperSize.SelectedIndex = 0 Then
  6.             PgSize = New PaperSize("myA1", 3311, 2339)
  7.
  8.         Else
  9.             PgSize = New PaperSize("myA2", 2339, 3311)
  10.
  11.         End If
  12.         PTResolution = New PrinterResolution
  13.         If Form1.RadioButtonHigh.Checked Then
  14.             PTResolution.Kind = PrinterResolutionKind.High
  15.         End If
  16.         If Form1.RadioButtonFollowDpi.Checked Then
  17.             PTResolution.Kind = PrinterResolutionKind.Custom
  18.             PTResolution.X = intDPI
  19.             PTResolution.Y = intDPI
  20.         End If
  21.         PT1.DefaultPageSettings.PaperSize = PgSize
  22.         PT1.DefaultPageSettings.PrinterResolution = PTResolution
  23.         PT1.Print()
  24.     End Sub
  25. End Module
复制代码
发表于 2014-2-13 19:20:26 | 只看该作者
  1. Public Class ptPaper
  2.
  3.     '每个图纸里的小图纸
  4.     Public inNerPapers As swDrawsAll
  5. End Class
复制代码
发表于 2014-2-13 19:20:52 | 只看该作者
  1. Public Class ptPaperAll
  2.     Inherits CollectionBase
  3.     Public Sub Add(ByVal newPaper As ptPaper)
  4.         Me.List.Add(newPaper)
  5.     End Sub
  6.     Public Sub Remove(ByVal oldPaper As ptPaper)
  7.         Me.List.Remove(oldPaper)
  8.     End Sub
  9.     Default Public Property Item(ByVal index As Integer) As ptPaper
  10.         Get
  11.             Return CType(Me.List(index), ptPaper)
  12.         End Get
  13.         Set(value As ptPaper)
  14.             Me.List.Item(index) = value
  15.         End Set
  16.     End Property
  17. End Class
复制代码
发表于 2014-2-13 19:21:14 | 只看该作者
  1. Public Class SwDraw
  2.     Public drawDir As String   'directory of a drawing
  3.     Public drawSheetName As String   'sheet of a drawing  工程图文件中的图纸1,图纸2,等等
  4.     Public drawHeight As Single     '图纸的大小
  5.     Public drawWidth As Single
  6.     Public PaperSize As String
  7.     Public mysheet As SldWorks.Sheet
  8.     Public sheetCount As Integer
  9.     Public paperNumber As Integer      '位于第几张图纸
  10.     Public insertPosX As Integer        '在图纸中插入时的位置编号
  11.     Public insertPosY As Integer        '在图纸中插入时的位置编号
  12. End Class
复制代码
发表于 2014-2-13 19:21:42 | 只看该作者
  1. Public Class swDrawsAll
  3.     Public Sub Add(ByVal newDraw As SwDraw)
  4.         Me.List.Add(newDraw)
  5.     End Sub
  6.     Public Sub Remove(ByVal oldDraw As SwDraw)
  7.         Me.List.Remove(oldDraw)
  8.     End Sub
  9.     Default Public Property Item(ByVal index As Integer) As SwDraw
  10.         Get
  11.             Return CType(Me.List(index), SwDraw)
  12.         End Get
  13.         Set(value As SwDraw)
  15.         End Set
  16.     End Property
  17. End Class
复制代码
发表于 2014-2-13 19:22:09 | 只看该作者
  1. Imports SwConst
  3. Imports SldWorks
  4. Imports System.IO
  5. Module swRelated
  6.     Public Sub loadsw()
  7.         ReDim SwFinalFiles(Form1.ListBox1.Items.Count - 1)
  8.         '将列表装入数组
  9.         For ix As Integer = 0 To SwFinalFiles.GetUpperBound(0)
  10.             SwFinalFiles(ix) = Form1.ListBox1.Items(ix)
  11.         Next
  12.         If SwFinalFiles.Length <> 0 Then
  13.             Form1.PSbar1.Maximum = SwFinalFiles.GetUpperBound(0)
  14.             Form1.PSbar1.Minimum = 0
  15.             swApp = New SldWorks.SldWorks
  16.             If Form1.CboxShowSW.Checked = True Then
  17.                 swApp.Visible = True
  18.             Else : swApp.Visible = False
  19.             End If
  20.             MsgBox("即将开始,建议关闭所有程序以保证足够内存")
  21.             Dim i As Integer
  22.             For i = 0 To SwFinalFiles.GetUpperBound(0)
  23.                 Try
  24.                     Form1.PSbar1.Value = i
  25.                     swMod = swApp.OpenDoc(SwFinalFiles(i), 3)
  26.                     swDoc = swMod
  27.                     '图片颜色变成黑白
  28.                     boolstatus = swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swTiffImageType, swTiffImageType_e.swTiffImageBlackAndWhite)
  29.                     '图片分辨率设为选定值
  30.                     boolstatus = swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swTiffPrintDPI, intDPI)
  31.                     '图片存放的目录全名
  32.                     intSheetCount = swDoc.GetSheetCount   '文件中图纸数量
  33.                     mysheet = swDoc.GetSheetNames     '图纸名称列表
  34.                     For j As Integer = 0 To intSheetCount - 1
  35.                         '获取图纸的大小尺寸
  36.                         tmpInt = swDoc.Sheet(mysheet(j).ToString).GetSize(stWidth, stHeight)
  37.                         stWidth = stWidth * 1000
  38.                         stHeight = stHeight * 1000
  39.                         If stHeight = 594 Or stHeight = 841 Then
  40.                             Form1.ListLargePapers.Items.Add(SwFinalFiles(i))
  41.                             Exit For
  42.                         End If
  43.                         If stHeight = 210 Or stHeight = 297 Then
  44.                             '选择了直接出图,并且选择的是A4和A3的图纸,
  45.                             If Form1.CBoxEnable.Checked = True Then
  46.                                 '选择打印机
  47.                                 swMod.Printer = Form1.cbxPtA4.SelectedItem
  48.                                 '设置页面参数
  49.                                 Dim a As PageSetup
  50.                                 a = swMod.PageSetup
  51.                                 a.HighQuality = True
  52.                                 a.ScaleToFit = True
  53.                                 Dim tt As Boolean
  54.                                 a.DrawingColor = swPageSetupDrawingColor_e.swPageSetup_BlackAndWhite
  55.                                 a.PrinterPaperSize = PaperKind.A4
  56.                                 tt = a.UsePageSetupOnSheets()
  57.                                 If stWidth = 297 Or stWidth = 210 Then  'A4图纸
  58.                                     swMod.PrintDirect()
  59.                                 End If
  60.                                 If stWidth = 420 Then  'A3图纸
  61.                                     swMod.PrintOut(j + 1, j + 1, 1, False, swMod.Printer, 0.67, False)
  62.                                 End If
  63.                             Else
  64.                                 '将图纸录入集合
  65.                                 swSingleDraw = New SwDraw
  66.                                 tmpSavefile = Application.StartupPath & "\OutputImage" & i.ToString & _
  67.                              mysheet(j).ToString & ".tif"
  68.                                 swMod.SaveAs(tmpSavefile)   '保存成jpg文件
  69.                                 With swSingleDraw
  70.                                     .drawDir = tmpSavefile
  71.                                     .drawHeight = stHeight
  72.                                     .drawWidth = stWidth
  73.                                 End With
  74.                                 If stWidth = 210 Then
  75.                                     swSingleDraw.PaperSize = "A4"
  76.                                 End If
  77.                                 If stWidth = 420 Then
  78.                                     swSingleDraw.PaperSize = "A3"
  79.                                 End If
  80.                             End If
  81.                         End If
  82.                         '如果是A2的尺寸,处理同上。
  83.                         If stHeight = 420 Then
  84.                             '将图纸录入集合
  85.                             swSingleDraw = New SwDraw
  86.                             tmpSavefile = Application.StartupPath & "\OutputImage" & i.ToString & _
  87.                         mysheet(j).ToString & ".tif"
  88.                             swMod.SaveAs(tmpSavefile)   '保存成TIF文件
  89.                             With swSingleDraw
  90.                                 .drawDir = tmpSavefile
  91.                                 .drawHeight = stHeight
  92.                                 .drawWidth = stWidth
  93.                             End With
  94.                             If stWidth = 594 Then
  95.                                 swSingleDraw.PaperSize = "A2"
  96.                             End If
  97.                         End If
  98.                         '录入完毕,图纸尺寸全部放入到了对象swSingleDraw中
  99.                         swDrawCollecton.Add(swSingleDraw)
  100.                         swDoc.SheetNext()
  101.                     Next
  102.                     swApp.CloseDoc(SwFinalFiles(i))
  103.                     swDoc = Nothing
  104.                     swMod = Nothing
  105.                 Catch ex As Exception
  106.                 End Try
  107.             Next
  108.
  109.             getA2s()
  110.             fillPaper()
  111.             joinPicture()
  112.             MsgBox("successed!")
  113.         Else : MsgBox("list not exist")
  114.         End If
  115.     End Sub
  116. End Module
复制代码
18
发表于 2014-2-13 19:34:27 | 只看该作者
各个控件的名称。
参与人数 1技术 +3 贡献 +10 收起 理由
Francis + 3 + 10 感激不盡!
19
发表于 2014-2-13 20:47:46 | 只看该作者
最好版主研究下能解决A3 A4自动识别图幅自动打印成需要的图幅的问题那就完美了
20
发表于 2015-3-27 20:55:55 | 只看该作者
请问楼主,您发的附件是已经进行了更新的吗?
GMT+8, 2025-4-21 14:28 , Processed in 0.027831 second(s), 13 queries , Gzip On, Redis On.
