查看: 30092|回复: 53
【讨论】用Mold Adviser 6.0和Part Adviser 6.0这里报名讨论
发表于 2002-9-2 17:45:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天似乎sw没有人气。这个模块我也不熟悉,是注塑分析模块,刚才随便弄了几下出来一个报告,全当关税。给大家看看
MOLDFLOW PLASTICS ADVISERS REPORT
1Prepared By: lhg
Prepared for: idesign
Date: 02-09-2002
Introduction
Summary
Release Level: 6.0
cover_results-2
Part Name: cover2
Material Supplier: DSM
Material Grade: Stamylan P 16M10
Max Injection Pressure: 100.00 MPa
Mold Temperature: 40.00 deg.C
Melt Temperature: 230.00 deg.C
Model Suitability: Part model was highly suitable for analysis.
cover_results-2
Moldability: Your part can be easily filled but part quality may be unacceptable.
View the Quality plot and use the Dynamic Adviser to get help on how to improve the quality of the part.
Confidence: Medium
Injection Time: 0.36 sec
Injection Pressure: 26.07 MPa
Weld Lines: Yes
Air Traps: Yes
Shot Volume : 14.51 cu.cm
Filling Clamp Force: 9.77 tonne
Packing Clamp Force Estimate @20%: ( 5.21 )MPa 2.89 tonne
Packing Clamp Force Estimate @80%: ( 20.86 )MPa 11.54 tonne
Packing Clamp Force Estimate @120%: ( 31.28 )MPa 17.31 tonne
Clamp Force Area: 54.27 sq.cm
Cycle Time: 12.00 sec
Warnings:
cover_results-2
Cooling Quality: Your part has some small problems and may not cool satisfactorily.
Temperature Range: -3.93 deg.C to 6.64 deg.C
Freeze Time Range: -1.17 sec to 2.16 sec
cover_results-2
Sinkability: 3 % of your model was found to be prone to sink marks.
发表于 2002-9-2 17:49:38 | 只看该作者
Glass Model:P
发表于 2002-9-2 17:51:51 | 只看该作者
Solid Model
发表于 2002-9-2 17:52:46 | 只看该作者
Plastic Flow
发表于 2002-9-2 18:04:41 | 只看该作者
Fill Time8D8D8D8D
发表于 2002-9-2 18:04:57 | 只看该作者
2Confidence of Fill
发表于 2002-9-2 18:20:04 | 只看该作者
Injection Pressure
发表于 2002-9-2 18:20:23 | 只看该作者
Pressure Drop
发表于 2002-9-2 18:20:34 | 只看该作者
Flow Front Temp
发表于 2002-9-2 18:21:21 | 只看该作者
Quality Prediction
GMT+8, 2025-4-4 01:25 , Processed in 0.023676 second(s), 10 queries , Gzip On, Redis On.
