123
返回列表 发新帖
【分享】Surfcam Tips 小技巧
发表于 2005-5-23 19:33:11 | 只看该作者
2 Axis Milling: Air Wall
How to machine open pockets:
There are situations when one needs to machine steps or "open pockets" on parts. A commonality between these features is that they are not entirely closed. The "missing" walls are commonly referred to as "check" or "air" walls. SURFCAM allows for easy machinery of these part features. A detailed explanation of the entire process and examples will be discussed below.
Steps to machine this feature in SURFCAM:
Using 2-Axis Contour, select the blue inner profile "A" as shown above; note that by default the Select Chain mode is set to "art"
Change mode to Material and then select the red profile "B", which defines the shape of the air wall
Press Done for chain selections and the 2-Axis Contour dialog box will appear
On the [Tool Info] tab page set the tool, feeds and speeds
On the [Cut Control] tab it is critical that the "Amount to Remove - On Sides" is set to a value that is greater than the distance from the part to the material boundary
Press OK, the resulting tool path is shown in the rightmost picture
发表于 2005-6-1 10:10:50 | 只看该作者
21樓, 上面功能, 我做的AVI 教程
壓縮檔一
发表于 2005-6-1 10:12:59 | 只看该作者
壓縮檔二
发表于 2005-6-8 08:57:44 | 只看该作者
Adjusting Arc Centers in Edit NC
Question:
My file looks correct in SURFCAM but after posting and Back Plotting in Edit NC, large arcs appear in the Back Plotted code.
Answer:
The default for the Back Plot arc center option is set to "Auto". This means that the editor tries to determine arc center location methods automatically i.e. “I,J relative to start point”, “I,J absolute”, etc. This is possible for the vast majority of arcs, unfortunately there is no perfect method for doing this. In cases like this where the user suspects a problem with the Backplot, the arc center type should be set manually. To set this option, select ANALYSIS > BACKPLOT > SETUP > BASIC OPTIONS > select “Relative To Start Point” for the “I,J,K Usage On G2/G3:”.
25
发表于 2005-7-9 14:48:57 | 只看该作者
更改4 Axis後處理 MPost的參數 --- MOD命令的應用:
在surfcam四軸後處理 xxxxx.M4裡, 以4軸 A軸為例,
通常位址碼設置如下:
% 00
/ 00
O >4
N >4
G >2
g >2 G
X ->4.>3
Y ->4.>3
Z ->4.>3
z ->4.>3 Z
A ->3.>3
I ->4.>3
J ->4.>3
K ->4.>3
當你連續切削往往A軸較度值在後面會出現非常大的值(不管是正值 或 負值)
例如: X45.34 Y22.343 Z40. A-99998.945 機床就會報警..
可以更改控制器A軸參數 讓A軸 一直都是 0 -- 359.999 或 0 --- -359.99 然後又是 0 --- 359.999 或 0 --- -359.999,
也就上面那行程序變成
X45.34 Y22.343 Z40. A-278.945
在Surfcam的後處理文件 在A軸位址碼那行要加入MOD命令 如下:
% 00
/ 00
O >4
N >4
G >2
g >2 G
X ->4.>3
Y ->4.>3
Z ->4.>3
z ->4.>3 Z
A ->3.>3 mod 360
I ->4.>3
J ->4.>3
K ->4.>3
26
发表于 2005-7-9 15:03:54 | 只看该作者
原來後處理出來的 程序:
O1
G17 G40 G80 G90
G91 G28 Z0
N1 T12 M6
( Tool Radius 5. Tool Diam 10. Corner Rad. 5. )
M3 S7958
G0 G90 G54 X-200.089 Y40.621 A-81.655
G43 Z66. H12
M8
G0 Z6.835
G1 Z4.335 F1114.120
Y38.121
X-200.116 Y37.705 Z4.28 A-81.735 F2387.400
X-200.14 Y37.289 Z4.231 A-81.81
X-200.159 Y36.873 Z4.182 A-81.885
X-200.168 Y36.457 Z4.134 A-81.96
Y35.833 Z4.063 A-82.072
X-200.163 Y34.793 Z3.948 A-82.259
X-200.155 Y33.128 Z3.771 A-82.558
X-200.147 Y31.462 Z3.603 A-82.856
X-200.133 Y28.307 Z3.309 A-83.422
X-200.118 Y25.149 Z3.046 A-83.987
X-200.117 Y24.79 Z3.018 A-84.051
X-200.102 Y21.628 Z2.789 A-84.616
X-200.089 Y18.464 Z2.592 A-85.181
X-200.075 Y15.297 Z2.425 A-85.745
X-200.062 Y12.128 Z2.29 A-86.31
X-200.059 Y11.417 Z2.264 A-86.437
X-200.046 Y8.247 Z2.168 A-87.002
X-200.033 Y5.076 Z2.102 A-87.567
X-200.02 Y1.905 Z2.068 A-88.132
X-200.008 Y-1.265 Z2.065 A-88.698
X-200.005 Y-1.977 Z2.068 A-88.824
X-199.993 Y-5.146 Z2.103 A-89.39
X-199.982 Y-8.314 Z2.17 A-89.955
X-199.977 Y-9.51 Z2.203 A-90.169
X-199.975 Y-10.293 Z2.233 A-90.341
X-199.966 Y-10.428 Z2.091 A-89.557
X-199.969 Y-10.47 Z2.143 A-89.844
X-199.98 Y-10.479 Z2.341 A-90.925
X-200.001 Y-10.441 Z2.723 A-93.015
X-200.039 Y-10.321 Z3.383 A-96.656
X-200.059 Y-10.231 Z3.748 A-98.697
X-200.098 Y-10.02 Z4.421 A-102.507
X-200.135 Y-9.767 Z5.056 A-106.184
X-200.177 Y-9.424 Z5.76 A-110.396
X-200.217 Y-9.031 Z6.437 A-114.608
X-200.256 Y-8.591 Z7.084 A-118.823
X-200.291 Y-8.138 Z7.657 A-122.758
X-200.327 Y-7.609 Z8.236 A-126.986
X-200.361 Y-7.038 Z8.775 A-131.225
X-200.393 Y-6.427 Z9.272 A-135.473
X-200.416 Y-5.938 Z9.62 A-138.708
X-200.444 Y-5.27 Z10.031 A-142.936
X-200.47 Y-4.573 Z10.393 A-147.174
X-200.492 Y-3.849 Z10.703 A-151.427
X-200.506 Y-3.33 Z10.888 A-154.397
X-200.524 Y-2.573 Z11.105 A-158.646
X-200.539 Y-1.801 Z11.266 A-162.889
X-200.551 Y-1.02 Z11.369 A-167.13
X-200.558 Y-0.418 Z11.409 A-170.365
X-200.564 Y0.373 Z11.41 A-174.615
X-200.567 Y1.162 Z11.352 A-178.87
X-200.567 Y1.945 Z11.237 A-183.131
X-200.565 Y2.542 Z11.108 A-186.419
X-200.559 Y3.304 Z10.891 A-190.688
X-200.55 Y4.046 Z10.618 A-194.946
X-200.538 Y4.765 Z10.293 A-199.193
X-200.528 Y5.291 Z10.013 A-202.398
X-200.511 Y5.962 Z9.597 A-206.644
X-200.493 Y6.536 Z9.183 A-210.46
X-200.471 Y7.141 Z8.677 A-214.712
X-200.449 Y7.631 Z8.207 A-218.375
X-200.423 Y8.159 Z7.624 A-222.619
X-200.394 Y8.642 Z7.006 A-226.851
X-200.364 Y9.077 Z6.355 A-231.073
X-200.338 Y9.388 Z5.817 A-234.419
X-200.305 Y9.729 Z5.126 A-238.577
X-200.271 Y10.014 Z4.414 A-242.718
X-200.236 Y10.244 Z3.685 A-246.847
X-200.213 Y10.363 Z3.205 A-249.521
X-200.184 Y10.46 Z2.62 A-252.745
X-200.174 Y10.462 Z2.427 A-253.804
X-200.169 Y10.374 Z2.325 A-254.365
X-200.174 Y10.091 Z2.454 A-253.645
X-200.169 Y9.463 Z2.422 A-253.834
X-200.157 Y7.697 Z2.375 A-254.15
X-200.136 Y4.535 Z2.316 A-254.714
X-200.116 Y1.371 Z2.287 A-255.279
X-200.111 Y0.632 Z2.285 A-255.411
X-200.091 Y-2.533 Z2.295 A-255.976
X-200.071 Y-5.698 Z2.336 A-256.541
X-200.067 Y-6.433 Z2.349 A-256.672
X-200.047 Y-9.598 Z2.429 A-257.236
X-200.028 Y-12.765 Z2.539 A-257.801
X-200.009 Y-15.931 Z2.68 A-258.365
X-199.991 Y-19.096 Z2.853 A-258.929
X-199.983 Y-20.552 Z2.942 A-259.188
X-199.965 Y-23.712 Z3.16 A-259.752
X-199.947 Y-26.864 Z3.409 A-260.317
X-199.93 Y-30.008 Z3.69 A-260.883
X-199.913 Y-33.144 Z4.002 A-261.45
X-199.905 Y-34.629 Z4.161 A-261.719
X-199.896 Y-36.387 Z4.337 A-262.003
X-199.888 Y-37.938 Z4.383 A-262.079
X-199.883 Y-38.018 Z5.48 A-263.732
X-199.877 Y-37.869 Z7.056 A-266.111
X-199.868 Y-37.443 Z9.587 A-269.96
X-199.861 Y-36.85 Z12.082 A-273.809
X-199.858 Y-36.508 Z13.261 A-275.65
X-199.852 Y-35.67 Z15.689 A-279.504
X-199.848 Y-34.67 Z18.055 A-283.356
X-199.844 Y-33.122 Z21.04 A-288.399
X-199.843 Y-31.762 Z23.226 A-292.259
X-199.843 Y-30.261 Z25.316 A-296.118
X-199.844 Y-28.623 Z27.299 A-299.976
X-199.846 Y-26.856 Z29.17 A-303.838
X-199.85 Y-24.966 Z30.918 A-307.702
X-199.855 Y-22.965 Z32.532 A-311.56
X-199.858 Y-21.76 Z33.403 A-313.791
X-199.864 Y-19.594 Z34.799 A-317.656
X-199.871 Y-17.343 Z36.044 A-321.516
X-199.881 Y-14.291 Z37.433 A-326.544
X-199.889 Y-11.875 Z38.313 A-330.396
X-199.898 Y-9.398 Z39.029 A-334.254
X-199.906 Y-6.869 Z39.579 A-338.12
X-199.911 Y-5.586 Z39.79 A-340.06
X-199.919 Y-3.19 Z40.067 A-343.673
X-199.929 Y-0.96 Z40.189 A-347.061
X-199.941 Y0.933 Z40.19 A-350.012
X-199.956 Y2.242 Z40.127 A-352.249
X-199.966 Y2.255 Z40.116 A-352.534
X-199.994 Y1.119 Z40.133 A-351.969
X-199.996 Y0.974 Z40.133 A-351.976
X-199.998 Y0.566 Z40.133 A-352.028
X-199.982 Y-1.929 Z40.123 A-351.64
X-199.98 Y-2.09 Z40.127 A-351.729
X-199.979 Y-0.58 Z40.185 A-354.199
X-199.979 Y1.471 Z40.161 A-357.355
X-199.98 Y3.72 Z40.006 A-360.771
X-199.982 Y6.366 Z39.653 A-364.779
X-199.985 Y8.9 Z39.138 A-368.649
X-199.988 Y11.388 Z38.453 A-372.513
X-199.992 Y13.82 Z37.603 A-376.376
X-199.996 Y16.189 Z36.591 A-380.239
27
发表于 2005-7-9 15:04:28 | 只看该作者
更改後處理後 所產生的 程式:
O1
G17 G40 G80 G90
G91 G28 Z0
N1 T12 M6
M3 S7958
G43 Z66. H12
M8
G0 Z6.835
G1 Z4.335 F1114.120
Y38.121
X-199.98 Y3.72 Z40.006 A-0.771
X-199.982 Y6.366 Z39.653 A-4.779
X-199.985 Y8.9 Z39.138 A-8.649
X-199.988 Y11.388 Z38.453 A-12.513
X-199.992 Y13.82 Z37.603 A-16.376
X-199.996 Y16.189 Z36.591 A-20.239
28
发表于 2005-7-14 09:22:45 | 只看该作者
英制程序變成公制程序:
有些加工程序是由美國或加拿大的英制國家的客戶所提供, 但是操機者希望用公制的程序, Surfcam自帶的NC編輯器可以在裡面將英制程序變成公制程序
GMT+8, 2025-2-2 16:33 , Processed in 0.024291 second(s), 8 queries , Gzip On, Redis On.
