查看: 8395|回复: 0
[转贴] Solid Edge ST7 发布 MP10
发表于 2015-10-8 11:18:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
向所有关注【SolidEdge联盟】的朋友们致敬!
【Solid Edge联盟】自2015年2月26日创建以来,历经九个月的发展,在长假后的第一天上班,关注者突破1000人!
我们会继续努力,发表更加优质的信息,与大家共享!
--------------Legal Notices--------------�2015 Siemens Product Lifecycle Management Software Inc.All Rights ReservedSoftware, file formats, and audiovisual displays may be used pursuant to the applicable Software License Agreement and contain confidential and proprietary information of Siemens Product Lifecycle Management Software Inc.; which is protected by copyright and trade secret law. Such materials may not be reproduced or transferred to other documents or used or disclosed to others for manufacturing or for any other purpose except as specifically authorized within the terms of the Software License Agreement, or as specifically authorized in writing by Siemens Product Lifecycle Management Software Inc.Siemens Product Lifecycle Management Software Inc.5800 Granite ParkwaySuite 600Plano, TX. 75024--------------------End of Legal Notices----------------------------------Release Notes:--------------Product:  ST7 MP10Version:  107.00.10.02- Maintenance Pack Executables (.exe files) patch existing product dlls. MaintenancePack executables are all inclusive and can be installed on top of a base release or any released Maintenance Pack.- Maintenance Pack Installs (.zip files) are complete product setups. Therefore, existing versions must be uninstalled using Add/Remove Programs from the Control Panel prior to installing the new setup.- Maintenance Packs are available up to a maximum of 15 months following the release date of the English version. The English version of Solid Edge ST7 was released on 25-Jul-2014 making the Maintenance Pack cutoff date 25-Oct-2015.--------------------End of Release Notes---------------------------------------Installation Notes:-------------------There were SEEC policy file updates in MP2. It�s vitally important that you install SEEC Administrator, which delivers the policy files to TC_DATA.- Maintenance Pack Executables (.exe files): After downloading the Maintenance Pack to your machine and dbl click on exe to install.- Maintenance Pack Installs (.zip files): After downloading the Maintenance Pack to your machine, extract the zip file contents and dbl click on the setup.exe to install.-------------------End of Installation---------------------------------------------------------------------This Maintenance Pack addresses the following PRs:--------------------------------------------------===API=== PR 7467945: Need a method to kill a command from the BeforeCommandRun event===Assembly=== PR 1989085: Setting subassembly as adjustable and assemble it cause that patterned parts be PR 7383011: femap running in background, locking up my assemblyPR 7478836: Solid Edge Physical Properties not matching results from APIPR 7453978: Hole Feature recompute Fails in certain casesPR 7475687: Interpart Project with offset giving incorrect result===Draft=== PR 7376599: Honor hidden explode flow line in drawing views with explode configurationsPR 7445736: undesirable segments remained after converting a view to 2dPR 7454662: a custom property named "Positionsnummer" does not work anymore since ST6PR 7460592: If there is not 3D model, the dimensions of the Dft file movePR 7467096: Problem with dimension placementPR 7476472: Dimensions disappear when they open the Dft file in "Inactive"PR 7479182: When there is not 3D model/ open Inactive, Feature Control Frame becomes longerPR 7481474: Parts List item numbers are N/A on file open when file is opened inactivePR 7488330: Linear dimension moves if draft file opened without 3D data /Inactivate dwg viewPR 7494666: When there is not 3D model, the dimension movesPR 8508749: Dimension moves far away when used attach dimensionPR 8510182: Linear dimension moves if draft file opened without 3D data /Inactivate dwg viewPR 7400253: Fixed sectioning failures for some modelsPR 7495622: Parts List not displaying frame items===Part/Profile/Sheet Metal=== PR 7448157: sheet metal part can no longer be editedPR 7510126: Not possible to connect to multiple elements===Insight===PR 7450577: Sporadic error message when creating a copy of a dft file with Revision Manager===Insight Connect===PR 7481541: API Regression since ST 7 MP7 concerning Revman===Solid Edge SP, Server, Standalone Client, Solid Edge Client===PR 7462078: Custom Properties can't be added to the BOM Report===Solid Edge Embedded Client===PR 1996834: Document Name formula problem within API, window will not updatePR 7429671: Initial value required attribute not available in ATT InteractivePR 7428885: Create a new part returns a TC error===Translators===PR 7465071: Dxfout - Save As Flat: Etch Text alignment (Centered) exported as left justified---End ---
GMT+8, 2025-4-5 03:17 , Processed in 0.019960 second(s), 11 queries , Gzip On, Redis On.
