1.执行pqmgr,用qadd命令增加一个队列.以下是我的建立队列(可参考)
Enter Queue Name (16 Char. Max.)
Default = PDF_A4
Enter Despooler Name (8 Char. Max.)
Default = UGIIPS
Enter Plotter Vendor (16 Char. Max.)
Default = POSTSCRIPT
Enter Plotter Type (E=Electrostatic; P=Pen)
Default = E
Enter Plotter Model (16 Char. Max.)
Default =
Enter Plotter Switches (132 Char. Max.)
Default = /AR/A4/MO
Enter Media Control (C=Continuous; N=Non-Continuous)
Default = C
Enter Distance Between Plots
Default = 0
1 = Direct
2 = System Queue
3 = Disk File
4 = Both Direct And File
5 = Both Queue And File
Enter Output Mode
Default = 3
Enter Directory Pathname (132 Char. Max.)
Default = G:\UG_FILE\UG_PLOT_FILE
Enter Message Com Line (16 Char. Max.)
Default =
Enter Steps Per Inch
Default = 1440
PDF_A4
Despooler Name = UGIIPS
 lotter Vendor = POSTSCRIPT
 lotter Type = Electrostatic
Number Of Pens = 8
Controller ID =
 lotter Model =
 lotter Switches = /AR/A4/MO
Media Control = Continuous Form
Distance Between Plots = 0
Output Mode = Disk File
 lotter Com Line =
System Queue Name =
Directory Pathname = G:\UG_FILE\UG_PLOT_FILE
Tape Density = 1600
Message Interval =
Message Com Line =
Horizontal Maximum = 0
Vertical Maximum = 0
Steps Per Inch = 1440
Optimization Level = None
