【讨论】热水煲、咖啡机、面包机等电热产品出产时要通过那些测试
发表于 2004-3-11 13:48:01 | 只看该作者
coffee maker test:
1.Power Input
The power input to an appliance shall not be more than 105 or less than 90 percent of its marked rating.
2.Leakage Current Test
  not be more than:
a) 0.5 mA for an ungrounded (2-wire) appliance,
b) 0.5 mA for a grounded (3-wire) appliance that is easily carried or conveyed by hand, and
c) 0.75 mA for a grounded (3-wire) permanently connected appliance, or a cord connected appliance that is intended to be fastened in place or located in a dedicated space and employing a standard attachment plug rated 20 A or less.
3.Resistance of Grounding Test
  The resistance between the point of connection of the equipment-grounding means at or within the appliance and any other point in the grounding circuit of the appliance shall not exceed 0.1 ohms.
4.Operational Tests
5.Normal Temperature Tests
6.Leakage Current as a Result of Moisture Tests
7.Dielectric Voltage-Withstand Test
  An appliance shall be capable of withstanding for 1 min without an indication of unacceptable performance, the application of a potential applied between live parts and accessible metal parts. The appliance is to be at its maximum normal operating temperature. The test potential shall be 1000 V.
8.Broken Element Test
9.Strain Relief Test
  The strain-relief means provided on an attached flexible cord, shall be capable of withstanding for 1 min, without displacement, a pull of 35 lbf (156 N) applied to the cord, with the connections within the appliance disconnected.
10.Metal Enclosure Impact Tests
   Each of three samples of the appliance is to be subjected to one impact. This impact is to beimparted by dropping or swinging a 2-inch (50.8-mm) diameter steel sphere, weighing 1.18 lbf (0.535 kg) from a height that will produce an impact of 1.5 ft-lbf (2.03 J). The sample is to be rigidly supported and the impact is to be made perpendicular to the most vulnerable spots on the appliance enclosure that are exposed to a blow during intended use.
11.Thermal Degradation
12.Handle Securement Tests
13.Loading Test
14.Abnormal Operation Tests
15.Automatic Controls Test
16.Permanence of Marking Tests
发表于 2004-3-11 15:06:18 | 只看该作者
请教一下楼手的高手,热水煲的底座,煲身一般用什么材料.
发表于 2004-3-11 16:43:38 | 只看该作者
高温PP
发表于 2004-3-13 20:17:48 | 只看该作者
一般的pp都可以使用,pp的玻璃化温度都比较高;
1、共聚级pp
     材料的性能比较好,相对比较稳定,缩水小,食品级的比较多;
2、拉丝级pp
     一般以国内的杨子F401和韩国的4017为代表,特点是流动性能好,价格比较便宜。
底座的材料由于涉及到热变形影响大小的问题,只是要求从颜色和价格来考虑
1、一般使用黑色或比较深的颜色,使用一级回料PP
2、比较浅的颜色使用新料PP
3、由于有的底座有可能发生平面变形,采用PC+ABS或PC+AS(当然是回料)
     也可以使用PP+填充剂。
发表于 2006-7-21 11:09:17 | 只看该作者
原帖由 hjk5135 于 2004-3-7 12:49 发表
1 功能试验
2 干烧试验
3 防漏水试验
4 电气绝缘和泄露电流试验
5 输入功率和电流试验
6 发热试验
7  防水、防潮试验
8 绝缘电阻和电气强度试验
9 非正常工作试验
10  稳定性和机械危险试验
如果能够分别对各个测试项目进行说明怎么测试,怎么样才算合格,怎么样不合格就更好了,期待!!!!1
发表于 2006-7-21 11:22:39 | 只看该作者
讲得好!以前搞咖啡机时好多东西不懂
发表于 2006-12-6 22:05:44 | 只看该作者
原帖由 海风吹乱了头发 于 2004-3-11 13:09 发表
热水煲、咖啡机美规是UL1084,面包机美规是UL1026.
热水煲、咖啡机欧规是EN60335-2-15,面包机欧规是EN60335-2-9.
咖啡机美规是UL1082吧,如果我没有记错的话
18
发表于 2006-12-6 22:05:59 | 只看该作者
19
发表于 2006-12-6 22:13:19 | 只看该作者
thks
20
发表于 2006-12-6 22:33:43 | 只看该作者
本人从事水煲,咖啡机,多士炉多年了,
为WHEERPOOL,CUISINART,SALTON等大品牌做过多款产品。
纠正一下这个兄弟的说法:
水煲、咖啡机美规是UL1082
各位兄弟若需要这方面的资料,请与我联系:pebsi@163.com
GMT+8, 2025-2-5 09:08 , Processed in 0.022749 second(s), 9 queries , Gzip On, Redis On.
