查看: 18322|回复: 14
【求助】怎么把skim提刀的路经post成G00
发表于 2004-3-9 12:04:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如下图示范‘
粉色的抬刀为G01加F值的方法post出来的。。。
默认最大F为9999.0
我怎么把skim提刀的刀路post成G00?
发表于 2004-3-9 12:07:13 | 只看该作者
To obtain a feedrate output in the Rapid G0 block it will be necessary to add / modify the option " define block move rapid" to include an " ; F ", and to insure that " rapid feed code = 1 "  is include in the option
From DUCTpost1300 version there will be a variable defined for this feedrate, " Srat", which will allow a little more flexibility in manipulating this function.
An example of this is if the skim move is to be classed as a Rapid Non Linear G0 move instead of a G1 move.
The following illustrates how this may be achieved.
define block move linear
    if (  feedrate => srat  )
      N ; G1 0 ; X ; Y ; Z  ; M1 ; M2   ## Rapid Skim as RAPID
    else
      N ; G1  ; X ; Y ; Z ; F ; M1 ; M2
    end if
  end define
So the above example tape output would now look as follows :-
1538 G0 Z84.                                     ## Normal Rapid move
1539 X15.653 Y-37.059                    ## Skim move ( At Rapid Non Linear rate )
1540 Z69.667                                    ## Normal Rapid move
1541 G1 Z66.667 F950                     ## Plunge move
1542 X14.684 Y-37.456 F1100        ## Cutting move
Warning :   It is recomended that this method be employed with care as it is possible that gouging may occure due to the move not being impletmented in a direct line because the machine GO could  move the axes in a zig zag.
如帮助文件所改,
我加上这一个
    else
    end if
  end define
就没有办法再post了,
说我这一句定义错误
发表于 2004-3-9 12:24:33 | 只看该作者
因為機床的關係
每台機床都不一樣
舊型機床可能會產生過切現象
所以不建議使用skim  為 G00
如果真的要    請將後處理傳上來謝謝
发表于 2004-3-9 12:30:18 | 只看该作者
偶现在只有改maximum feedrate =  20000.0
快快帮我
发表于 2004-3-9 12:31:29 | 只看该作者
游客,本帖隐藏的内容需要积分高于 20 才可浏览,您当前积分为 0
发表于 2004-3-9 13:30:50 | 只看该作者
发表于 2004-3-9 14:11:10 | 只看该作者
谢谢板大
可以了
发表于 2004-3-9 20:14:09 | 只看该作者
  快快帮我
想不到高速机走得这么快
发表于 2004-3-12 17:13:40 | 只看该作者
看一下DUCTPOST的DOC文件保证你三天搞定所有的三轴POST的问题^_^
发表于 2004-3-12 20:02:01 | 只看该作者
现在粉忙了吧?
GMT+8, 2025-4-19 00:29 , Processed in 0.030177 second(s), 12 queries , Gzip On, Redis On.
