【求助】Surfcam 2002的后处理 (PostProcessor)
发表于 2003-2-8 15:48:50 | 只看该作者
blackbird111 wrote:
编写后处理(mpost)总是不得要领,不知从何入手?
  spost是图形化操作,却不知如何使用。
  后处理的资料太少,也找不到这方面的书籍。
  不知大家是用何种方法学习的?
MPost
Surfcam PDF Manual Page1221 -------
粉詳細...
发表于 2003-2-8 15:54:04 | 只看该作者
  不知大家是用何种方法学习的?
SPost=InterCIM GPost=Pro-NC GPost
Surfcam PDF Manaul Page 1371 ---
看看之前Pro-NC GPost的帖與Boby版主提供的教材
发表于 2003-2-22 03:40:17 | 只看该作者
最近自己开了几天数控铣,对后处理有些感觉了。
发表于 2003-2-22 23:49:12 | 只看该作者
自己試著改一個看看...
发表于 2003-2-23 00:01:23 | 只看该作者
现在用的数控系统是802s,我想把840D的后处理简化即可。
发表于 2003-2-23 05:39:29 | 只看该作者
最简单的,只进行直线圆弧插补。
name SIEMENS 802S
% 00
N >4
* 00
& 00
G 2
X ->3.>3
Y ->3.>3
Z ->3.>3
I ->3.>3
J ->3.>3
K ->3.>3
M 2
T >2
H >2
V >2
D >2
S >4
F >4
ModalLetters X Y Z F                       # List of letters that are modal
ModalGs 0 1 2 3                            # List of g codes that are modal
Sequence#s N 1 1 1                          # Char, freq, incr & start
First#? N                                   # Y or N  'Output 1st sequence no.
Last#? Y                                   # Y or N  'Output last sequence no.
HCode X                                     # X or X U  'Horizontal char.
VCode Y                                    # Y or Y V  'Vertical char.
Dcode Z                                     # Depth char.
FeedCode F                                  # Feed rate char.
Comment ;( )                              # Begin End comment char.
Spindle 3 4 5                               # Cw, ccw & stop m codes
Coolant 8 9 7                                   # Flood, Off, Mist and Thru Spindle M codes
DComp 41 42 40                              # Left, Right & Cancel m codes
LComp 43 49                                 # On & Off codes
Feed G01                                     # Linear move
Rapid G00                                    # Rapid positioning word
ArcPlane G 17 18 19                         # G19, G18, G17 Arc Plane selection
Cw G02                                       # Circular move clockwise
Ccw G03                                      # Circular move counter clockwise
Inc/Abs G 91 90                             #Inc& Abs char. & values
CtrCode I J K                               # I J or R or I J K L
Helical? Y
Spaces? Y                                   # Y or N  'Spaces between words
Incremental? Y                              # Y or N  'Inc or abs output
CtrIncremental? Y                           # Y or N  'Inc or abs I & J
ByQuadrants? Y                              # Y or N  'Break arcs at quadrants
UppercaseComments? N                        # Y or N 'Require uppercase comments
StartCode                                   # Start of the program
*[0]
&[0]
G<53> G<17> G<90>
End
1stToolChange
G<60> G<601> D<1>
G<54> S<Speed> M<Direct> T<Tool> F<FRate>
End
Infeed
G<Side> X<H> Y<V> F<FRate>
end
Outfeed
G<1> G<40> X<H> Y<V>
end
ToolChange
G<60> G<601> D<1>
End
EndCode
M05
M09                                    # End of the program
M02
End
Replace "*" With "%_N_CAM_MPF"
REPLACE "&" WITH "M07"
发表于 2003-2-23 05:54:47 | 只看该作者
可以生成数控程序,有个小问题:Z41. 但Z0  Y0 后没有“.", 希望表示为 Z0.  Y0. 如何设置?
18
发表于 2003-2-23 06:14:00 | 只看该作者
另外Incremental? y  CtrlIncremental? Y 和换刀设定的G90是否矛盾?
19
发表于 2003-2-23 18:11:49 | 只看该作者
這一欄是指  圓弧插補是 增量 或 絕對... 與G90, G91無關
20
发表于 2003-2-23 18:15:50 | 只看该作者
看不出來問題出在哪裡? 你上面貼的有完全貼上來嗎? 用附件貼上來偶幫你看看...
GMT+8, 2025-4-28 22:30 , Processed in 0.029599 second(s), 11 queries , Gzip On, Redis On.
