查看: 17186|回复: 15
本人打了2.0.2.2后出现意外情况!!!
发表于 2004-3-14 13:02:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2004-3-14 13:03:55 | 只看该作者
那个很好用的动态拉伸不见了 !!
发表于 2004-3-14 17:19:19 | 只看该作者
真遗憾,我装了也是这样,我用的是XP操作系统,断定可能这一升级文件只是支持WIN2000系统的缘故吧;希望能尽快出XP系统的升级文件哦。
发表于 2004-3-14 17:39:36 | 只看该作者
非也,只是新的補丁中把原來的动态拉伸指令不知拿到哪兒了,用原來的ug_modeling.men,ug_feature_operation.tbr還是可以的.我還在想辦法看怎麼做才可以更新後不用再手動去修正.....有研究出來的快發表一下吧!!
发表于 2004-3-14 17:46:21 | 只看该作者
整来整去总整不到理想要求的点子上,我看UG的进步真是太慢了!即便NX3出来,恐怕在许多方面也还不如小小的RHINO4.0哦!遗憾!
发表于 2004-3-15 08:11:03 | 只看该作者
UGII_ENV.DAT 中加UGII_NEW_EXTRUDE = 613
UGII_TRIM_AND_EXTEND = 613
UGII_CORNER_DART_DEMO = 613
UGII_VSWEEP_DEMO = 613
UGII_MOUSE_WHEEL=2
发表于 2004-3-15 10:18:20 | 只看该作者
上述方法只支持2.0.1.2,不支持2.0.2.2,故不起作用.
发表于 2004-3-15 11:10:43 | 只看该作者
四楼的兄弟,快出手,等待......
升级后,好像UGII\menus中ug_drafting.rws,ug_modeling.rws,ug_sketcher.rws三个文件被覆盖了。
发表于 2004-3-15 13:50:21 | 只看该作者
抄来的.
Navigate to the directory defined as UGII_USER_DIR. If this system environment variable is not set, define it.
Create these directories, if they don’t already exist:
startup
application
Navigate to the $UGII_USER_DIR/startup directory. Create a new file of any unique NX .men name with the .men extension (e.g., my.men). Its contents should be:
VERSION 120
EDIT UG_GATEWAY_MAIN_MENUBAR
MODIFY
APPLICATION_BUTTON UG_APP_MODELING
MENU_FILES my_modeling.men
END_OF_MODIFY
Note that my_modeling.men can be any unique Unigraphics NX .men name with the .men extension (e.g., my_modeling.men).
Navigate to the $UGII_USER_DIR/application directory. Create a file named my_modeling.men (or named as referenced above) with these contents:
VERSION 120
SHOW UG_MODELING_EXTRUDED_FEATURE
Bring up interactive Unigraphics NX 2.0.2. You may now access the new Extrude from Insert-> Form Feature-> Extrude. To add it to the NX Form Feature Toolbar, use MB3 over the toolbar area and choose Customize. Choose the Commands property page. Choose the Form Feature toolbar from the panel on the left. Select Extrude from the panel on the right.
发表于 2004-3-15 14:07:06 | 只看该作者
2.0.2.2版本有什么变化吗?当然是除了这个变化之外的,请给大家介绍一下!
GMT+8, 2025-9-18 14:37 , Processed in 0.096826 second(s), 13 queries , Gzip On, Redis On.
