查看: 17212|回复: 2
一个很郁闷的错误(vba开发cad一个小程序),大家看看。
发表于 2004-3-19 01:42:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Private Sub CommandButton1_Click()
   Call DrawArc
End Sub
Private Sub DrawArc()
   Dim NewArcObj As ACADArc
   Dim Center As Variant, Radius As Double
   Dim StartAngle As Double, EndAngle As Double
   With ThisDrawing.Utility
      Center = .GetPoint(, vbCr & "Enter the center point OR Click on center point:")
      Radius = .GetDistance(Center, vbCr & "Enter the raduis:")
      StartAngle = .GetAngle(Center, vbCr & "Enter the start angle:")
      EndAngle = .GetAngle(Center, vbCr & "Enter the end angle:")
   End With
   Set NewArcObj = ThisDrawing.ModelSpace.AddArc(Center, Radius, StartAngle, EndAngle)
   NewArcObj.Update
End Sub
‘错误提示:autocad主窗口不可见。
说明:有人说要关闭程序窗口,我加了unload me , 也不好用
autocad版本为2004
谢谢指教。
发表于 2004-3-19 11:30:13 | 只看该作者
AutoCAD.Application.Visible = True‘该语句有没有都可以
UserForm1.Hide
   Call DrawArc
End Sub
   Dim NewArcObj As AcadArc
   End With
   NewArcObj.Update
End Sub
发表于 2004-3-20 00:31:02 | 只看该作者
谢谢。
GMT+8, 2025-9-18 15:20 , Processed in 0.039639 second(s), 11 queries , Gzip On, Redis On.
