查看: 16314|回复: 5
【求助】在PRO/E2001中如何打印SHADE模式的图形
发表于 2002-9-12 09:19:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的PRO/E2001在线框下打印都正常,可是一转成SHADE模式就无法正常打印了,连CONFIGURE都变灰不能使用了?还会出这样的错误An error occured while executing the shaded print.请教各位如何解决!
发表于 2002-9-12 13:35:37 | 只看该作者
怎么没有热心的人帮我解决啊?那就请斑竹来帮忙了!
发表于 2002-9-12 13:45:49 | 只看该作者
直接抓屏再打印不就可以了吗。
发表于 2002-9-12 14:00:32 | 只看该作者
不是的,我还想搞清楚出错的原因。而且抓屏打印很麻烦的。
发表于 2002-9-12 19:14:29 | 只看该作者
FYI:
Print a Shaded Model:
Note: Shaded plots cannot be generated with the MS Printer Manager.
Printing a model that is shaded is different from printing a model that is set to display in wireframe, hidden line, or no hidden line. With shaded models, you specify model scaling and formatting using the Shaded Image Configuration dialog box.
1. Click File > Print. The Print dialog box opens.
2. Click “choose a printer” icon to choose a printer or to add a new printer. The selected printer type is saved for the current session only. Note that shaded plots cannot be generated with the MS Printer Manager.
3. Click Configure to specify model scaling and formatting for printing. The Shaded Image Configuration dialog box opens.
4. Set model scaling and formatting as desired, using the following options in the Shaded Image Configuration dialog box.
Size
  Specify a standard size or a custom size by selecting from the list.
Height
  Specify custom height dimensions (if you select Variable in the Size list as a paper size).
Width
  Specify custom width dimensions (if you select Variable in the Size list as a paper size).
Top Margin
  Specify custom top margin dimensions (if you select Variable in the Size list as a paper size).
Left Margin
  Specify custom left margin dimensions (if you select Variable in the Size list as a paper size).
Units
  Set the variable plot size to inches or millimeters.
DPI
  Specify the resolution of the output from the list. Choose from 100 dpi, 200 dpi, 300 dpi, or 400 dpi.
Image Depth
  Specify the image depth for the print. choose from 8 bit index or 24 Bit RGB.
发表于 2002-9-13 18:57:30 | 只看该作者
可是在我的打印机列表里没有我的打印机型号?
GMT+8, 2025-4-27 11:40 , Processed in 0.023149 second(s), 12 queries , Gzip On, Redis On.
