查看: 15788|回复: 2
R13的钣金
发表于 2004-3-21 22:04:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问R13的钣金有加强吗?
发表于 2004-3-22 09:36:22 | 只看该作者
New Functionalities
Conical Bend
You can now create conical bends.
Recognize
You can now recognize an existing part as a Generative Sheetmetal Design part.
Hopper
You can now create hoppers.
Defining Generative View Styles
Generative view styles let administrators customize the appearance of drawings via a set of parameters defined in an XML file. Administrators can now define the generative view styles that should be used when generating drawings from sheet metal parts.
Producing Drawings with Generative View Styles
You can now produce drawings using generative view styles.
Enhanced Functionalities
New parameters and options available for flanged hole
The Flanged Hole Definition dialog box has been redesigned to provide more parameters and options.
The interface of the Flange Definition dialog box has been redesigned to provide additional possibilities.
New parameters and options available for hem
The interface of the Hem Definition dialog box has been redesigned to provide additional possibilities.
New parameters and options available for tear drop
The interface of the Tear Drop Definition dialog box has been redesigned to provide additional possibilities.
Longitudinal chamfer
You can now create a longitudinal chamfer by selecting a single long edge, which allows you to create a welding chamfer.
发表于 2004-4-12 22:51:29 | 只看该作者
有,k系数更改天便了
GMT+8, 2025-4-25 15:53 , Processed in 0.019756 second(s), 11 queries , Gzip On, Redis On.
