查看: 17121|回复: 6
Cimatron E5.02中文版,怎样输出中间文件
发表于 2004-3-30 21:05:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我们单位刚买了Cimatron E5.02中文正式版,但是,不知道怎样输出中间文件。以前的外挂后置处理程序没办法用了,培训老师也没办法导出中间文件。
那位好人指点指点,万分感谢!!
发表于 2004-3-31 00:02:10 | 只看该作者
中间文件?不明白
发表于 2004-3-31 09:14:15 | 只看该作者
      我是用ug的,UG可以输出后缀为cls的中间文件,可以用第三方的后置处理程序进行处理。我厂用的全是第三方的后置处理程序。
      Cimatron E5.0以前的版本可以输出类似于UG的cls的中间文件。
      因为我厂有好几台很特殊的机床,所以后置处理程序都是用VB重新编制的,急需导出中间文件。
发表于 2004-3-31 09:31:52 | 只看该作者
USE IMPOST 成生 .APT FILE.
SOULD BE THE SAME THING.
   TOOL XX  , TOOL,XX
    TLDATA/MILL,10.0000,5.0000,75.0000,0.0000,0.0000
    MSYS/158.7500,31.7500,50.8000,1.0000000,0.0000000,0.0000000,0.0000000,1.0000000,0.0000000
    PAINT/PATH
    PAINT/SPEED,10
    LOAD/TOOL,1
    SPINDL/RPM,100,CLW
    COOLNT/FLOOD
    PAINT/COLOR,186
    RAPID
    GOTO/-127.6618,136.7055,30.0000,0.0000000,0.0000000,1.0000000
    RAPID
    GOTO/-127.6618,136.7055,2.5400
    PAINT/COLOR,42
    FEDRAT/MMPM,36.0000
    GOTO/-126.2491,136.9759,2.1546
    GOTO/-124.6974,138.0341,1.6513
    GOTO/-123.6231,139.8295,1.0907
    GOTO/-123.4242,141.6971,0.5874
    GOTO/-123.9852,143.4896,0.0842
    GOTO/-125.2133,144.9106,-0.4191
    GOTO/-126.9056,145.7254,-0.9223
发表于 2004-3-31 09:34:59 | 只看该作者
   TOOL XX  , TOOL,XX
   &nbspAINT/PATH
   &nbspAINT/SPEED,10
    LOAD/TOOL,1
    SPINDL/RPM,100,CLW
    COOLNT/FLOOD
   &nbspAINT/COLOR,186
    RAPID
    RAPID
   &nbspAINT/COLOR,42
    FEDRAT/MMPM,36.0000
,长见识
建议给热心的ray斑竹加分鼓励
发表于 2004-3-31 13:19:26 | 只看该作者
老大,多谢!我没权力给你加分,先在心里给你加分!!
发表于 2004-4-2 14:49:15 | 只看该作者
use gpp 模拟仿真后生成。CL文件
   \Cimatron\CimatronE\Data\VERIFY_DIR
UNIT/MM
NEXT_TOOLPATH
NEXT_PROCEDURE
PPRINT/WCUT
PPRINT/No Text
CUTTER/10.0,0.0,0.0,0.0,0,0,15.0
LOADTL/1,ADJUST,1
FROM/-261.6953,0.0551,50.0
GOHOME
TOOLINF/'无名称',1,10.0,0.0,30.0,15.0,'无备注'
RAPID
SPINDL/RPM,1000,CLW
COOLNT/OFF
GOTO/-261.6953,0.0551,50.0,0.0,0.0,1.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3 Blk. =9
FEDRAT/150,MMPM
GOTO/-261.6953,0.0551,44.0,0.0,0.0,1.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3  Blk. =11
FEDRAT/500,MMPM
GOTO/-261.8747,0.1093,44.0,0.0,0.0,1.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3  Blk. =14
GOTO/-261.8748,-0.1082,44.0,0.0,0.0,1.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3  Blk. =15
GOTO/-261.5158,0.0015,44.0,0.0,0.0,1.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3  Blk. =16
GOTO/-261.6953,0.0551,44.0,0.0,0.0,1.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3  Blk. =17
GOTO/-259.9699,5.8016,44.0,0.0,0.0,1.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3  Blk. =19
CIRCLE/-245.9885,52.3684,44.0,0.0,0.0,-1.,48.6204
GOTO/-267.7817,8.9058,44.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3  Blk. =21
CIRCLE/180.6242,-0.2333,44.0,0.0,0.0,1.,448.499
GOTO/-267.7901,-8.9506,44.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3  Blk. =22
CIRCLE/-245.5723,-52.8128,44.0,0.0,0.0,-1.,49.1683
GOTO/-243.7371,-3.6787,44.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3  Blk. =23
GOTO/-237.4231,-3.7582,44.0,0.0,0.0,1.0 $$  TP=TP_MODEL-3 Proc. WCUT    =3  Blk. =24
GMT+8, 2025-4-26 05:42 , Processed in 0.034755 second(s), 11 queries , Gzip On, Redis On.
