查看: 17505|回复: 3
【求助】autocad 可否打开igs文件
发表于 2004-4-8 15:28:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题
谢谢各位帮个忙了!!!
发表于 2004-4-8 15:41:15 | 只看该作者
推薦:
IGES Import for AutoCAD
Description:
IGES Import for AutoCAD is a plug-in for AutoCAD 2000/2000i/2002. This plug-in gives AutoCAD the ability to import graphical data from ASCII IGES files.
The Initial Graphics Exchange Specification (.IGES) file format standard was developed to address the incompatibility issue with various CAD/CAM systems. This standard allows efficient and accurate exchange of product definition data across almost all CAD/CAM systems.
IGES files contain graphical data in the form widely accepted by most CAD/CAM systems. IGES Import for AutoCAD converts this graphical data into corresponding AutoCAD entities and adds them to the contents of the currently opened AutoCAD drawing.
This plug-in is very easy to use as it adds a new command to AutoCAD called "IGESIN". The user has to simply type "IGESIN" at the AutoCAD command prompt and select an IGES file to import.
Version: 1.0
File Size: 400Kb
Platform: AutoCAD 2000 thru 2002 (+ verticals)
  https://www.caddepot.com/cgi-bin/downloads/download.cgi?
  https://www.fpsols.com/installers/IGESImportAC.exe
发表于 2004-4-9 20:13:37 | 只看该作者
谢谢,看到了
发表于 2004-4-10 01:01:07 | 只看该作者
3Q
GMT+8, 2025-4-19 19:39 , Processed in 0.023200 second(s), 11 queries , Gzip On, Redis On.
