查看: 16633|回复: 3
【讨论】ANSYS如何分析带铰链的空间钢架
发表于 2004-4-12 13:54:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位学长:我需要用ANSYS 分析空间的刚架结构,但不知如何处理它们之间的铰接问题?请指教。
发表于 2004-4-13 16:22:19 | 只看该作者
直接采用LINK单元,共点就是表示铰接
发表于 2004-5-18 10:19:18 | 只看该作者
COMBIN7: Revolute Joint
MP ME ST <> <> <> <> <> <> PP ED
Element Description
COMBIN7 is a three-dimensional pin (or revolute) joint which may be used to connect two or more parts of a model at a common point. Capabilities of this element include joint flexibility (or stiffness), friction, damping, and certain control features. An important feature of this element is a large deflection capability in which a local coordinate system is fixed to and moves with the joint. This element is intended for use in kinetostatic and kinetodynamic analyses.
发表于 2004-5-19 21:16:35 | 只看该作者
这个问题你们应该去看一下中华钢结构网,你们都是老粗???
GMT+8, 2025-4-20 06:26 , Processed in 0.022672 second(s), 13 queries , Gzip On, Redis On.
