查看: 15833|回复: 1
Engineer Analysis model Creat in APDL
发表于 2004-4-16 12:58:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The sample is my first engineer analysis application and I creat this model with APDL which is very easy to change the parameter in the model. The work is not finish yet. So just for your reference only!!!
Need export give me some advice on it. As i know that we can learn this one more effectively if you have a project on hand.
发表于 2004-4-24 11:05:13 | 只看该作者
I finish the work of Engineering Analysis. and I remesh the element in the model.
GMT+8, 2025-1-24 05:00 , Processed in 0.026556 second(s), 10 queries , Gzip On, Redis On.
