查看: 16643|回复: 8
寻求帮助,关于ug装配部分的二次开发
发表于 2004-4-17 15:23:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
谢谢,斑竹回答我上次的问题,讲得很详细,呵呵~!
下面是我编译的关于贴合装配的源程序:
char message[133];  //选择第一个面的程序
         message[0]='\0';
       strcpy(message,"请选择第1个面");
         UF_UI_selection_options_t opts;
       UF_UI_mask_t mask;
       int response;
       tag_t view;
       double cursor[3];
       int unhightlight=0;
       UF_initialize();
       opts.other_options=0;
       opts.reserved=NULL;
       opts.num_mask_triples=1;
       opts.mask_triples=[$mask]
         opts.mask_triples->object_type=UF_face_type;
       opts.mask_triples->object_subtype=UF_bounded_plane_subtype;
       opts.mask_triples->solid_type=UF_UI_SEL_FEATURE_ANY_FACE;
       opts.scope=UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY;
       int type;
       double point[3];
       double dir[3];
       double box[6];
       double radius;
       double rad_data;
       int norm_dir;
       tag_t first_plan;
     int irc=UF_UI_select_single(message,&opts,&response,
                           [$first_plan,cursor,&view)]
        UF_MODL_ask_face_data(first_plan,&type,point,dir,box,
                         [$radius,&rad_data,&norm_dir)]
      if(type!=22&&type!=16&&type!=18&&type!=23&&type!=19&&type!=20&&type!=17)
      {  uc1601("请选择一个面",1);
      UF_DISP_set_highlight(first_plan,0);}
     //此时的first_plan是object occurence
       if(response!=5)
     {     uc1601("没有选择面",1);
          return( UF_UI_CB_CONTINUE_DIALOG );}
     int ret;
     tag_t from_part_occ;
     ret=UF_ASSEM_ask_parent_component(first_plan,[$from_part_occ)]
                                 char part_name[132+1];
     char refset_name[30+1];
     char instance_name[30+1];
     double origin[3];
     double csys_matrix[9];
     double transform[4][4];
     ret=UF_ASSEM_ask_component_data(from_part_occ,part_name,refset_name,instance_name,
                                     origin,csys_matrix,transform);
  uc1601("请选择第2个面",1);
     message[0]='\0';
         strcpy(message,"请选择第2个平面");
               tag_t second_plan;
         int irc2=UF_UI_select_single(message,&opts,&response,
                           [$second_plan,cursor,&view)]
        UF_MODL_ask_face_data(second_plan,&type,point,dir,box,
          UF_DISP_set_highlight(second_plan,0);}
       if(response!=5)
     tag_t to_part_occ;
     ret=UF_ASSEM_ask_parent_component(second_plan,[$to_part_occ)]
     ret=UF_ASSEM_ask_component_data(to_part_occ,part_name,refset_name,instance_name,
     //构造配合关系
     tag_t from_part_ins=UF_ASSEM_ask_inst_of_part_occ(from_part_occ);(问题出现处)
     uc1601("hahahahaha",1);(测试语句)
     UF_ASSEM_mating_condition_t ftf;
         ftf.mated_object=from_part_ins;
     ftf.name=NULL;
     ftf.user_name=FALSE;
     ftf.constraints[0].from_status=UF_ASSEM_ok;
         ftf.constraints[0].to_status=UF_ASSEM_ok;
     ftf.constraints[0].mate_type=UF_ASSEM_v16_mate;
     ftf.constraints[0].from_type=UF_ASSEM_planar_face;
         ftf.constraints[0].to_type=UF_ASSEM_planar_face;
         ftf.constraints[0].from=UF_ASSEM_ask_prototype_of_occ(first_plan);
     ftf.constraints[0].from_part_occ=from_part_occ;
目前还没有编译完成,但是在进行测试的时候,虽然没有错误,但是我的测试语句 uc1601("hahahahaha",1);并没有出现,我认为就是因为执行 tag_t from_part_ins=UF_ASSEM_ask_inst_of_part_occ(from_part_occ);后就往后执行了,请问斑竹为什么会这样,怎么才能解决阿~!!!!我的程序是根据清华那本书上改编的啊,在问题出现处之前都能较好的执行,就是在那条语句之后就执行不了了~!
发表于 2004-4-17 23:20:54 | 只看该作者
from_part_occ的选择是很有讲究的,以前我也遇到过类似的问题。可能你选择的不是Occ。
发表于 2004-4-18 10:52:48 | 只看该作者
那要怎么样才能解决这个问题呢,用一个别的变量代替occ?
发表于 2004-4-18 14:44:03 | 只看该作者
请问你这句话有什么用?
发表于 2004-4-19 08:04:55 | 只看该作者
具体我也不太清楚,我是照着清华那本书上写的,好像就是一个提示所显示的实例名称的,关键是岛问题出现处就不往下执行了,请问怎么样修改呢~!!我现在很着急啊~!!!!!
发表于 2004-4-19 11:54:07 | 只看该作者
我建议你不要去选择面,用程序来找所需要的面去装配,这样肯定没有问题,你先试试吧。
发表于 2004-4-19 22:31:28 | 只看该作者
多谢多谢~!!!呵呵,现在又面临个新问题,之前的问题我已经解决了,就是在构造配合关系那里,具体就是ftf.constraints[0].to=UF_ASSEM_ask_prototype_of_occ(second_plan)执行不了啊,不知道为什么, ftf.constraints[0].from=UF_ASSEM_ask_prototype_of_occ(first_plan); 可以执行阿,我两个面的程序基本上是一样的,为什么second_plan执行不了,我用的是nx2.0版本的~!!!
头像被屏蔽
发表于 2004-5-16 19:47:27 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
发表于 2004-5-16 21:21:14 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-1-31 07:55 , Processed in 0.024035 second(s), 10 queries , Gzip On, Redis On.
