查看: 16564|回复: 1
New Pencil Tracing mill Sequence
发表于 2004-5-4 10:05:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Benefits
It is ideal for finishing shallow corners, and removes the need to work-around by using Local/Prev Tool sequences.
Description
It is a new sequence type, located under the Local Mill sequence menu. In addition, it provides slope angle control using the parameter SLOPE_ANGLE. This will keep the tool from dipping into steep corners (all corners steeper than the slope_angle parameter).
Menu Location
Local, Prev Sequence
发表于 2004-5-4 12:28:01 | 只看该作者
[quote]lmccax wrote:
Does it new?I had used it last year yet.
GMT+8, 2025-4-30 08:18 , Processed in 0.020909 second(s), 11 queries , Gzip On, Redis On.
