查看: 18110|回复: 1
【公告】CATIA V5R13SP2的hotfix项目
发表于 2004-5-7 17:54:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
DS最新提供的R13Sp2 hotfix解决了以下的BUG
做开发的或用相应模块的可以参考一下
这些修正将会被反映到sp3里
- Level FUNCTION       APAR      Abstract
  HF1   EV5INFRA       HD17602   Edit ODMA does not work for MSWord documents
  HF1   OBJMOD         HD18537   OBJECT MANAGER / CATIA DOES NOT EXECUTE STEP CONVERSION UTILITY
  HF1   SHAPEDSG       HD18857   GSD Line When a line is deleted, non-related element also affected
  HF1   ASSEMBLY       HD18942   Assembly : After a replace of component, the update takes 10 times more than R11
  HF1   SHAPEDSG       HD19071   GSD / CIRCLE : CATIA ABENDS WHEN SUPPORT IS SELECTED
                                 FOR A CIRCLE WITH CENTER AND TANGENT METHOD
  HF1   REVWMACH       HD19137   NC REVIEW / WHEN A NEW TOOL IS LOADED THROUGH TOOLING QUERY IN A MACHINING PROCESS
                                 IT HAS 1000 TIMES VALUE
  HF1   PART           HD19354   If 'Thick Surface' is performed CATIA becomes ABEND
  HF1   GENDRAFT       HD19373   GENERATIVE DRAFTING / ABEND WHEN PERFORMING AN OFFSET SECTION CUT VIEW AND
                                 SWAPING BETWEEN THE CATPART WINDOW AND THE CATDRAWING WINDOW
  HF1   EV5INFRA       HD19372   Get a error that says Server Crash when sending a Product Enovia to PPRHUB
  HF1   SKETCHER       HD19546   SKETCHER / REPLACE OF A SPLINE WITH A USE EDGE ISN'T POSSIBLE
                                 IF 2D OFFSET OF SPLINE EXISTS : USE EDGE CANNOT BE SELECTED
  HF1   MECMOD         HD20329   NULPMRCAD00253: Synchronizeing Command on Solid not worked at R13GASP2
  HF1   EV5INFRA       HD20497   JAVA PROCESS OUT OF MEMORY CONDITION REACHED
                                 WHEN TO MANY APPLICATION CONNECT TO VAULT SERVER
  HF1   REVWMACH       HD20679   NULPMRCAM00268: No DS command appears in NUL Workbench
  HF1   ITEV5CV5       HD18246   Crash CATIA sending to CATIAV5 an Assembly
  HF2   DPMASM         DR2923    A Problem in restoring Visualization Mode
  HF2   HUMNSIM        DR2931    Manikin shifts when saving a posture in V5 catalog
  HF2   HUMNBLD        DR15000   Manikin constraints are not updated automatically
  HF2   HUMNSIM        DR3024    pelvis-leaning posture is ignored during Line Tracking
  HF2   VISU           HD19715   Selection Set High-Light problem
  HF2   HUMNBLD        DR3066    Reset of a manikin segment moves a manikin to an unexpected posi
  HF2   HUMNBLD        DR3081    Referential of Manikin isn't referred when loading posture
  HF2   HUMNSIM        DR3095    Walk-related API does not work properly
  HF2   PROENOPT       HD20596   PEO / EXPERIMENTS WHICH IS INSTANTIATED FROM POWERCOPY IS INCORRECT
  HF2   MOLDTOOL       HD20689   NULPMRCAD00269: Bad performance if deactive rule was included
  HF2   ELECWIRE       HD21085   ELECTRICAL WIRE ROUTING / BUNDLE ON WHICH A WIRE EXISTS IN IS NOT HIGHLIGHTED.
  HF2   MANUINTF       HD21095   Arc Display on tool path center points failed
  HF2   HUMNBLD        DR3138    IK Worker Frame Rotation with User Env
  HF2   HUMNBLD        DR3139    Multi part relation behavior
  HF2   DPMASM         DR3058    Part jumps to incorrect position if editing move activity
  HF2   DMPPRHUB       DR3131    Detailing cannot be opened after DB has been updated
- Here is the list of files that will be fixed by the current CD-ROM:
2367565   .\intel_a\code\bin\CATApplicationFrame.dll
81988     .\intel_a\code\bin\CATBBMagic.dll
98376     .\intel_a\code\bin\CATBatProtocol.dll
94279     .\intel_a\code\bin\CATBatchUtils.dll
1441863   .\intel_a\code\bin\CATEleModeler.dll
3280964   .\intel_a\code\bin\CATFDGImpl.dll
282692    .\intel_a\code\bin\CATGuiLine.dll
397384    .\intel_a\code\bin\CATGviGeomVisu.dll
2564      .\intel_a\code\bin\CATIAAppTypeLib.tlb
106566    .\intel_a\code\bin\CATIABatImpl.dll
266311    .\intel_a\code\bin\CATIPDProcess.dll
6013003   .\intel_a\code\bin\CATManufacturing1.dll
2883659   .\intel_a\code\bin\CATManufacturing2.dll
2293835   .\intel_a\code\bin\CATManufacturing3.dll
77910     .\intel_a\code\bin\CATManufacturingBufferOutput.dll
2781260   .\intel_a\code\bin\CATManufacturingUI.dll
6148174   .\intel_a\code\bin\CATMechanicalModeler.dll
569422    .\intel_a\code\bin\CATMfgInProcessModel.dll
2179151   .\intel_a\code\bin\CATObjectSpecsModeler.dll
553036    .\intel_a\code\bin\CATPrdEnoviaV5Impl.dll
2490446   .\intel_a\code\bin\CATProductStructure1.dll
303171    .\intel_a\code\bin\CATPrsRep.dll
3158089   .\intel_a\code\bin\CATSkmWireframe.dll
716873    .\intel_a\code\bin\CATSktAssistant.dll
1724488   .\intel_a\code\bin\CATSkuCommands.dll
979015    .\intel_a\code\bin\CATSpaMeasure.dll
2494534   .\intel_a\code\bin\CATThickImpl.dll
118859    .\intel_a\code\bin\CATToolPathEditor.dll
823372    .\intel_a\code\bin\CATToolPathEditor2.dll
24644     .\intel_a\code\bin\CATVersion.exe
319564    .\intel_a\code\bin\DNBAsyActivityBase.dll
876617    .\intel_a\code\bin\DNBHumanSimBase.dll
544845    .\intel_a\code\bin\DNBHumanSimCommands.dll
61519     .\intel_a\code\bin\DNBHumanSimInterfaces.dll
15300     .\intel_a\code\bin\DNBHumanSimItfTypeLib.tlb
204874    .\intel_a\code\bin\DNBHumanSimModel.dll
172097    .\intel_a\code\bin\DataNav.dll
57412     .\intel_a\code\bin\ENOVIPDSRV.dll
24648     .\intel_a\code\bin\ENOVODMAdapter.dll
1654850   .\intel_a\code\bin\JS0GROUP.dll
94278     .\intel_a\code\bin\MfgBatchMain.dll
24650     .\intel_a\code\bin\MfgClfileConvExe.exe
1376332   .\intel_a\code\bin\ProcessModelerBase.dll
909384    .\intel_a\code\bin\SWKHmiCommands.dll
528454    .\intel_a\code\bin\SWKHmiUIBase.dll
327758    .\intel_a\code\bin\SWKHumanModelingAuto.dll
688206    .\intel_a\code\bin\SWKHumanModelingBase.dll
110669    .\intel_a\code\bin\SWKHumanModelingCCP.dll
102477    .\intel_a\code\bin\SWKHumanModelingItf.dll
38484     .\intel_a\code\bin\SWKHumanModelingTypeLib.tlb
1126467   .\intel_a\code\bin\SWManikin.dll
188485    .\intel_a\code\bin\VPMTpPlugin.dll
353090    .\intel_a\control\B13.2
2112      .\intel_a\docs\java\BBJumper.jar
5982      .\intel_a\docs\java\VDK0VaultBatch.jar
33934     .\intel_a\docs\java\VDK0VaultChecker.jar
188708    .\intel_a\docs\java\VDK0VaultServer.jar
24325     .\intel_a\docs\java\VaultJAVACORBA_S.jar
12581     .\intel_a\resources\graphic\SWKHumanModel.feat
发表于 2004-5-7 19:50:25 | 只看该作者
顶一下。。。
GMT+8, 2025-4-25 06:41 , Processed in 0.029939 second(s), 11 queries , Gzip On, Redis On.
