查看: 15280|回复: 1
各位大侠我想问一下阵列的问题
发表于 2004-5-8 19:07:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
当用关系式阵列时,那些变量是什么意思?
发表于 2004-5-8 19:55:02 | 只看该作者
看一下下面的说明,也许你会明白的,希望能帮助你
/*  Enter relations using the following symbols:
/* memb_v - relation driven resultant dimension in this specific direction
/* memb_i - relation driven increment in this specific direction
/* lead_v - leader value (dimension selected to determine direction)
/* idx1   - pattern instance index in the first direction
/* idx2   - pattern instance index in the second direction
/*   DO NOT USE memb_v AND memb_i IN THE SAME RELATION
GMT+8, 2025-4-28 17:03 , Processed in 0.020620 second(s), 11 queries , Gzip On, Redis On.
